Old 10-03-2004, 06:54 PM   #12946
wyd
Tech Legend
wyd's Avatar
Trader Rating: 50 (100%+)
Send a message via AIM to wyd
pumkinfish did that picture I posted help you out?
That Cuda is nice but not as nice as a blue one!!!!!!!!
ST Racing Concepts (STRC)
Old 10-03-2004, 07:07 PM   #12947
chappi's Avatar
Trader Rating: 17 (95%+)
Originally posted by pumpkinfish
Chappi,
He, like most of us, is using the mid-span arms. The wheels will still sit the same distance from the chassis, but the mid-span arms change the physics of the pivot point and the roll center. From the Xray website:
so this mean , the Mid-Span arms is shorter then the original arms, am i right!?
chappi is offline   Reply With Quote
Old 10-03-2004, 08:39 PM   #12948
JDM_DOHC_SiR's Avatar
Trader Rating: 31 (100%+)
Yes Shorter...
3 types of arms you can get for the Cuda
Long
Middle
Short(made by PAL for the R1..but can work on the R2/3 with a few modifications )
-Dave
Ȼ4.5 Centro+α ◊ TRF 501ӽ ◊ TRF 502ӽs ◊ TRF 503 ◊ TRF 511 ◊ TRF 201ӽr ◊ TRF 211ӽ
B5m ◊ T5m ◊SC5m ◊ B64deez nutz
Speedway PAL ◊ SDRC ◊ Shop UFO ◊ SMC
JDM_DOHC_SiR is offline   Reply With Quote
Old 10-03-2004, 09:12 PM   #12949
pumpkinfish's Avatar
Wyd they helped a bunch. I put the front ball with the line on the inside and the rears with the line on the outside. I then flipped the carriers so the R is on the L and vice-versa. Correct?
I like the orange and the pink colors because they are different. I would like to see a car done in yellow. It could be cool if it doesn't look to gold-ish in color. I have seen a Losi in green.
Yokomo YZ-2, B-Max4 III
Kyosho RT6
Losi 22b, XX4 Worlds
Associated SC10.2, RC10B2, RC10T2, RC10
pumpkinfish is offline   Reply With Quote
Old 10-03-2004, 09:15 PM   #12950
wyd
Tech Legend
wyd's Avatar
That is right. I will be at DC in a few weeks so I will let you know when I'm coming down. Not saying my car will work but you can look at my setup.
If you take a RPM camber gauge and set your car straight up and downyou will see it should read about 1 degree of toe in for you. If you need better pics let me know.
Brian
Old 10-04-2004, 01:08 AM   #12951
Merciless's Avatar
Send a message via ICQ to Merciless
Merciless,
On the photo (bottom) you shown, I saw you mount your A-arms on the outer screw hole instead the inner hole (as the manuel show), Can you tell me the benfit of doing this??
also, the A-arm that you mount on the outer screw hole, is it the original A-arm (stock one from the kit )?? if so, do you need to modify or replace any tunbucles to make it works??
I am new to my R3, so hopefully you dont mind explain this to me!?
Yes there the MID span arms
Used for the reasons everyone else on here is stating
Sorry for the delay in getting back to you
Merciless is offline   Reply With Quote
Old 10-04-2004, 03:25 AM   #12952
stjerno's Avatar
Originally posted by JDM_DOHC_SiR
New Collectors edition R3 Barracuda pic's... .... hmmmm I wonder who had there bulkheads done like this before Alex Racing ....
-Dave
All I need is the Pal Rack and it's it fully loaded
Gotcha get me onee .. IN BLACK BLACK
Dave- U know if it come with all 3 stabilizers ?
stjerno is offline   Reply With Quote
Old 10-04-2004, 04:05 AM   #12953
National Championship Round 1, 2 & 3 in Malta (Europe)
Xenon Converted R2s or R3s won the DHI Cup (with Xenon 23T Gold Dot Controlled Motor) and all Super Stock Races (with Corally 21T Controlled Motor)
From three races in the Open Modified Class, our best results were 2nd, 2nd and 1st
(Drivers over here are competing mainly with Associated TC3s, Yokomos and Barracudas now)
dhiracing.com is offline   Reply With Quote
Old 10-04-2004, 04:08 AM   #12954
stjerno's Avatar
Way to go
Old 10-04-2004, 04:39 AM   #12955
Not quite sure...but I think it does...
and you have a PM
-Dave
Old 10-04-2004, 04:41 AM   #12956
Thats some great news!!!
-Dave
Old 10-04-2004, 04:46 AM   #12957
Herminator's Avatar
Send a message via ICQ to Herminator
Originally posted by Merciless
You've cut the top deck up NOT REALLY WEIRD as it allows me to have much better angles on the top links
As for stiffness/rigidity i got the alloy center shaft holders/bulkhead braces, So with the 4 screws holding them down you tell me how it going to be less rigid think about it !!! the cuda isn't designed like other cars that was the only reason i could do it !!! (it's a mod i can't believe someone else hasn't tried before, but without the alloy braces it simiply wouldn't be possible because of flex which my car does not !!!!)
Sorry but i'll mention this one last time for everyone i AIN'T splitting up my car.....IF someone wants it great, if not GREAT too i said i was THINKING about swapping it in and that exactly what i meant. If i'm offered something sensible for it i'll let her go, if not i'll happily race it still or simply buy another car.....
The bulkheads will be fine but I'm thinking about the top deck itself, it is held on now at each end with only two screws and it doesn't sit on much of a flat surface. It's like grabing the very end of a ruler with a couple of fingers rather than grabbing it with your fist.
I did 'think about it!!'
Herminator is offline   Reply With Quote
Old 10-04-2004, 04:50 AM   #12958
Herminator's Avatar
-Dave
Now thats a better solution to the turnbuckle angle "issue"
I'm not sure I like the plain graphite though, looks like a HPI Sport 2 type material... and they still have those annoying two slots for cells on the motor side
Old 10-04-2004, 05:01 AM   #12959
The design that will be made by BMI should fix that issue
Old 10-04-2004, 05:05 AM   #12960
stjerno's Avatar
Dave- do you have any ide on the timeframe and price for the BMI parts ?
WTB Alex Racing Barracuda R2 & R3 Funkymojo R/C Items: Wanted to Buy 3 02-03-2007 01:00 PM
alex racing barracuda con81 Electric On-Road 1 12-14-2005 03:36 AM
WTT: Alex Racing Barracuda R2 for PS2 AZ_Ron Other Items: For Sale/Trade or Wanted to Buy 0 02-13-2005 07:30 PM
Alex Racing Barracuda R3-New. rcracing1973 R/C Items: For Sale/Trade 9 04-11-2004 08:29 AM
Alex Racing Barracuda Bugs Bunny Singapore R/C Racers 6 01-22-2003 11:47 PM
