Alex Racing Barracuda R2 & R3 >
Old 11-02-2004, 06:35 PM
  #13306
wyd
Tech Legend
wyd's Avatar
Trader Rating: 51 (100%+)
Poop the easiest way to get those ball studs out is to use a heat gun and heat up the area around the studd and carefully use some nice pliers and pull them out. As long as they are heated up you shouldn't have any problems.
Are you running the stock steering rack on your R3 are did you get the Speedway Pal version that gives you more steering?
wyd is offline
Old 11-02-2004, 09:16 PM
  #13307
chappi's Avatar
Trader Rating: 17 (95%+)
Default tell me why.....
Originally posted by Lotus111
Hi, I just see that the have mounted the ball studs upside down. cool idee need to try that one out. I can save the money for the spezial wrench
Just curious.. What is the benfit to mount the ball studs upside down for the A arms??
chappi is offline
Old 11-03-2004, 12:35 AM
  #13308
stjerno's Avatar
Default Re: tell me why.....
Easier to put a wrench on the studs when they are upside down..
BUT .. to everyone considering this ... the surface between the bottom and the studs will be a lot less when they are upside down and you might rip your bottom if you hit something.. !!
stjerno is offline
Old 11-03-2004, 12:43 AM
  #13309
SpeedTech's Avatar
upside down ball stud in the suspension arm also lowers the roll center a bit more.
Steve Wang
SpeedTech is offline
Old 11-03-2004, 01:06 AM
  #13310
chappi's Avatar
Default Re: Re: tell me why.....
What is a wrench? can you show me
chappi is offline
Old 11-03-2004, 03:17 AM
  #13311
TC3
TC3's Avatar
Steve Wang
that's it
if u wanna try it, leave the ballstuds on, and just switch the right a-arm to the left side. the left and right a-arms are the same.
TC3 is offline
Old 11-03-2004, 02:44 PM
  #13312
Merciless's Avatar
weekends nearly here
Merciless is offline
Old 11-03-2004, 02:54 PM
  #13313
Gazza_D's Avatar
What you cant see from the picture is that they have some small conical washers under the ball stud to keep the roll centre the same.
So if you run this way here's another easy to change tuning option. Providing you have the conical washers to prevent the arm fouling on the ball stud ofcourse
Hopefully there should be some more news on Alex Racing products very soon........ Dave have you got any further info
may have to do some digging myself at the weekend too
Gazza_D is offline
Old 11-03-2004, 05:50 PM
  #13314
wyd
Tech Legend
wyd's Avatar
Well I'm starting to put all my new stuff on my Cuda plus something new to help keep the delrin diff halfs nice. A little trick I would like to thank Dave for!!!!!!!!!! I'm putting my ceramic bearings in and man are they smooth. When done the car will be like a totally different ride.
wyd is offline
Old 11-03-2004, 11:40 PM
  #13315
Mr. MR4's Avatar
wyd,
you will notice the difference with the carbide balls - they are worth the money spent they require much less maintenance than the normal ones
Mr. MR4 is offline
Old 11-04-2004, 01:03 AM
  #13316
JDM_DOHC_SiR's Avatar
Trader Rating: 31 (100%+)
Just show us a pic when you get it all done
-Dave
JDM_DOHC_SiR is offline
Old 11-04-2004, 05:18 AM
  #13317
wyd
Tech Legend
wyd's Avatar
-Dave
I hope to get her done after I get home from work. SHould have pics tonight.
wyd is offline
Old 11-04-2004, 09:15 AM
  #13318
Crashmaster's Avatar
Hi guys,
Does anyone have any idea what the part number for the 3M glass fibre tape is??
Wouldn't mind seeing this trick myself wyd.....
Cheers
Dan
Crashmaster is offline
Old 11-04-2004, 01:30 PM
  #13319
BlueisBetter's Avatar
yeah com on dude share
BlueisBetter is offline
Old 11-04-2004, 01:38 PM
  #13320
Lotus111's Avatar
Default Project Barracuda R3 LOLA style
Just want to show you my new project
http://www.mypage.bluewin.ch/Combat-wing
1.Step geht the Body on the Chassis => Done
2.Get a Brushless system => open task
3.Get Li-Po Batteries 11,4V => open task
4. Go out and kill the gas cars
Lotus111 is offline
