Old 04-08-2005, 11:02 AM   #14071
Turbonium's Avatar
Trader Rating: 27 (100%+)
Send a message via Yahoo to Turbonium
Originally posted by Herminator
LOL, three cars I could buy already
It's ok about the pics Turbonium, I'm looking for a slightly different spec anyway.
gotcha... no biggie.
Wes
Team Novak
Turbonium is offline   Reply With Quote
Old 04-08-2005, 04:25 PM   #14072
JDM_DOHC_SiR's Avatar
Trader Rating: 31 (100%+)
Originally posted by RcMonk
If only I can get the TC4 that I have been messing around with to be as quiet as my Cuda. The TC4 is really loud !! Whir whir whir....Maybe Dave has some tricks up his sleeve....
PM Me I have quite a few
-Dave
Ȼ4.5 Centro+α ◊ TRF 501ӽ ◊ TRF 502ӽs ◊ TRF 503 ◊ TRF 511 ◊ TRF 201ӽr ◊ TRF 211ӽ
B5m ◊ T5m ◊SC5m ◊ B64deez nutz
Speedway PAL ◊ SDRC ◊ Shop UFO ◊ SMC
JDM_DOHC_SiR is offline   Reply With Quote
Old 04-08-2005, 04:27 PM   #14073
Originally posted by gene465
Okay, I have looked through alot of pages in this thread but hey it's over 460+ pages! Alot of good info to be had but it will take me awhile to get through them all. My R3 is enroute and plan on running it with a 19T/27T motor the weekend after this one. Can anyone give me a good set-up for the R3 on a large asphalt track it has a large straightaway and a medium difficulty infield. Should I use my current TC3/TC4 set-up? I plan on running rubbers with the car. Any assistance would be greatly appreciated. Thanks Gene
I posted a very good no swaybar set up about 10-15 pages back for a R3 with a similar track to what you have..
Have a look.. you'll find it
-Dave
Old 04-08-2005, 10:59 PM   #14074
gene465's Avatar
Trader Rating: 25 (100%+)
Send a message via Yahoo to gene465
Dave,
Thanks I will keep looking I went back 18 pages and did not find it yet maybe I missed it. I will keep checking! I was at my LHS today and a couple of racers and I were talking and they all looked at me like I was crazy when I mentioned the Barracuda. Most had never heard of it. Looking forward to blowing them away with a car they never heard of! Thanks Gene
gene465 is offline   Reply With Quote
Old 04-09-2005, 09:34 AM   #14075
racer's Avatar
Dave,
here's the link:
http://www.rctech.net/forum/showthre...pagenumber=669
racer is offline   Reply With Quote
Old 04-09-2005, 09:55 AM   #14076
gene465's Avatar
Default Re: R3 High Grip set up(no sway bars)
Originally posted by JDM_DOHC_SiR
Here ya go Poop
Front
Front One way
Oil AE 35W
1.2mm pistion
1.5x600 spring
Mid Span sus arm
Lower hole on c-hub(5deg)
Outermost hole on upper deck for camber link
shock on outer most hole on shock tower & 60% or inner hole on sus arm
toe 0deg @ wheels
Sus arm toe out (as much as you can get )you`ll need offset sus balls for this..the front a-arms when looking down at them should look like this \ /..as much as possible
Camber 1deg
4.5mm ride height
3.5mm rebound/droop
Steering Rack inner holes for linkage and short/fwd hole on knuckle
Rear
Rear Diff med~tight
Oil AE 30W
1.2mm pistion
1.5x700 spring
Mid Span sus arm
Upper hole on rear hub
Shock on outer most hole on shock tower & 70% or second hole in on sus arm
toe in 2.5 deg
camber 1.5 deg
4.8~5mm ride height
4.5mm rebound/droop
This set up can work with both mid span or long span sus arms..all you have to do is change the upper camber link mount from the outermost hole to the middle hole on the upper deck.. so if the track grip goes away switch to the long span
I also would recomend using a nutral body..AKA Dodge 2.0 and try to stick with a Med inner...Xenon Green or Xenon X-Black..and you should be on your way to having a very fast cornering easy driving Barracuda
Good Luck
-Dave
Thanks Dave, Sneaky will give it a shot, If it had teeth it would have bit me! LOL.
Old 04-09-2005, 04:11 PM   #14077
Default Re: Re: R3 High Grip set up(no sway bars)
No problem
Old 04-10-2005, 12:52 PM   #14078
Herminator's Avatar
Send a message via ICQ to Herminator
Well I've had a decent days racing. I was expecting to be pretty rusty but after tip toeing around on a damp track for a couple of packs of cells I was up to the usual speed. Just in time for the track to dry out.
Setup from last October was just as I remembered it, pretty darn good
I just need to get a new motor and possibly a couple packs of 3700's. The car was lacking a bit of oomph.
Would like a second car as a spare but the R2 is so darn reliable.... (plus I need a PC upgrade )
Herminator is offline   Reply With Quote
Old 04-12-2005, 06:45 AM   #14079
gene465's Avatar
Guys just got my R3 and I must say an awsome car! Not too fond of the steering rack but it is very free along with the rest of the car. I am in the process of setting it up for a large asphalt track and while I have the instructions they are in Japanese! What is the transmission ratio to figure out final drive ratio with spur and pinion? Want to make up my chart for the car. Thanks Gene
Old 04-12-2005, 06:53 AM   #14080
stjerno's Avatar
Guess it's time to post this again
stjerno is offline   Reply With Quote
Old 04-12-2005, 06:55 AM   #14081
stjerno's Avatar
oh and the ration is 39/16= 2.4375
Old 04-12-2005, 06:55 AM   #14082
The Internal Gearing Ratio is 2.4375
i.e. 39T (Big Gear) / 16T (Small Gear)
dhiracing.com is offline   Reply With Quote
Old 04-12-2005, 06:57 AM   #14083
stjerno ... it seems you were faster than me in typing
Old 04-12-2005, 06:58 AM   #14084
stjerno's Avatar
yep .. fast and furious
How is that outdoore setup comming ?
Old 04-12-2005, 07:09 AM   #14085
I simply have to find the time to write it down. Will do my best to do it tomorrow cause bit busy building new kits for customers at the moment
One of my team drivers used the R3 during round 7 of our national championships, i.e. couple of weeks ago and he did manage to finish 2nd in the modified class making also the 2nd best time of the whole day. Quite impressive I might say, taking in consideration that he normally races with Xray and practised with the R3 only for couple of days before the actual race meeting
WTB Alex Racing Barracuda R2 & R3 Funkymojo R/C Items: Wanted to Buy 3 02-03-2007 01:00 PM
alex racing barracuda con81 Electric On-Road 1 12-14-2005 03:36 AM
WTT: Alex Racing Barracuda R2 for PS2 AZ_Ron Other Items: For Sale/Trade or Wanted to Buy 0 02-13-2005 07:30 PM
Alex Racing Barracuda R3-New. rcracing1973 R/C Items: For Sale/Trade 9 04-11-2004 08:29 AM
Alex Racing Barracuda Bugs Bunny Singapore R/C Racers 6 01-22-2003 11:47 PM
