Alex Racing Barracuda R2 & R3 >
Like Tree4Likes
Old 10-02-2004, 05:56 AM
  #12916
wyd
Tech Legend
wyd's Avatar
Trader Rating: 51 (100%+)
Ok one more!!!!!!!!!!!!!!
wyd is offline
Old 10-02-2004, 06:06 AM
  #12917
JDM_DOHC_SiR's Avatar
Trader Rating: 31 (100%+)
Looking Good!!
-Dave
JDM_DOHC_SiR is offline
Old 10-02-2004, 06:14 AM
  #12918
wyd
Tech Legend
wyd's Avatar
Originally posted by JDM_DOHC_SiR
Looking Good!!
-Dave
Thanks Dave. I'm just getting ready to pack up and head to the local indoor asphalt track to break it in some. I'm even going to try the one way. I hate those things but I will give it a try and work from their. Track is pretty tight so might not be the best thing.
wyd is offline
Old 10-02-2004, 06:18 AM
  #12919
Good luck with your new toy... some pointers on the R3.. you will want to run the shocks almost vertical in the front and the rear as you can this car is a little different to set up vice the R2
-Dave
Old 10-02-2004, 08:27 AM
  #12920
RcMonk's Avatar
Car looks great. Good luck at the track.
Now with out the body.
RcMonk is offline
Old 10-02-2004, 09:23 AM
  #12921
Merciless's Avatar
Wyd
Are those yokomo springs your running ??
If so, do you often run with the rear springs harder than the front ?
It's something i was going to try next week as i'm struggling to get the turn in as visous as i like, So it's either that or a more aggressive tyre combo . Can't make my mind up
Merciless is offline
Old 10-02-2004, 01:00 PM
  #12922
pumpkinfish's Avatar
Dave you posted a carpet setup a few pages back. I converted to a setup sheet and want to know if anything needs to be changed.
pumpkinfish is offline
Old 10-02-2004, 01:47 PM
  #12923
You might want to change the rear diff setting... to Med.. and the camber link position to the out ones for the Front and Rear...and the Sus arms need to be changed to Mid-Span... thats all ..
But dont forget this is a basic carpet set up... it's a starting point
-Dave
Old 10-02-2004, 02:04 PM
  #12924
Updated the picture above so I am not cluttering up the board. I did this for guys to print and keep as a base. I know it is sometimes hard to work from a written text file and the setup sheets provide that quick visual.
Old 10-02-2004, 02:12 PM
  #12925
You have a PM..
Old 10-02-2004, 02:15 PM
  #12926
Talking Nice Paint
Look Who has some nice paint on the New ALEX M6 Bodies at the Tokyo Hobby Show .. I wonder who painted them ..
I tried a few new colors of some same patterns
-Dave
Old 10-02-2004, 08:42 PM
  #12927
wyd
Tech Legend
wyd's Avatar
Originally posted by Merciless
Wyd
Springs are from Rayspeed.
wyd is offline
Old 10-02-2004, 08:50 PM
  #12928
wyd
Tech Legend
wyd's Avatar
Well I ran the new R3 tonight. Car was fast all night long. In the main I was taken out on the 1st corner and batted back to 3rd in A but did run the fastest lap of day. I can't believe how fast Iw as and I even ran a one and have never ran one before at this track. Car was smooth and easy to drive all night. I very impressed with it.
Only real problem I have I think I read about before is their is just not enough steering throw on the R3 steering rack. The steering blocks are far from turning as far as they did on my R2. It would have really helped me to have more throw.
Speedtech don't have the Speedway ones in stock at this time and I'm going to a big race in 2 weeks and need to have this fixed before that. I will run the car next week and want to have a solution for it by then.
Ca I use the steering setup off my R2 and just change the center link between the steering links and the links going to the hubs? If I find a Speedway Pal steering rack how much more throw will I get? I'm looking for a blue one or would like to use the stock steering from my R2?
wyd is offline
Old 10-02-2004, 09:39 PM
  #12929
I'm trying to get to a target of -1.5 to -1.0 degrees or rear toe. I have the Ti-nitride coated 6.8mm uncentered ball studs but can't figure out how to position them. They don't look too "uncentered" to me! Should I use all four, on the fronts only or on the rear only. Also, I am using the Xenon aluminum rear hub carriers.
Old 10-02-2004, 09:43 PM
  #12930
wyd
Tech Legend
wyd's Avatar
I run 1 degree of rear to in the rear. I use the Xenon rear hubs. I run the left one on the right side and vice versa. With the off center ball studs look for the little notch in the one side of the ball. Take the ones in the front of the rear arm and have that notch facing towards the center of the car and the rear studs have the notch facing the outside of the car. This will take the most amount of toe out of the car.
wyd is offline
