Old 09-15-2004, 04:50 PM   #12706
Gazza_D's Avatar
Send a message via Yahoo to Gazza_D
The Alex racing shocks work fine, although I would recommend replacing the stock caps for Yokomo bladder style. It makes the whole unit super smooth. I have the Tamiya shocks too and to be truthful find no difference between the two on the car.... I only use them so as to utilise all those Associated springs I still have in the pit box
It will be back to the Alex ones when i get a few more springs
Sure is nice to have a couple of sets though, one set up different to the other. Not cheap though!!
Gazza_D is offline   Reply With Quote
Old 09-15-2004, 08:45 PM   #12707
pumpkinfish's Avatar
Hey guys I need some help. I finally ran my Pink R3 on rug tonight. The car felt very lazy through the chicane. I remember someone (Jim I think) giving some tips on what would make the steering have some "snap". Does anyone remember the tip?
Also, I had the pin fall out of my drive shaft Can I fix it or do I need to get new center shaft ends?
pumpkinfish is offline   Reply With Quote
Old 09-15-2004, 11:53 PM   #12708
GTO2's Avatar
R/C Tech Charter Subscriber
Some idea abt the lazy steering, it is normal tho can be improved.
Probably I would do droop adjust, more steering throw, shocks setup.
If your drive shaft not deforming, I would put the pin back with some CA enforcement.
driftercentral.com
GTO2 is offline   Reply With Quote
Old 09-16-2004, 03:33 AM   #12709
stjerno's Avatar
One of our team drivers made a small mod to his R3 .. finde it rather usefull for indoor carpet racing
He cut some lexan to put over the diff's instead of the regular diff. covers because they can not be used with the stabilisors on the R3 without further cutting.
Pics can be seen here : http://www.a-rc.dk/forum/viewtopic.php?t=13
Good luck with the carpet season to all the Cuda drivers
stjerno is offline   Reply With Quote
Old 09-16-2004, 05:53 AM   #12710
Lowner_V1S's Avatar
Send a message via Yahoo to Lowner_V1S
Does the r3 chasis tweaks?? or it depends how you prep the chasis??
Lowner_V1S is offline   Reply With Quote
Old 09-16-2004, 06:05 AM   #12711
GTO2's Avatar
For past 8mths I run my R3, no tweak.
It was designed not to I suppose, or me just don't run it hard enough ...
driftercentral.com
Old 09-16-2004, 07:22 AM   #12712
wyd
Tech Legend
wyd's Avatar
Trader Rating: 50 (100%+)
Send a message via AIM to wyd
Cool you ran the fish on carpet. What type changes did you make to it as far as shock oils and pistons to run at DC Ultra. What tires did you run on it. How do you think you car looked against the others practicing? I do plan to run their a few times but I need to shake my car down Saturday at RCO since it is 40 minutes away and I'm familiar with the track. Alot closer to home if I do have any problems.
Brian
ST Racing Concepts (STRC)
Old 09-16-2004, 05:32 PM   #12713
Wyd,
I was there with your Surge boys John & John. Very cool guys! I live about 40 minutes away from the track...I"m in Collegeville.
I was just trying to shake down the car and get used to turning right again I was racing dirt oval all summer and forgot that my wheel turned the other direction
I had my Novak 5800 Brushless in just trying to get track time. See the attached for my setup except I was running 2 degree camber all the way around.
GTO2,
I lost the pin So I have no way of putting it back in. I guess I need a new set unless someone can suggest a replacement pin source.
Old 09-16-2004, 05:38 PM   #12714
wyd
Tech Legend
wyd's Avatar
Thanks. John said he say you their with that Cuda. I will be down in a few weeks. Need to get some more stuff first.
Brian
Old 09-18-2004, 06:04 AM   #12715
wyd
Tech Legend
wyd's Avatar
Man way to quite in this thread. I'm going to run my new car in a few hours and race it as well. Should be a great day to shake it down as it is raining like cats and dogs out here from the left over of Hurricane Ivan..............
Old 09-18-2004, 06:09 AM   #12716
Herminator's Avatar
Send a message via ICQ to Herminator
Last weekends setup for the Carlisle outdoor track.
The car had good turn in and exit steering and on the tighter corners you could slide the back out a little in a controled manner.
The tyres are CS22 premounts on dished wheels that are about 5 meetings old but they still worked well.
Herminator is offline   Reply With Quote
Old 09-19-2004, 02:07 PM   #12717
Herminator's Avatar
where on earth is everyone?
Old 09-19-2004, 02:16 PM   #12718
wyd
Tech Legend
wyd's Avatar
I was wondering the same thing. I did run my newest Cuda (2nd time around with a Cuda) and didn't do too bad. I think I need to take off the rear alum hub carriers because with them on I can't use 28mm tires ont he car when I use foams. I'm pretty sure with my first Cuda that I used the hard stock plastic ones and this solved my problem.
Won't be a problem next time I run the Cuda as I'm going to be running rubber tires in October. My last time I will be racing outside for this year.
I did have alot of body roll running foams this week even with the 1.2mm front sway bar on and going up to 50 wt oil with the #2 HPi pistons. Now this was on asphalt. I did run the Rayspeed red front springs and white in the rear.
Old 09-19-2004, 03:17 PM   #12719
Merciless's Avatar
Send a message via ICQ to Merciless
Humm i've never had any luck using the std. hubs and foams i had to change to the PAL hubs to get them on there
Merciless is offline   Reply With Quote
Old 09-19-2004, 03:37 PM   #12720
wyd
Tech Legend
wyd's Avatar
I was thinking of maybe trying the low profile hubs I sayw on the Speedtech site. If the rear ones just mounted lower their would be no problem.
WTB Alex Racing Barracuda R2 & R3 Funkymojo R/C Items: Wanted to Buy 3 02-03-2007 01:00 PM
alex racing barracuda con81 Electric On-Road 1 12-14-2005 03:36 AM
WTT: Alex Racing Barracuda R2 for PS2 AZ_Ron Other Items: For Sale/Trade or Wanted to Buy 0 02-13-2005 07:30 PM
Alex Racing Barracuda R3-New. rcracing1973 R/C Items: For Sale/Trade 9 04-11-2004 08:29 AM
Alex Racing Barracuda Bugs Bunny Singapore R/C Racers 6 01-22-2003 11:47 PM
