Old 06-26-2003, 06:27 AM   #1306
Regional Moderator
R/C Tech Charter Subscriber
Originally posted by MikeR
Nice
Who makes the beefy top plate?
Herm said it right there parts made from Flap.
Ko Racer is offline   Reply With Quote
Old 06-26-2003, 06:31 AM   #1307
Regional Moderator
Originally posted by Randman
I am going to pick up an R2 from Speedtech as soon as Steve gets back from the nats. Going to see if he can get me a red kit soon. Are there any parts on the car I should upgrade right out of the box? What manufacturers make aftermarket parts for the car, please post websites if you have them. I am going to read this thread back a few pages to try and pick up some more info, but any tips or tricks are appreciated!
I would get 2 upper shaft holders to start. as far as manufacturers
JDM_DOHC_SiR as them posted all the time in his post just click on one as excel,square,xenon,speedwaypal,clubK&K,etc......
Old 06-26-2003, 07:51 AM   #1308
JDM_DOHC_SiR's Avatar
Trader Rating: 31 (100%+)
Ko is right....I have a few that I will add to my signature that are not it it later....
Ȼ4.5 Centro+α ◊ TRF 501ӽ ◊ TRF 502ӽs ◊ TRF 503 ◊ TRF 511 ◊ TRF 201ӽr ◊ TRF 211ӽ
B5m ◊ T5m ◊SC5m ◊ B64deez nutz
Speedway PAL ◊ SDRC ◊ Shop UFO ◊ SMC
JDM_DOHC_SiR is offline   Reply With Quote
Old 06-26-2003, 07:52 AM   #1309
jpn
jpn's Avatar
Default R2 box stock
I plan on getting a new kit. I considered the R2 but was
discouraged after knowing it needed so much hop ups.
The FTC3, Surikarn Evo3 are competitve out of the box.
Are these hop ups really necessary for the R2 to match
FTC3 and Evo3 out of the box? Or are the hop ups available
just for show? Does the R2 have a chronic problem
box stock ( like the Evo3...front one way gear...FTC3...weak
arms...SD3...universals )
Pls. advice....tnx
www.casarosario.net
HIROBO EAGLE3 SWM Y.S.91 SR - HIROBO Freya EX2 Y.S.91 SR - HIROBO Turbulence D3 90 O.S.91HZ - HIROBO LEPTON - ALIGN Trex 600N PRO Novarossi C50-H2 - COPTER X V2 - Futaba 12MZH
jpn is offline   Reply With Quote
Old 06-26-2003, 08:22 AM   #1310
Default Re: R2 box stock
Pls. advice....tnx
THe R2 is built like a tank...it can withstand more abuse than a TC-3 or a EvoIII any day of the week......also the only thinks that you might need would be the alloy front and rear center shaft holders thats it... you would still be better of that you would with a TC-3 or EVOIII
just my 2 bits but.... just ask the other users here
-Dave
Old 06-26-2003, 08:52 AM   #1311
Randy Caster's Avatar
Trader Rating: 46 (100%+)
I already had the alloy shaft holders in mind, but are there any other parts I should look at right when I get the kit?
Old 06-26-2003, 08:59 AM   #1312
Nope ...just try the kit out and see what you need for it...after you drive if for the 1st time...
-Dave
Old 06-26-2003, 09:16 AM   #1313
Herminator's Avatar
Send a message via ICQ to Herminator
I would say spur gears are the achilies heal of the cuda but thats easily fixed. Unlike other kits where you're likely to break things like suspension arms and keep breaking them until a major design change comes along. The barracuda itself is incredibly strong, I don't crash a lot, now , but I have had a few at my club events due to a lack of rostrum and me trying to clip corners dots I can't see properly not a pretty site at full speed when your car goes summersualting half way down the striaght and then into some bushes. Nothing broken at all, my shell on the other hand is looking very rough now I managed to tear it at the front in the middle of the shell, not near an edge I think that was the head on with a wooden fence post
Herminator is offline   Reply With Quote
Old 06-26-2003, 09:19 AM   #1314
The durability aspect of the Cuda is one of the reasons I really like it. I am planning on building the car to be run mainly in stock classes, which seems to be what it's good at. I am also going to get the Speedway PAL system for it, as that seems like it will help in the fight against chewing spur gears, especially since I like to run 64 pitch.
Old 06-26-2003, 10:08 AM   #1315
MikeR's Avatar
Trader Rating: 15 (100%+)
Pls. advice....tnx
Why does this question keep coming about the Cuda needing hopups?? The Cuda doesn't need ANY hopups to be competitive- just look at the results at Reedy where Dave Bergers car was pretty much box stock- including the shock springs! Dave installed the alloy shaft carriers true but they cost the same as the optional Yoke SD oneway and everybody knows oneways are a must to keep the motor from overheating. My car has the stock drive system and stock shaft carrier and has no problem taking wins in prostock. Don't forget- the TC3 didn't make the non factory A-mains at Reedy and the Surikarn will cost $400 anyway.
MikeR is offline   Reply With Quote
Old 06-26-2003, 12:57 PM   #1316
Default changing spur gear
I'm considering getting a cuda and have some questions. How easy/hard is it to change out the spur gear? How many screws to remove and how much time?
Also, it seems like a lot of people aren't running with the dust covers. Are extra parts needed to remove them?
TIA!
Headbanger is offline   Reply With Quote
Old 06-26-2003, 01:09 PM   #1317
Herminator's Avatar
Default Re: changing spur gear
It's not easy to change, like most shaft drive cars. How much work it requires depends on if you use the diff covers or not. Without the covers you could just remove the topdeck and get access, maybe dismantle the shaft a little to make things easier to manouver. With the sheilds on you need to remove them too which means removing the shock towers, I'm also thinking you could just remove the top deck screws at the rear, then remove the lower bulkhead screws at the rear, remove the two rear most pivot balls screws so the rear suspension arms will rotate forwards a bit, then you can slide the rear diff/bulkhead assembly out backwards, pulling the shaft out of the small bevel gear as you go, which leaves access to the spur, I've never actually done it like that yet though.
Then there are different ways if you have the Speedway PAL drive system, with that and no diff sheilds it would probably be quickest.
Old 06-26-2003, 01:31 PM   #1318
highwayman's Avatar
JPN: All the guys are correct, you don't need to hop up the R2. Check out FATBOY JOE's Barracuda this Saturday at ROCKWELL. Watch how it will run, box stock.
highwayman is offline   Reply With Quote
Old 06-26-2003, 07:10 PM   #1319
stonedgti's Avatar
You guys are saying that the Cuda is built like a tank, but are indicating that the stock spur setup might chew up gears. Is that why you need the Pal system? Would it chew up gears if you don't have the Pal system in place? Also, what does the Pal system really do to improve the car?
Team Powers | ORCA | OD 12 Racing | NorCal Hobbies | JWerks | Sonic Racing | Team Gayzer | AYO Racing | Team Hastings | Uncle Larry Concepts | Moonlight Toys
stonedgti is offline   Reply With Quote
Old 06-26-2003, 07:16 PM   #1320
I'm trying to figure out how important the PAL system is as well. I am definately getting a Cuda when Steve gets back, but I really want to know what to order with it.
WTB Alex Racing Barracuda R2 & R3 Funkymojo R/C Items: Wanted to Buy 3 02-03-2007 01:00 PM
alex racing barracuda con81 Electric On-Road 1 12-14-2005 03:36 AM
WTT: Alex Racing Barracuda R2 for PS2 AZ_Ron Other Items: For Sale/Trade or Wanted to Buy 0 02-13-2005 07:30 PM
Alex Racing Barracuda R3-New. rcracing1973 R/C Items: For Sale/Trade 9 04-11-2004 08:29 AM
Alex Racing Barracuda Bugs Bunny Singapore R/C Racers 6 01-22-2003 11:47 PM
