Old 03-10-2005, 10:10 PM   #14011
COLEKO's Avatar
Send a message via AIM to COLEKO
Default Re: help with rear toe in
Originally posted by poop
Hi, i know that this has been asked before but i cant find where it is
I cant get the rear left toe to be anything more than 1 degree toe in i've tried offset balls front and rear and that didnt help...i've tried using standard pivot balls and that gave me maximum of 1 degree
it used to be fine...dont know why it's like this now all of a sudden
My left toe in was off to but found out it was my setup station that was a little off. You can also check for a bent pivot ball or bent screw or try new rear uprights
The Flying Hawaiian
Team TAOB 2004
COLEKO is offline   Reply With Quote
Old 03-11-2005, 05:07 AM   #14012
StasI's Avatar
Default Re: barracuda rc spool
Originally posted by StasI
hi guys i got a speedtech spool from steve 2 days ago and i think that the car is going to split something like universals or shafts i am running a 12 turn also when i turn hard left and right the car likes catches on the unversal join is this right help would be nice................thanks
ANYONE
StasI is offline   Reply With Quote
Old 03-11-2005, 05:38 AM   #14013
I think someone already mentioned this matter in the past. With the Speedtech's locked diff I think you have to limit the amount of travel of the steering, otherwise it is quite normal to hear that noise. Maybe someone else might give you more detailed information
I am currently using a locked diff made locally using also Alex's original one way cups and I have no problem at all
dhiracing.com is offline   Reply With Quote
Old 03-11-2005, 05:39 AM   #14014
stjerno's Avatar
Hi,
Did you get the asphalt setup finished ?
Later
Claus
stjerno is offline   Reply With Quote
Old 03-11-2005, 05:59 AM   #14015
Yes, was really quite impressed with my R3. I raced first time with it in modified last National Race Meeting and finished 3rd overall in the last race. Taking in consideration that it was only my third race meeting ever in our open modified class and that the drivers who placed 1st and 2nd has been racing modified for years, I think it is quite a good result
Working on some final touches and will be posting the setup shortly
Old 03-11-2005, 06:04 AM   #14016
wyd
Tech Legend
wyd's Avatar
Trader Rating: 50 (100%+)
Send a message via AIM to wyd
When I ran my spool I had the same problem plus if I touched anything it would strip my front gear. Running spools is very hard on the front drivetrain on any car but shaft cars it even seems to be harder yet on the car.
ST Racing Concepts (STRC)
Old 03-12-2005, 03:57 PM   #14017
Trader Rating: 23 (100%+)
Default Re: Re: help with rear toe in
I've tried changing new arms, and even changing to new pivot balls. the screws look fine, and my setup station is fine too because you can see that the left toe is way off compared to the right without needing a set up station to read the numbers when i bolted on some set up wheels.
poop is offline   Reply With Quote
Old 03-12-2005, 09:57 PM   #14018
Oasis's Avatar
Trader Rating: 36 (100%+)
Gear ratios for an R3 stock motor,Med track,Matrix Stock, GP 3300's.
I didn't say it was your fault, I said I was blaming you.
Oasis is offline   Reply With Quote
Old 03-13-2005, 12:01 PM   #14019
How many turns is the stock motor?
Old 03-13-2005, 12:40 PM   #14020
Crashmaster's Avatar
If its a 27 stock, I geared my Matrix V10T at 27/72 and it absolutely flew
Cheers
Crashmaster
Crashmaster is offline   Reply With Quote
Old 03-14-2005, 08:31 AM   #14021
Herminator's Avatar
Send a message via ICQ to Herminator
Originally posted by rc-zombies
Something left over from my Web Special that I sold a long while ago....
Anybody need a Square CF front bumper brace? In excellent like new condition. This part is highly sought after and no longer made..... $30.00 shipped.
Hey, have you still got this? I'll take it if you'll ship to the UK
Yes folks, I'm still around, although not raced since last October
Will be trying to do a few outdoor events this summer, probably all at Carlisle. Just starting to look at getting new tyres, motors, spares for the Cuda Old cells will have to do, I hope they're ok after not being used for so long
Herminator is offline   Reply With Quote
Old 03-14-2005, 03:13 PM   #14022
Gazza_D's Avatar
Send a message via Yahoo to Gazza_D
Blimey Herm, you've appeared out of hibernation at last!! Did kind of wonder where you had disappeared to.
Only Carlisle, get down to Halifax for the BRCA mod round in July. We got some Cudas going and should be a real hoot. Hope to even have something new to try there if Alex pull their finger out that is
You just doing 19 turn up there again????
l8r geezer
Oh.....by the way, how long did it take you to catch up on this thread??? not quite as long as in the old days eh
Gazza_D is offline   Reply With Quote
Old 03-18-2005, 07:59 PM   #14023
berger's Avatar
R/C Tech Charter Subscriber
Anyone got a medium/large sized tarmac track setup? Got the chance to get down to one of the TORC championship venues before it starts this year, its Ashby for you UK guys, its a fairly bumpy track in a bowl shaped area, so a few banked corners, ive been told that a tight front diff works well or a sp000l but not a one way. Anyone able to hook me up? Thanks. Will be running CS22's as its a control tyre, 22s or 27s, but as its freezing it will be 22s.
berger is offline   Reply With Quote
Old 03-19-2005, 05:26 AM   #14024
Herminator's Avatar
Yeah, didn't take long to read the couple of pages that were posted since I last looked. Boy things are slow here
Looking like I'll just do a few outdoor events this summer, nothing big, I'm probably pretty rusty.
I'll be running 19Turn again, especially since at Carlisle I won't be loosing much to the mods.
Gaz probably has some setups for you Berger, I have one for Carlisle that I like but it's with a one way and it's a smallish/medium track.
I'm after a good wheel/insirt combo for CS22's. Have used premounts up until now and I'm sure the insirt could be improved on with something a touch harder.
Old 03-19-2005, 07:29 AM   #14025
berger's Avatar
I think you can use the medium, medium hard or hard CS inserts and your choice of wheel if you are building them yourself, but i cant really afford to spend loads buying tyres and inserts to try.
WTB Alex Racing Barracuda R2 & R3 Funkymojo R/C Items: Wanted to Buy 3 02-03-2007 01:00 PM
alex racing barracuda con81 Electric On-Road 1 12-14-2005 03:36 AM
WTT: Alex Racing Barracuda R2 for PS2 AZ_Ron Other Items: For Sale/Trade or Wanted to Buy 0 02-13-2005 07:30 PM
Alex Racing Barracuda R3-New. rcracing1973 R/C Items: For Sale/Trade 9 04-11-2004 08:29 AM
Alex Racing Barracuda Bugs Bunny Singapore R/C Racers 6 01-22-2003 11:47 PM
