Alex Racing Barracuda R2 & R3 >
Old 02-19-2005, 01:47 PM
  #13936
Wink What is it
Originally posted by Tekin
No it's not the reciever, take A look at the other pictures and you'll notice that the reciever's placed on the servo and the ESC behind it.
I don't know for sure what it is, but I guess it's A (personal) transponder.
The item you are wondering about is a personal transponder made by a British company called M.R.T
Hope this helps,
By the way just got a r3 and have to say its gggrrreeeaaattt
wotcars is offline
Old 02-19-2005, 03:00 PM
  #13937
Thraex's Avatar
Thanks!
I hope it goes as fast as it looks
Post some pictures when you finished building it...
Thraex is offline
Old 02-19-2005, 04:30 PM
  #13938
AZ_Ron's Avatar
Trader Rating: 16 (100%+)
Just got back from the carpet track... car is WAY better than last time... I converted it to the R3, wound up going to 60wt in the front, White springs on front and Red on rear. I'm running CRC orange/red's up front, and Jaco Purples in the rear.
I found I couldn't get more than about 3.5mm in ride height in the front... droop screws were worthless... I wound up moving the shock mounting point on the bottom to the inside hole, and Man, after all those changes, it's really come around... now if I can drive it to it's potential, I should do well... Only broke one steering arm today...
R
AZ_Ron is offline
Old 02-19-2005, 05:38 PM
  #13939
berger's Avatar
You shouldnt be using your droop screws to set ride height, can you not adjust the shocks enough to get 4-5mm?
berger is offline
Old 02-19-2005, 05:46 PM
  #13940
AZ_Ron's Avatar
Once I moved the bottoms of the front shocks to the inner hole, I had enough room to adjust the shocks and get 5mm for ride height. I wasn't using the droop screws for ride height...just mentioning them as a reference.
I'm running the mid span arms, as I feel our track is a bit tight and technical... I may play with the long span setup and some point and see how it feels...
R
AZ_Ron is offline
Old 02-19-2005, 07:02 PM
  #13941
berger's Avatar
Anyone got a carpet setup using dual diffs and rubbers that i can use as a starter. My one way setup isnt too bad but it can be better, going to put a few more runs into it and see how it can improve then try a diff setup.
berger is offline
Old 02-19-2005, 07:12 PM
  #13942
JDM_DOHC_SiR's Avatar
Trader Rating: 31 (100%+)
THere are about 3 Carpet set ups posted about 30+ pages back that use dual diff`s and Rubber tires.... happy hunting
-Dave
JDM_DOHC_SiR is offline
Old 02-19-2005, 07:20 PM
  #13943
berger's Avatar
Lol i did try the search, tried "barracuda carpet setup" and didnt get that many, wish me look. Ill start looking!
berger is offline
Old 02-19-2005, 07:31 PM
  #13944
When you do find it link it to your next post so that others that want to run on carpet are not struggling
-Dave
Old 02-19-2005, 07:39 PM
  #13945
berger's Avatar
Here we go, its not a million miles away from what ive got on at the moment so i could change it mid meeting if i have enough time Just have to check the diff tightness on each end.
My car is a missile currently, just need the setup taming so i can lay the power down even more.
berger is offline
Old 02-20-2005, 11:29 AM
  #13946
Originally posted by RcMonk
Car looks great. See you got the alum diff outdrives on there too !! Is that green thing on the top deck a receiver pack ?
Wotcars is right, the green thing in my photos above, is a personal transponder we use here in Malta.
dhiracing.com is offline
Old 02-20-2005, 11:42 AM
  #13947
AZ_Ron's Avatar
Berger, what tires are you running? I've been unable to run 28mm foams on my cars with the standard hubs... are you trimming the inside edge of the tires/rims away? I'm much happier with mine now, but it can probably be a little better...
I'm currently running the PAL low profile hubs, but am building an R2 with the stock hubs and am wondering what you did...
Thanks!
R
AZ_Ron is offline
Old 02-20-2005, 11:43 AM
  #13948
berger's Avatar
Im not using foams, CS22 premounts. I have the alloy hubs on mine.
berger is offline
Old 02-20-2005, 11:57 AM
  #13949
AZ_Ron's Avatar
Ahhhhh... you're running rubber on carpet... gotcha... I might try it...see how it is compared to foams...
I have the tall (std) aluminum hubs for the R2, but have the low profile hubs for running foams on my R3...
R
AZ_Ron is offline
Old 02-21-2005, 12:07 AM
  #13950
stjerno's Avatar
Default Rideheight
R
Try to build your shocks without the internal spacer .. then you can get 8+ mm of ridehight
stjerno is offline
