Old 09-29-2004, 09:17 PM   #12871
Speed Demon's Avatar
Default Spliff vs Diff
Isn't the spliff work just the same as the diff???? If no..
what's the difference???
CUSTOM CRAWLER & ROCK STACKER
Speed Demon is offline   Reply With Quote
Old 09-29-2004, 09:59 PM   #12872
JDM_DOHC_SiR's Avatar
Trader Rating: 31 (100%+)
Originally posted by wyd
Perfect!!!!!!! Thanks Dave I can count on you to help.
That is a pretty trick setup from them.
Brian
Your welcome
Ȼ4.5 Centro+α ◊ TRF 501ӽ ◊ TRF 502ӽs ◊ TRF 503 ◊ TRF 511 ◊ TRF 201ӽr ◊ TRF 211ӽ
B5m ◊ T5m ◊SC5m ◊ B64deez nutz
Speedway PAL ◊ SDRC ◊ Shop UFO ◊ SMC
JDM_DOHC_SiR is offline   Reply With Quote
Old 09-29-2004, 11:52 PM   #12873
MikeR's Avatar
Trader Rating: 15 (100%+)
Never noticed that about the R3 sway bars- that's trick!
Speed Demon- Spliff is basically an extremely tight front diff. Gives you the pull of a spool but less damaging to the universals.
www.exotekracing.com ☆ASSOCIATED☆DURANGO☆HPI☆HB RACING☆KYOSHO☆LOSI/TLR☆SERPENT☆TAMIYA☆TEKNO☆XRAY☆
A picture with your post, when trouble shooting, will probably get more rctech help than without...
MikeR is offline   Reply With Quote
Old 09-30-2004, 03:27 AM   #12874
[i]Speed Demon- Spliff is basically an extremely tight front diff. Gives you the pull of a spool but less damaging to the universals. [/B]
Thanks Mike.. I appreciate that..
Old 09-30-2004, 05:56 AM   #12875
wyd
Tech Legend
wyd's Avatar
Trader Rating: 50 (100%+)
Send a message via AIM to wyd
Thread is starting to jump now. Seems like a some new guys are showing up and running Cuda's. Thats cool.
It seems like alot of guys are using the #2 HPI Piston. Does anyone run the white teflon ones from Alex? I bought some from SPeedtech but didn't order enough of them. I thought you got 4 of them but they come in pairs. I will get some more when I place my next order.
ST Racing Concepts (STRC)
Old 09-30-2004, 03:26 PM   #12876
Either one works good... I like the HPI one's may self...
but the ALEX pistion is more like a #3 HPI..or 1.1mm holes
-Dave
Old 09-30-2004, 03:48 PM   #12877
Pro Models's Avatar
Default Problem Under Braking with R3
Hi GUys.... I have a small problem with my R3. Under braking coming into a corner it sort of skids a few centimeters (in a striaght line) and then turns. Obviously this is leading me to misjudge my braking point at each corner where brakes are applied.
Was wondering If any one has any tips on how to cure this problem.... I was thinking about the following.
1. Increase Rear droop which should increase weight transfer to the front.
2. Add a thin anti roll bar at the rear.
3. Place rear shocks on the outer hole (fronts are on the outer).
4. Decrease Brake (Step 2 on Nosram Evo)
Am I right on the above? Any Ideas?
Bye for now.
Pro Models is offline   Reply With Quote
Old 09-30-2004, 04:16 PM   #12878
Merciless's Avatar
Send a message via ICQ to Merciless
how much droop are you running (rear)?
I'd suggest unless it's very little you'd want to decrease it not increase it
You didn't say if it was front or rear or all sliding
Still think you probably got to much weight transfere not to little ??
possibly harder front springs
If it's a problem under braking start with altering the front normally..........
Merciless is offline   Reply With Quote
Old 09-30-2004, 04:32 PM   #12879
Pro Models's Avatar
Hi Mercilles,
I measure droop from the center of the axle to the ground on 10mm blocks ... at the moment I run 32mm front and rear.
It seems that the front slides.. it sort of 'bobs' up and down for split second with the tires turned...then it turns.. this always under heavy braking into a hair pin.
What do u think?
Old 09-30-2004, 04:36 PM   #12880
Merciless's Avatar
I'd go for harder front springs
Sorry as for the droop do you know how much upward movement the chassis has from rest fully loaded ??
It makes much more sense to me that way i use 2.5mm front and 4mm rear
Old 09-30-2004, 04:42 PM   #12881
Pro Models's Avatar
I have no idea.... not sure exactly how to measure it. However I would try out a harder spring up front. Thanks for your suggestion.
Old 09-30-2004, 04:52 PM   #12882
Merciless's Avatar
Cause i'm such a nice guy
I just looked at my droop your way roughly
34mm rear 32mm front ish
but my settings are about .5 to 1mm out at the mo (new tyres)
So at a guess using your formula to do it i'd say 31mm font and 33/34 rear
but basicly measuring from the ground to the bottom of your car after setting your ride height i think you should have about 2mm of upward movement at the front and 3/4mm at the rear over and above your ride height to full shock movement.
Old 09-30-2004, 05:07 PM   #12883
OVA
OVA's Avatar
Trader Rating: 79 (100%+)
Anybody here have this problem,,My front universal making noise when you turn the wheel all the way right or left? sound like the universal binding? I love my R2
I have not failed. I've just found 10,000 ways that won't work
OVA is offline   Reply With Quote
Old 09-30-2004, 05:09 PM   #12884
Pro Models's Avatar
Hey Merciless .... very nice guy I must say thanks...
Up front I also have about .5 toe out ... I will try out the droop measurement tomorrow and let you know how I got on.... if it still dosent work i will try out the harder front springs.....
Thanks for your help much appreciated
Old 09-30-2004, 05:55 PM   #12885
wyd
Tech Legend
wyd's Avatar
Mine seemed to do it alot more when I had my spool in their but with a diff it didn't do it near as much. You will know if it is really binding up when you run.
Merciless your car will always go straight if you lock up the brakes and have 2 diffs in or diff and a spool. Cars will not steer if the brakes are lokced and the car will push or plw straight ahead til you let off the brakes some and the wheels can free wheel. Now if you use a one way up front then you can steer while you apply some brakes but then you more than likely get really loose as the rear tires lock and the fronts don't and it is be like 2wd drive and slide the rear. You could add a tad bit of caster under you front ball studs under the a arms as this will giv you more off power steering. Start with 1mm spacers and work your way up from their. I wouldn't go more than 2mm or so.
WTB Alex Racing Barracuda R2 & R3 Funkymojo R/C Items: Wanted to Buy 3 02-03-2007 01:00 PM
alex racing barracuda con81 Electric On-Road 1 12-14-2005 03:36 AM
WTT: Alex Racing Barracuda R2 for PS2 AZ_Ron Other Items: For Sale/Trade or Wanted to Buy 0 02-13-2005 07:30 PM
Alex Racing Barracuda R3-New. rcracing1973 R/C Items: For Sale/Trade 9 04-11-2004 08:29 AM
Alex Racing Barracuda Bugs Bunny Singapore R/C Racers 6 01-22-2003 11:47 PM
