Alex Racing Barracuda R2 & R3 >
Like Tree4Likes
Old 09-19-2004, 03:53 PM
  #12721
Merciless's Avatar
Originally posted by wyd
I was thinking of maybe trying the low profile hubs I sayw on the Speedtech site. If the rear ones just mounted lower their would be no problem.
Think were talking about the same thing
Deffinately check them out @ steve's i'm sure you'll find there the PAL hubs............
Merciless is offline
Old 09-19-2004, 04:07 PM
  #12722
wyd
Tech Legend
wyd's Avatar
Trader Rating: 51 (100%+)
They look perfect. Only need them for the rear if I do it down the road. Won't be running foams for at least a month or more. I will be getting another big order from Steve in the near future.
wyd is offline
Old 09-19-2004, 04:52 PM
  #12723
Trader Rating: 27 (100%+)
Default Lazy Steering on R3
Hi Guys/Gals (if any )
I know this must be answered a million times but please answer it once more
how can i make the steering in an R3 more lively? i'm using mid span arms, pal steering rack, all shocks moved to the outest hole, and all camber links moved to the top hole on the knuckles and on the out most hole on the top deck. It feels a lot better than it used to but would still prefer some more snappy steering is it possible to make it steer like a pro4?
thanks!
poop is offline
Old 09-19-2004, 06:26 PM
  #12724
wyd
Tech Legend
wyd's Avatar
Lighter oil will make it a little more lively. The softer you go the faster it will react. Stiffer will slow it down some.
wyd is offline
Old 09-19-2004, 06:32 PM
  #12725
I've tried that too dropping it down to 25wt. it's a lot better than before but i was just wondering if it could ever steer as direct as a pro4, if so, what needs to be done or what set ups should i try?
thanks!
poop is offline
Old 09-19-2004, 06:43 PM
  #12726
wyd
Tech Legend
wyd's Avatar
Well you could try a swaybar int he rear only as it will loosen it up a little more. Could also try less caster especially if you need more on power steering.
Another thing to try is adjust you steering expo to about +25% as that will speed it up some. You will more your steering wheel less but it will make your steering input a little faster.
wyd is offline
Old 09-20-2004, 02:48 PM
  #12727
cheers mate, i'll give it a go today and see how it is. Would a bit of anti squat/kick up help?
poop is offline
Old 09-20-2004, 05:06 PM
  #12728
wyd
Tech Legend
wyd's Avatar
Kick up in the front will give you more off power steering and less on power steering.
Pro squat I'm not sure of as I have not ran it yet to see what it does.
wyd is offline
Old 09-21-2004, 04:43 AM
  #12729
TC3
TC3's Avatar
only 2 weeks until carpet season starts
so what is a good starting point for shock setup?
on asphalt is usualy start with 1,4x5,25 springs and 40-50wt oil with hpi #1 pistons.
i think i have to try heavier shock oil or smaller pistons for carpet.
any sugestions.
i am running rubbertieres (sorex 28 or pit 24r).
TC3 is offline
Old 09-21-2004, 01:35 PM
  #12730
I think that 1.4 x 5.25 is already bit hard for asphalt. We are using 1.4 x 6.00 or even 6.50s on asphalt here in Malta, however it depends the particular track I guess
On carpet, you have to go harder but since we do not have carpet racing over here, cannot help you a lot
dhiracing.com is offline
Old 09-22-2004, 02:27 AM
  #12731
Default ADVICE
hi to everyone that owns a barracuda
is there anything that you can do to make the barracuda sound like a belt driven car e.g QUIET i have oiled the bearing , new spur , diif gears and the 16 tooth gears as well i have also shimed the gear boxes like the manuel so CAN ANYONE HELP ME
i am sick of the car sounding loud
If anyone can help me send a Pm or post it
StAsIk is offline
Old 09-22-2004, 03:52 AM
  #12732
TC3
TC3's Avatar
the car is quiet if u run without diffcovers.
but therefor u need the shorter steering posts.
TC3 is offline
Old 09-22-2004, 04:05 AM
  #12733
stjerno's Avatar
Default Re: ADVICE
Go back through the last 18 pages.. Dave is giving af lot of advice on the correct shim' of the drive train.
I run my gears dry btw.
stjerno is offline
Old 09-22-2004, 04:52 AM
  #12734
wyd
Tech Legend
wyd's Avatar
If you use anything on the gears it needs to ba dry type lube. I use Paragon liquid graphite. It goes on wet and dries in seconds. I can't say my car is the quietest thing around but I bought it used and need to go over the drive train some. It is very free though so I will be just make sure everything is shimmed correctly.
wyd is offline
Old 09-22-2004, 01:27 PM
  #12735
rcsabah's Avatar
shiming important. if race i used all new gears and it quiet no any other treatment on gears and no cover. don't followed the manual shiming shim them to the right clearance between gears
rcsabah is offline
