Alex Racing Barracuda R2 & R3 >
Like Tree4Likes
Old 02-21-2005, 01:03 AM
  #13951
tim fry's Avatar
Hi all
Im having problems getting front and rear knuckles (UK importer is waiting for a delivery and speedtech are showing out of stock)
Are there any others that might fit?
Tim
tim fry is offline
Old 02-21-2005, 01:05 AM
  #13952
stjerno's Avatar
Originally posted by tim fry
Hi all
Tim
See 1-3 pages back .. I think Dave said something about PRO4 and TC4 parts fitting ..
stjerno is offline
Old 02-21-2005, 07:19 AM
  #13953
AZ_Ron's Avatar
Trader Rating: 16 (100%+)
hmmmm... I'd swear there weren't any spacers in them, but I wasn't specifically looking for them either... I'll redo them and see...
Thanks!
R
AZ_Ron is offline
Old 02-21-2005, 07:32 AM
  #13954
stjerno's Avatar
Thanks!
R
If you followed the manual you should have put a part #7 in there ..
Look at the picture from the manual..
stjerno is offline
Old 02-21-2005, 07:43 AM
  #13955
AZ_Ron's Avatar
I actually bought all of my Alex cars and parts from a guy in Atlanta, so the shocks were already built, I just dumped the oil, put the bleeder caps on, and then refilled them...didn't notice if there were spacers in there or not... I've got some rocket parts I need to machine up now, when I'm done I'll pull the shocks apart again and take a look at them a little closer...
Thanks for the input...
R
AZ_Ron is offline
Old 02-21-2005, 08:08 AM
  #13956
Turbonium's Avatar
Trader Rating: 27 (100%+)
Just got back from the carpet track... car is WAY better than last time... I converted it to the R3, wound up going to 60wt in the front, White springs on front and Red on rear. I'm running CRC orange/red's up front, and Jaco Purples in the rear.
I found I couldn't get more than about 3.5mm in ride height in the front... droop screws were worthless... I wound up moving the shock mounting point on the bottom to the inside hole, and Man, after all those changes, it's really come around... now if I can drive it to it's potential, I should do well... Only broke one steering arm today...
R
if you are running the R2 shocks, make sure that you have them at the right ends. the front and rear werent the same length...
i had switched mine to the TRF shocks when i last was running it, tho. cant remember which goes in front, long or short.
Turbonium is offline
Old 02-21-2005, 10:51 AM
  #13957
berger's Avatar
Just got the yokomo caps built on mine from steve, well ive done the rears and im doing the front now. But wow so smooth best shocks ive built yet, prefer them over the AE and Xray ones.
berger is offline
Old 02-23-2005, 09:24 PM
  #13958
OVA
OVA's Avatar
Trader Rating: 84 (100%+)
Originally posted by berger
Here we go, its not a million miles away from what ive got on at the moment so i could change it mid meeting if i have enough time Just have to check the diff tightness on each end.
My car is a missile currently, just need the setup taming so i can lay the power down even more.
why not use the front oneway diff?
OVA is offline
Old 02-23-2005, 10:44 PM
  #13959
AZ_Ron's Avatar
Hey Guys... are the steering arms on these things notoriously brittle, or am I just that big of a hack....actually, I think it's both... I'm very new to TC's, and road course in general, being maily an oval guy (did myself a diservice by sticking to oval)
I clip the corners quite a bit, but it seems like just tagging the corner lightly and the steering arm breaks! I broke 2 of them last weekend, and 4 tonight...
R
AZ_Ron is offline
Old 02-24-2005, 03:58 AM
  #13960
newnew's Avatar
hi
did u guys have an english manual or set up for the R2???
thanks
newnew is offline
Old 02-24-2005, 05:43 AM
  #13961
tim fry's Avatar
R
I had the same problem. If you use 12mm screws and file them down a tad so they're about 11 - 11.5mm then its much more secure. You have to file them down so they don't rub on the driveshafts as the original screws are 10 mm and not quite long emough.You can also put a little thread lock on them as they seem to come loose!
Tim
tim fry is offline
Old 02-24-2005, 06:54 AM
  #13962
RcMonk's Avatar
(did myself a diservice by sticking to oval) I clip the
R
The hard material arms are more brittle compared to the
regular material especially in colder weather. I would try
switching to the regular arms.
RcMonk is offline
Old 02-24-2005, 06:57 AM
  #13963
berger's Avatar
I am doing, its so so as the tracks fairly tight, its swings and roundabouts wether im doing to swap it for a diff or not.
berger is offline
Old 02-24-2005, 09:57 AM
  #13964
OVA
OVA's Avatar
Oh I understand.....I can't get the car to drive smooth like my x ray....the car is too hard to drive and is react too quick and no forgiving
OVA is offline
Old 02-24-2005, 12:14 PM
  #13965
berger's Avatar
Compared to my xray i prefer it, i think i had more transmission loss on the xray though, but it was easy to drive.
The thing with the xray is the easy to change differential tensions that i like.
On the barracuda i would redesign the E-Clips holding the outer hinge pins on.
berger is offline
