Old 09-14-2004, 10:59 AM   #12676
Thanks for all the ideas guy's keep them coming and I will check it all out!!
anton is offline   Reply With Quote
Old 09-14-2004, 11:04 AM   #12677
Greenbandit's Avatar
Question: I am running titanium axles on my R2 and I have shimmed them as much as possible to where they still spin freely, but there is still a bunch of slop front and rear. Is anybody experiencing this at all. Any suggestions to remidy this? I am running Acer ceramic bearings all the way around and they only have a couple of runs on them. Are the axles maybe just a bit too small?
Greenbandit is offline   Reply With Quote
Old 09-14-2004, 03:42 PM   #12678
JDM_DOHC_SiR's Avatar
Trader Rating: 31 (100%+)
Do you have the Hex addapters on the right way..?? the one with the groove should be in the front.?
just a thought
-Dave
Ȼ4.5 Centro+α ◊ TRF 501ӽ ◊ TRF 502ӽs ◊ TRF 503 ◊ TRF 511 ◊ TRF 201ӽr ◊ TRF 211ӽ
B5m ◊ T5m ◊SC5m ◊ B64deez nutz
Speedway PAL ◊ SDRC ◊ Shop UFO ◊ SMC
JDM_DOHC_SiR is offline   Reply With Quote
Old 09-14-2004, 04:08 PM   #12679
raving-monkey's Avatar
Send a message via MSN to raving-monkey
Default shock problem!
ok guys, ive just been setting the ride height and set 5.5 on the rear, and the all is good.
but i come round to doing the front, i set it to (well attempt to) 5.5mm but even with the shock collars all the way up, it is still 6mm+..that isn't the problem but the problem is that evening having 6mm+ ride height the shocks have no movement at all..they have about 1mm movement on left and right (only on the front)....
i hope it made sense and i was wondering if anyone else has had this problem before..if so is there a cure to it?
thanks
Matt
raving-monkey is offline   Reply With Quote
Old 09-14-2004, 04:19 PM   #12680
just a thought
-Dave
I am running the clamp style hex adapters.
Todd Daly
Old 09-14-2004, 04:40 PM   #12681
OK..
hmmm how much in and out play do you have on the Axle.?? .5mm is acceptable
-Dave
Old 09-14-2004, 04:45 PM   #12682
RcMonk's Avatar
When I ran Jet Hobby front knuckles there was some play in the axles. I think the spacing between the bearings in the knuckles was not enough causing the slop. Ended up putting a 8x10x0.3mm shim prior to installing the inner 6x10 bearing. It's the same shim that I use to shim the bevel gears. Miight work in your case.
RcMonk is offline   Reply With Quote
Old 09-14-2004, 04:52 PM   #12683
Yea I hear ya on the Jet hubs.. I had 2 that were very different..one I couldn`t even get the bearing insude the tollerance was too dng tight and the other one had mad ammounts of play..??
-Dave
Old 09-14-2004, 04:57 PM   #12684
RcMonk's Avatar
Hmmm...I thought I was the only one. Maybe their QC is not as good as Xenon or Pal guys. The Jet knuckles are now my backups since I now use Xenon and Pal ones.
-Dave
Old 09-14-2004, 05:07 PM   #12685
wyd
Tech Legend
wyd's Avatar
Trader Rating: 50 (100%+)
Send a message via AIM to wyd
JDM_DOHC_SiR will the R3 Cuda chassis work on a Xenon kit? Are the shock towers the same on the R2 and the R3? If Jason gets that chassis setup from you I will have him make me some stuff but I have the Xenon R2 which you saw.
Well was working on the new Cuda R2 Xeonon and pretty much have it ready to run for this weekend. Need to mount my new body on it and set the electronics and it is about ready. I rebuilt the shocks. Funny is it don't have stock shock caps on. It has some silver alum. type and not sure what car they came from.
ST Racing Concepts (STRC)
Old 09-14-2004, 07:30 PM   #12686
RcMonk's Avatar
wyd,
I think those shock caps are yokomo mr4tc alum caps. at least from the pic you posted.
Old 09-14-2004, 08:14 PM   #12687
wyd
Tech Legend
wyd's Avatar
You know I think your right. Thats whats on my car now but I did order some stock shock caps. I have a big order coming in from Speedtech this week.
Old 09-14-2004, 09:27 PM   #12688
wyd
Tech Legend
wyd's Avatar
Anyone have a printable Cuda Setup sheet. Everytime I try to print the one from the Alex Site it won't center up right.
Old 09-15-2004, 03:41 AM   #12689
Herminator's Avatar
Send a message via ICQ to Herminator
Yeah they're yoke caps with the anodizing stripped off, I'd keep them on there
Herminator is offline   Reply With Quote
Old 09-15-2004, 06:42 AM   #12690
RcMonk's Avatar
wyd, i can email one that i had made when i get home tonite. format is a combination of the japanese alex racing setup sheet and the one on the usa website. word and pdf format.
WTB Alex Racing Barracuda R2 & R3 Funkymojo R/C Items: Wanted to Buy 3 02-03-2007 01:00 PM
alex racing barracuda con81 Electric On-Road 1 12-14-2005 03:36 AM
WTT: Alex Racing Barracuda R2 for PS2 AZ_Ron Other Items: For Sale/Trade or Wanted to Buy 0 02-13-2005 07:30 PM
Alex Racing Barracuda R3-New. rcracing1973 R/C Items: For Sale/Trade 9 04-11-2004 08:29 AM
Alex Racing Barracuda Bugs Bunny Singapore R/C Racers 6 01-22-2003 11:47 PM
