Alex Racing Barracuda R2 & R3 >
Like Tree4Likes
Old 10-27-2004, 03:21 AM
  #13231
JDM_DOHC_SiR's Avatar
Trader Rating: 31 (100%+)
Default Re: Re: Re: Barracuda R4
Originally posted by utieh
that's almost what I wanted to hear
Thanks.
Gilles
OK I just found out the deal with the Xenon Belt conversion... ... The design has been finished by "PAL"... but there was no time to get a couple of prototypes built up before the worlds.. So Xenon has dropped the Belt Barracuda ...Sorry for the bad news guys...
-Dave
JDM_DOHC_SiR is offline
Old 10-27-2004, 03:50 AM
  #13232
stjerno's Avatar
Default Re: Re: Re: Re: Barracuda R4
-Dave
Not your fault .. but we'll expect more accurate info from you in the future .. JK
So PAL is talking up the design .. then we could expect a Belt conversion ?
stjerno is offline
Old 10-27-2004, 03:58 AM
  #13233
Default Re: Re: Re: Re: Re: Barracuda R4
Umm OK
Anyways PAL has always been behind "ALL" Xenons conversion hits and they will not produce any belt conversions... the R4 seems to be right around the corner..?? ....who knows..
-Dave
Old 10-27-2004, 05:11 AM
  #13234
TC3
TC3's Avatar
Default Re: Re: Re: Re: Re: Re: Barracuda R4
-Dave
what car will be used at the worlds than?
i hope we will see some pics of Hideo Kitazawa's car !!
TC3 is offline
Old 10-27-2004, 05:59 AM
  #13235
wyd
Tech Legend
wyd's Avatar
Trader Rating: 51 (100%+)
Oh damn that means I will be buying another Cuda R4 down the road. Hope when they make it that alot of my R2 and R3 stuff fits as I have a ton of stuff for the Cuda's.
I would think the R4 would have the new Alex racing low profile hubs and a maybe a few other minor changes like the steering rack!!!
Brian
wyd is offline
Old 10-27-2004, 06:50 AM
  #13236
GTO2's Avatar
the more i look at the belt conversion, the more it reminds me of the Yok MR4TC SP gen. It wasn't a pleasant memory
IF there is an R4, hope it stays shaft.
GTO2 is offline
Old 10-27-2004, 07:21 AM
  #13237
stjerno's Avatar
Brian
All you describe looks like the R3S ..
I would like to see something like more steering throw and maybe both up'n down stops -
Anyway it comes out I'm proberly going to get me the R4 when it comes out and right now I can't figure out if I "need" a black R3S
stjerno is offline
Old 10-27-2004, 07:46 AM
  #13238
wyd
Tech Legend
wyd's Avatar
Yes more steering throw is a must have!!!!!!!!!! and also the ability to run 28mm wide tires would also be nice so I can run foam tires easily!!!!!!!! I would also want it to be shaft drive as well. I think the R3 setup of the shaft drive is very free and super smooth so I would want that to stay as well. I'm also a fan of the way the A arms are mounted to the chassis thru the pillow balls and uses no hinge pins.
wyd is offline
Old 10-27-2004, 02:33 PM
  #13239
Default Re: Re: Re: Re: Re: Re: Re: Barracuda R4
All of the ALEX/Xenon Drivers will be using the R3...... but modified a little bit
Old 10-27-2004, 03:27 PM
  #13240
wyd
Tech Legend
wyd's Avatar
I hope we get some pics of their cars and close ups at that!!!!! The more pics the better. I'm tires of always seeing the same damn cars in the mags all the time.
wyd is offline
Old 10-28-2004, 10:40 AM
  #13241
Crashmaster's Avatar
Hi guys,
Been out running my TrioX today (been too long ), and I was messing around with the setup. I was playing around trying to dial out the understeer, and I found that by standing up the front shocks more, I got more steering. Is this normal?????
Would this mean that if I drop the rear shcoks down, I would get more steering, b/c I still get abit of understeer which is hampering me abit.
Thanks for the help guys
Dan
Crashmaster is offline
Old 10-28-2004, 11:36 AM
  #13242
Hebiki's Avatar
Trader Rating: 26 (100%+)
id definitely come back to my barracuda roots if they got rid of the steering rack. i liked the steering on the R2 much better.
Hebiki is offline
Old 10-28-2004, 12:46 PM
  #13243
Originally posted by Crashmaster
Hi guys,
Dan
The rest of my setup:
Front:
60Wt oil
2 no. pistons
-1.5 camber
1.4x6 springs
Shocks on outer most hole, inner hole on bottom
Rear:
40Wt oil
2 no. pistons
-1.5 camber
1.4x6 springs
Shocks one whole down, outer most on the bottom
Cheers
Dan
Old 10-28-2004, 01:33 PM
  #13244
OVA
OVA's Avatar
Trader Rating: 84 (100%+)
Default Re: Re: Re: Re: Re: Re: Re: Re: Barracuda R4
modified what
OVA is offline
Old 10-28-2004, 01:35 PM
  #13245
OVA
OVA's Avatar
Front:
60Wt oil
2 no. pistons
-1.5 camber
1.4x6 springs
Rear:
40Wt oil
2 no. pistons
-1.5 camber
1.4x6 springs
Cheers
Dan
this set up for carpet?
OVA is offline
