Alex Racing Barracuda R2 & R3 >
Old 09-28-2004, 08:18 PM
  #12841
wyd
Tech Legend
wyd's Avatar
Trader Rating: 51 (100%+)
Originally posted by RcMonk
Wow...you weren't kidding about overnight delivery. The stuff I sent you should be there in two days. Have fun building it and stay away from the graphite dust !!
Wouldn't kid about stuff like that. I did eat some graphite dust and sniffed some as well. That stuff sucks!!!!!
I have the car about 70% done. I have the drive line all hooked up and the a arms and shock towers are all on as well. I'm actually going to try the one way but RCO is pretty tight to use one but I will try it. The sparkle chassis with the blue parts is awesome!!!!!!!
I sent your parts out as well. I would think you could get them tommorrow since you only live 2 hours from me but if not Thursday. I will have my R3 done tommorrow for the most part and then Thursday will be used to put my R2 back together and then to steal parts from it to the R3 as needed.
Friday I will use to put the radio in and final setup. I hope my body from the R2 fits the R3.
Brian
wyd is offline
Old 09-28-2004, 08:43 PM
  #12842
JDM_DOHC_SiR's Avatar
Trader Rating: 31 (100%+)
Brian
They do....
-Dave
JDM_DOHC_SiR is offline
Old 09-28-2004, 08:45 PM
  #12843
I will take some pics. Car is coming along nicely. Had a few hang ups since I can't read Japanese!!! Steering rack took a little messing around with but everything else is cool.
I guess the kit don't come with a servo saver....?
Nope no servo saver.. you can get the Tamiya one...but it has a lot of slop in it. .... Your if you have access to a Kawada one that would be the best
now as for the Steering Rack...?? did you pick up the PAL Alloy one..?? it has a bit more travel than the graphite one
-Dave
Old 09-28-2004, 08:46 PM
  #12844
wyd
Tech Legend
wyd's Avatar
Originally posted by JDM_DOHC_SiR
They do....
-Dave
That saves me a ton of time.
wyd is offline
Old 09-28-2004, 08:47 PM
  #12845
pumpkinfish's Avatar
No servo saver in the kit I had to go to a hobby shop 20 miles away to find a small one when I built my R3. I'm just waiting on Jim to help me out with a few choice parts (hint, hint....)
pumpkinfish is offline
  #12846
Makes life easy when they use the same mounts and such
-Dave
Old 09-28-2004, 08:49 PM
  #12847
wyd
Tech Legend
wyd's Avatar
-Dave
Well somehow when I had my other Cudas I happened to have a brand new steering rack that had the bearings in with it so I used it. I will look into the aluminum one down the road.
Right now my R3 don't have the alum. idler gear holders, do you think I will strip spur gears? I will have some blue one from my R2 and will use them if needed.
wyd is offline
Old 09-28-2004, 08:53 PM
  #12848
wyd
Tech Legend
wyd's Avatar
Yea I was surprised of having no servo saver but I have a few here so not a problem.
So far the R3 is building pretty easy. I would of liked to see hardened parts and mid span arms on the car for the price. I stole parts off my R2 like my mid span arms and off set ball studs for the arms. I also will be using my blue alum. idler gear holders (if I find I need them) and I will steal some of my stainless steel scres from the R2 as well. My R2 will be mainly a parts car.
wyd is offline
Old 09-28-2004, 08:57 PM
  #12849
you should not have any problems with the R3 plastic holders... but I would try to use the Alloy one up front on both cars.. and then upgrade them in the rear after you get them...also the alloy ones are a bit less binding(pinching on the bearing) than the plastic ones ....
-Dave
Old 09-28-2004, 09:02 PM
  #12850
Default Personal transponder holder!!!
Does anyone know who makes and where I could the personal transponder holder thats in the pictures of the belt conversion back on page 425...
I thought I also saw something similar on a picture of an EVO IV recently.
Jim C
JIMC is offline
Old 09-28-2004, 09:07 PM
  #12851
Default Re: Personal transponder holder!!!
Jim C
Are you talking about the Transponder/servo mount that bolts to the servo/chassis...or the Alloy holder that the Transponder mounts on to..??
Talk a look at the attached picture.. are you talking about the item at the lower right hand corner.??
-Dave
Old 09-28-2004, 09:23 PM
  #12852
Hey Dave
Its Jim Crider
I am interested in the actual Alloy holder that the transponder mounts into in the lower right hand corner, you are correct...Ed McMahon would so say
Do you have any pics showing how a personal or where a personal might be mounted.??
Does Dragon Paint have a website??
JIMC is offline
Old 09-28-2004, 09:26 PM
  #12853
Hey Dave
Its Jim Crider
Xenon makes the Mount... and I belive that Steve at Speed Tech can get them
.. I"ll look for some pic's right now..
-Dave
Old 09-28-2004, 09:28 PM
  #12854
No But I can paint almost anything... PM me if you are looking to get something done
-Dave
Old 09-28-2004, 09:36 PM
  #12855
Thanks Dave...
I'll give Steve a shout tomorrow about the Xenon holder.
JIMC is offline
