Old 11-07-2004, 04:35 PM   #13381
Merciless's Avatar
Send a message via ICQ to Merciless
Guys i am aware that most set-ups usually have a harder spring up front, This is usually to tame the front of the car alittle though and i'm looking for more.
I also don't think our carpet produces the level of grip that you get else where. It's more of a felt type of surface than the ozite carpet and we also have some bumps to contend with.
I'm on 40wt all round, again well aware that a thicker oil up front would be normal but felt that the car is more responsive this way.
Merciless is offline   Reply With Quote
Old 11-07-2004, 04:39 PM   #13382
JDM_DOHC_SiR's Avatar
Trader Rating: 31 (100%+)
Originally posted by Merciless
Yes,
Sway bars
I've got the softer of the hardest set on the front and the harder of the medium set on the rear
I am also thinking harder springs as i am also scrubbing to much corner speed through the infield, But the last time i used Rayspeed Whites and the car just didn't feel good, sort of loose as if i had gone to hard but i was thinking of trying a red on the front white on the rear combo this week (Rayspeed springs) as i think the grip has picked up alittle more over the last couple of weeks.
I am only looking for alittle more really i can already run 2nd at the club but i'm averaging about .4/.5sec a lap of the pace i need to get to, which is too slow as i am.
I need the car to hold a tighter line while loosing less speed doing it a hard one i know
I also thought of leaving the springs as they are but adding a 1mm spacer under the rear wishbone mounts to loosen it abit.
The Red & White combo is nice for High Bite Asphalt.. but you might want to try Gray & Red...? and going to a High Rollcenter in the Rear might help... but I would start out in small sizes AKA .5mm because it has a huge on the way the car handles ... well at least with the Cuda..
-Dave
Ȼ4.5 Centro+α ◊ TRF 501ӽ ◊ TRF 502ӽs ◊ TRF 503 ◊ TRF 511 ◊ TRF 201ӽr ◊ TRF 211ӽ
B5m ◊ T5m ◊SC5m ◊ B64deez nutz
Speedway PAL ◊ SDRC ◊ Shop UFO ◊ SMC
JDM_DOHC_SiR is offline   Reply With Quote
Old 11-07-2004, 04:41 PM   #13383
Have you messed around with the pistion hole size yet.?? Try a HPI #1 or a 1.3mm pistion hole with one weight up in oil and see how you like that also
-Dave
Old 11-07-2004, 04:44 PM   #13384
Merciless's Avatar
-Dave
Sorry hpi 1 all round or just in the front ??
i know this affects the pack but just how do you think the 1 piston and say 50wt oil would change how it reacts now ?? pistons are a tunning aid i don't normally mess with
Old 11-07-2004, 04:52 PM   #13385
HPI #1's in all 4 shocks
I use to run the stock 1.1 pistion but it did not like the way the car reacted in the switch backs..( hard to discribe ) and after going to a 1.2mm and even 1.3mm on my R3 the car felt better IMO... just some food for thought
-Dave
Old 11-07-2004, 05:12 PM   #13386
wyd
Tech Legend
wyd's Avatar
Trader Rating: 50 (100%+)
Send a message via AIM to wyd
Dave sent ya new PM with a few questions!!!!!!
Brian
ST Racing Concepts (STRC)
Old 11-07-2004, 05:23 PM   #13387
Brian
back to ya with a few answers
Old 11-07-2004, 06:34 PM   #13388
wyd
Tech Legend
wyd's Avatar
Ok Dave I will have sent out via the EMS. I will let the wife know.
I think I will switch my stuff only the R2 chassis setup tis weekend. Also I think I have lined up a brand new R-1 Pro in the PCM version. I will be looking to get the new spectrum setup that Todd Hodge and Matt Francis run. Should be out really soon and never have a radio conflict again.
Old 11-07-2004, 06:37 PM   #13389
Thanks!!!!!!!! .... and try out the R2 Xenon again when you can
-Dave
Old 11-07-2004, 07:16 PM   #13390
MikeR's Avatar
Trader Rating: 15 (100%+)
Are you converting the R3 to an R2 or do you just have both versions?
I think i need to get a new cuda or something soon. The parts are starting to wear out fast after a year and a half of driving this car. Raced a club race where I was able to TQ and win the Spec Mod class yesterday but the car felt a little quirky. Spent some time giving the car the once over that night and found the rear diff bearings (ceramics) were seized and was locked up like bushings in the rear bulkheads- not good Even so the car was still ballistic, just felt like it had a little extra drag brake
www.exotekracing.com ☆ASSOCIATED☆DURANGO☆HPI☆HB RACING☆KYOSHO☆LOSI/TLR☆SERPENT☆TAMIYA☆TEKNO☆XRAY☆
A picture with your post, when trouble shooting, will probably get more rctech help than without...
MikeR is offline   Reply With Quote
Old 11-07-2004, 08:00 PM   #13391
MikeR's Avatar
Hey Dave- quick question. Do you still happen to have a link or image of the 'rainbow of anodising' you used to post. It was where it showed all of the anodising colors available I think from Alex Racing.
Old 11-07-2004, 08:04 PM   #13392
wyd
Tech Legend
wyd's Avatar
Well I have enough parts to put my R2 back together. I have all of my trick parts on my R3 though. Ceramic bearings ( 4 runs on them),, all new hardened midspans and just put on the Speedway pal stuff. I'm not sure how I'm going to do it yet. Problem is if I sell my Cuda stuff I will take a beating with all the stuff I have bought in the last 2 months for it. I have a ton of spares.
Old 11-07-2004, 08:11 PM   #13393
Let me see if I can post a pic of it later tonight.
-Dave
Old 11-07-2004, 08:40 PM   #13394
RcMonk's Avatar
Thinking about switching cars again ?
RcMonk is offline   Reply With Quote
Old 11-07-2004, 09:09 PM   #13395
wyd
Tech Legend
wyd's Avatar
Yea but this wouldn't true be like switching cars!!!!!!!!! Its still a Cuda.
WTB Alex Racing Barracuda R2 & R3 Funkymojo R/C Items: Wanted to Buy 3 02-03-2007 01:00 PM
alex racing barracuda con81 Electric On-Road 1 12-14-2005 03:36 AM
WTT: Alex Racing Barracuda R2 for PS2 AZ_Ron Other Items: For Sale/Trade or Wanted to Buy 0 02-13-2005 07:30 PM
Alex Racing Barracuda R3-New. rcracing1973 R/C Items: For Sale/Trade 9 04-11-2004 08:29 AM
Alex Racing Barracuda Bugs Bunny Singapore R/C Racers 6 01-22-2003 11:47 PM
