Alex Racing Barracuda R2 & R3 >
Old 11-09-2004, 08:30 PM
  #13441
JDM_DOHC_SiR's Avatar
Trader Rating: 31 (100%+)
Default Re: ZS-501R Differential Outdrive Ring
Originally posted by COLEKO
Ok I just got mine in the mail today from yokomo. They are still in the package but I was wondering on how they stay on the diff. I noticed the holes on them and is that for glue or somthing or will they stay on them without using anything?
A little Shoo Goo or super glue...should work just fine
JDM_DOHC_SiR is offline
Old 11-09-2004, 08:32 PM
  #13442
wyd
Tech Legend
wyd's Avatar
Trader Rating: 51 (100%+)
They press on pretty tight so I don't do anything to keep them on. Just slide them on and your ready. If they are loose use a small dab of shoe goo to hold them on.
They will fit tight!!!!!!!
wyd is offline
Old 11-09-2004, 08:35 PM
  #13443
pumpkinfish's Avatar
I have the Yokomo MR-4BC Super Dogfighter 2 Special and it came with them. The directions said to apply a small amount of CA into the hole when it is lined up on the diff.
The only downside is when I have had a hard hit and the arm broke, I always pulled them off and had to look for them in the dirt!!! Yokomo never had a number on the website for replacements until recently. I thought they might have been cheaper given the size.
Check out this link for the directions from Yokomo's website, see page 3.
http://www.yokomousa.com/manuals/mrb...lement_eng.pdf
pumpkinfish is offline
Old 11-09-2004, 08:39 PM
  #13444
Thanks for the link...
-Dave
Old 11-09-2004, 08:48 PM
  #13445
COLEKO's Avatar
Thanks guys! Ill see how tight of a fit they are if anything shoegoo well be used
COLEKO is offline
Old 11-10-2004, 01:06 AM
  #13446
Trader Rating: 27 (100%+)
Default Re: R3 High Grip set up(no sway bars)
Originally posted by JDM_DOHC_SiR
Here ya go Poop
Rear
Rear Diff med~tight
-Dave
Hi Dave,
i tried your setup today and i must say that the cornering speed is FAST!!! turns in nice and holds the line relatively well (with a slight push mid and exit on power) off power steering is excellent and really responsive.
I do have a question though, when you say med-tight diff, approximately how many turns out from fully tightened? initially i was 1/8th out but the rear end was too tail happy...right now i'm at approximately 5/8 of a turn out from full tight and it tamed the rear end by a lot but to tame it totally, it will bleed too much power away and loose corner speed. is there another way to tame the sliding rear end? there is this bastard of a corner where i race where at the end of the main straight there's this tight little chicane leading into a 180 degree hair pin where my car really, really hates and this is where i'm mainly having problems. it doesnt like high speed off power direction changes. A lot of other cars are having trouble with this corner too but i just want to show them how good this car is (to prove that this car "works") that's why i really want it to handle well and pass them on that particular corner
any insight would be tried and appreciated
cheers mate.
poop is offline
Old 11-10-2004, 03:13 AM
  #13447
Default Re: Re: R3 High Grip set up(no sway bars)
Originally posted by poop
Hi Dave,
cheers mate.
Great News.. Glad that I was able to help you get started...... now for the fun part... fine tweeking the set up to work better for you..
so you need a bit more mid to exit on power steering....hmmm... Here is what you should try out..
#1) put a .5mm shim under the rear arm rear sus-arm balls.(anti-squat)
or
#2) put a .5mm shim under the front balls on the front sus-arms(more caster)
or
#3) move the front shock lower mount position to the out most hole on the a-arm or 70%
try any of these and it should fix your mid to exit on power push
-Dave
Old 11-10-2004, 03:21 AM
  #13448
Thumbs up OH yea
On the diff.. tighten it untill the diff doesn`t slip and then 1/4 turn on the diff screw to tighten it up just a tad
-Dave
Old 11-10-2004, 04:58 AM
  #13449
wyd
Tech Legend
wyd's Avatar
Dave can you move back to Maryland and help me setup my Cuda's!!!!!!
wyd is offline
Old 11-10-2004, 05:01 AM
  #13450
wyd
Tech Legend
wyd's Avatar
I'm getting my R3 Xenon Cuda ready for this weekend. I will put the servo in tonight and then wait for my new radio to arrive today or Thursday to finish it up. Still need to sweep the front a arms yet so I can get all the steering!!!!!!!!!!
wyd is offline
Old 11-10-2004, 12:26 PM
  #13451
You have got to be kidding...j/k... but I can come back once a year to MD..
-Dave
Old 11-10-2004, 12:28 PM
  #13452
stjerno's Avatar
-Dave
Ever consideret visiting Denmark ?
stjerno is offline
Old 11-10-2004, 01:12 PM
  #13453
Default Re: OH yea
-Dave
Dave, champion mate! thanks for all your help!
will give this a try later today
poop is offline
Old 11-10-2004, 01:14 PM
  #13454
Default Re: Re: OH yea
Let us know how it turns out for ya`
-Dave
Old 11-10-2004, 02:27 PM
  #13455
wyd
Tech Legend
wyd's Avatar
-Dave
Man you must really like it over their. Well I can see why as the R/C stuff hits Japan first anyways and you can get all the cool stuff!!!!!!!! Can't blame you at all.
wyd is offline
