Alex Racing Barracuda R2 & R3 >
Old 03-03-2005, 08:28 AM
  #13996
RcMonk's Avatar
Yeah, that setup is pretty unique, Maybe with the new car I
won't need to bring a heat gun along on racedays.
Originally posted by wyd
I also would really like the new car getting the same
ball stud a arm mounting setup. I really like that
setup.
RcMonk is offline
Old 03-03-2005, 08:58 AM
  #13997
rc-zombies's Avatar
Something left over from my Web Special that I sold a long while ago....
Anybody need a Square CF front bumper brace? In excellent like new condition. This part is highly sought after and no longer made..... $30.00 shipped.
rc-zombies is offline
Old 03-03-2005, 02:27 PM
  #13998
JDM_DOHC_SiR's Avatar
Trader Rating: 31 (100%+)
WOW.. You still have one of them ... very nice item to have there
JDM_DOHC_SiR is offline
Old 03-03-2005, 04:28 PM
  #13999
wyd
Tech Legend
wyd's Avatar
Trader Rating: 51 (100%+)
wyd is offline
Old 03-03-2005, 04:40 PM
  #14000
Blaa who needs a heat gun when you have a Soldering sation to heat up the pivot balls
-Dave
Old 03-04-2005, 11:03 PM
  #14001
OVA
OVA's Avatar
Trader Rating: 82 (100%+)
Originally posted by JDM_DOHC_SiR
R2 or R3?? High or Low grip..
I have a few
Hi Dave
My ride is R2 and the traction is Med grip
OVA is offline
Old 03-06-2005, 01:33 PM
  #14002
tim fry's Avatar
Thumbs down Breakages
I keep breaking front hubs and knuckles even from small hits! Anyone got any tips other than don't hit things. Even my old Xray seemed stronger than this.
Tim
tim fry is offline
Old 03-06-2005, 02:20 PM
  #14003
Default Re: Breakages
Tim
Your using which ones the standard knuckles or the carbon ones.??
You could try giving the Xenon Alloy front C-hub a try
and use the non-carbon steering knuckles
-Dave
Old 03-06-2005, 02:23 PM
  #14004
tim fry's Avatar
I'm using standard parts at the moment and I've got some Xenon parts on order.
tim fry is offline
Old 03-06-2005, 02:28 PM
  #14005
That might fix part of the problem
-Dave
Old 03-07-2005, 06:57 AM
  #14006
berger's Avatar
I pulled a screw through the knuckle from the steering turnbuckle yesturday, was fixed with a longer screw and the same with the rear wishbones.
berger is offline
Old 03-08-2005, 01:40 PM
  #14007
Anyone tried the aluminium diff outdrives? It seems the soft diff rings are too soft ey. Have to try the hard ones and will let you know
dhiracing.com is offline
Old 03-08-2005, 08:15 PM
  #14008
Wink PAL 3mm R3 lower chassis
Hey guys PAL will be making a small lot of 3mm thick R3 chassis here this month for a Few Drivers .... if any of you might be interested in a chassis that will not break.... Post here
also on this chassis the servo will be moved forward 3mm...
I belive that 10 will be made and 5 are being used by Alex Japan Drivers the other 5.... well
-Dave
Old 03-08-2005, 09:24 PM
  #14009
StasI's Avatar
Default barracuda rc spool
hi guys i got a speedtech spool from steve 2 days ago and i think that the car is going to split something like universals or shafts i am running a 12 turn also when i turn hard left and right the car likes catches on the unversal join is this right im not new to this so help would be nice................thanks
StasI is offline
Old 03-10-2005, 06:56 PM
  #14010
Trader Rating: 27 (100%+)
Default help with rear toe in
Hi, i know that this has been asked before but i cant find where it is
I cant get the rear left toe to be anything more than 1 degree toe in i've tried offset balls front and rear and that didnt help...i've tried using standard pivot balls and that gave me maximum of 1 degree
it used to be fine...dont know why it's like this now all of a sudden
poop is offline
