Alex Racing Barracuda R2 & R3
Re: Project Barracuda R3 LOLA style
Originally posted by Lotus111
Just want to show you my new project
http://www.mypage.bluewin.ch/Combat-wing
1.Step geht the Body on the Chassis => Done
2.Get a Brushless system => open task
3.Get Li-Po Batteries 11,4V => open task
4. Go out and kill the gas cars
Ive want to get my Shocktower even lower then on the Pictures shown on my Page, Problem is the Barracuda Shocks are to long , do you remember any shorter schocks on the Market?
Roger
Re: Re: long span arms
Originally posted by JDM_DOHC_SiR
I can help you make these people Eat Crow let me know what type of surface you run on and what version of Barracuda R2 or R3... but the issue with the chassis and the ripped out ballstud??? that might be grounds for a new chassis in my book...anyways.. lt me know what you have and we can go from there
-Dave
-Dave
i race on a high grip asphalt surface that is tight and technical using rubbers. I have the R3 black chassis with pal steering rack, aluminium shaft holders front and rear, center one way, two sets of offset balls, full sway bar kit. it's shimmed relatively good (can surely be better as it's not as free as your- spin for 15+ sec drivetrain) and it's quiet. i'm running a ko vfs1 speedie trying out a few profiles for 27T stock. there's nothing wrong with the acceleration of this car and it's top speed as i can see that it just accelerates like a bullet compared with others, it's the handling that letting me down
it really doesnt like rapid weight transfer as it'll swing the rear end around faster than anything!
my set up right now:
kit pistons with 35wt front 25wt rear
no stabilizer bars installed (yet)
1 deg camber all round
kit mount position of shock on arms and tower
0 toe front
2.5 toe in rear
5mm ride height F and R
kit springs (i have yokomo springs but still using kit ones)
camber links all on the outer most hole on top deck and on the bottom hole on the hubs
2mm droop all round
thanks mate!
- Karl.
Re: long span arms
What! They think the Cuda doesn't work? Haha- good one, hope you show them all. Dave will get you a good set up
Long span arm is great for big flowing high speed tracks. Some people say the mid span car makes your car snapier which makes sense since on tight tracks the car feels like it pushes unless you mod the c-hubs to allow more steering throw. I would stick with matched front and rear lengths until you get very familier with the Cuda. There are a lot of reasons to use adjustable balls up front but the only 2 reasons i use them is that they are stronger and I can fine tune the freeness of the arm (sometimes you get an arm that sits too tight and so doesn't move up and down freely- twist the brass ball just slightly and it'll free up the arm)
BTW- What car did you used to drive?
Originally posted by poop
Thanks for the reply guys about the long span arms. I was still a bit too lazy to try them out over the mid spans but last night i had a really bad crash and ripped the pivot ball off the chassis now there's a corner taken off my chassis and i cant use mid spans anymore
i guess this is a 'sign' to tell me to go long spans...*sigh
i was wondering the effects of running long in rear and mid up front. any one know? also, when using long span, which camber link position to use on the top deck? should i just go back to long spans all round?
another question that has been puzzling me is that i see people (on the net) use offset sus balls up front. what are the effects of adding toe in or out on the arms coupled with the toe that is set via the steering knuckles?
I really want to get this car going really, really well as many people have told me that this car doesn't work. It makes me want to beat them even more
Re: Re: Re: long span arms
What tires and inserts and how hot does the track get? Also what body?
Thanks Dave!
0 toe front
2.5 toe in rear
2mm droop all round
thanks mate!
- Karl.
Thanks Dave!
0 toe front
2.5 toe in rear
2mm droop all round
thanks mate!
- Karl.
Tech Legend
Trader Rating: 51 (100%+)
Ok I hope this picture of my R3 looks a little better. I now have all my hopups on and I have my shocks done with the Yoke caps.
Tech Legend
One with my newest body on.
Re: Re: Re: Re: long span arms
I'm using sorex 28R and sorex A firm inserts. track doesnt get too hot because it's indoors.
cheers mate.
Re: Re: Re: Re: Re: long span arms
Thanks for your reply mike,
cheers mate.
cheers mate.
Although that is what I think is the main problem for you, since this is a new car for you, there still may be other things to still sort out on your car. I would try 1mm less droop in back compared to the front, double and then triple check that the suspension moves freely with the shocks off, moving the front/top shock to the furthest out and running with no one-way until you are more familiar with the car.
Best,
Mike
Tech Legend
Disco is back! Car looks great. Looks like you finely got your alloy steering rack... watch out!
Re: Re: Re: Re: Re: Re: long span arms
Ah ha- that's what i thought when you said high grip asphalt. Your tires are most likely overheating.
i'm pretty sure it's not the tyres as all the other good racers are using this combo plus the car actually gets better as more heat get's into the tyres.
Dave,
any help you can throw my way to shut those guys up and beat them convincingly?
cheers.
Re: Re: Re: Re: Re: Re: Re: long span arms
Dave,
cheers.
Dave,
cheers.
-Dave
I can't argue with that
Hi Mike,
Dave,
cheers.
Hi Mike,
Dave,
cheers.
Re: Re: Re: Re: Re: Re: Re: Re: long span arms
Now that I know what type of track surface... I can post a set up that is pretty easy to drive and has very good corner speed!!
-Dave
-Dave
would it be beneficial to go with pal or xenon hubs and then the drop down camber links? would this improve handling by a lot?
R3 High Grip set up(no sway bars)
Here ya go Poop
Front
Front One way
Oil AE 35W
1.2mm pistion
1.5x600 spring
Mid Span sus arm
Lower hole on c-hub(5deg)
Outermost hole on upper deck for camber link
shock on outer most hole on shock tower & 60% or inner hole on sus arm
toe 0deg @ wheels
Sus arm toe out (as much as you can get )you`ll need offset sus balls for this..the front a-arms when looking down at them should look like this \ /..as much as possible
Camber 1deg
4.5mm ride height
3.5mm rebound/droop
Steering Rack inner holes for linkage and short/fwd hole on knuckle
Rear
Rear Diff med~tight
Oil AE 30W
1.2mm pistion
1.5x700 spring
Mid Span sus arm
Upper hole on rear hub
Shock on outer most hole on shock tower & 70% or second hole in on sus arm
toe in 2.5 deg
camber 1.5 deg
4.8~5mm ride height
4.5mm rebound/droop
This set up can work with both mid span or long span sus arms..all you have to do is change the upper camber link mount from the outermost hole to the middle hole on the upper deck.. so if the track grip goes away switch to the long span
I also would recomend using a nutral body..AKA Dodge 2.0 and try to stick with a Med inner...Xenon Green or Xenon X-Black..and you should be on your way to having a very fast cornering easy driving Barracuda
Good Luck
-Dave
Front
Front One way
Oil AE 35W
1.2mm pistion
1.5x600 spring
Mid Span sus arm
toe 0deg @ wheels
Camber 1deg
4.5mm ride height
3.5mm rebound/droop
Rear
Rear Diff med~tight
Oil AE 30W
1.2mm pistion
1.5x700 spring
Mid Span sus arm
toe in 2.5 deg
camber 1.5 deg
4.8~5mm ride height
4.5mm rebound/droop
Good Luck
-Dave
