Alex Racing Barracuda R2 & R3 >
Old 09-08-2004, 04:44 AM
  #12601
Lowner_V1S's Avatar
Thanks dhiracing.....
Im After the C hub,drive shaft holder,rear hub,dogbones (all of this are alloy)if they fit in r3???and also TEAM BOMBER fits on the r3???? or is it different size?
Lowner_V1S is offline
Old 09-08-2004, 04:48 AM
  #12602
JDM_DOHC_SiR's Avatar
Trader Rating: 31 (100%+)
All of the stuff that you have listed will work from the R2 ..and I Know the EXCEL Shaft works for the R2 and R3 ...they are the same..just a different part # thats all
-Dave
JDM_DOHC_SiR is offline
Old 09-08-2004, 04:50 AM
  #12603
Herminator's Avatar
drive shaft holders and dogbones are the same for the R2 and R3 so no problem there.
rear hubs on the R3 have slightly different roll centres I think and the c-hubs may be slightly different too. They'll fit but effect the geometry slightly.
No idea what the team bomber thing is that you mention?
Herminator is offline
Old 09-08-2004, 04:51 AM
  #12604
Herminator's Avatar
-Dave
beat me to it
So what were your thoughts on that belt drive alloy chassis brace?
Old 09-08-2004, 05:08 AM
  #12605
Lowner_V1S's Avatar
Thanks dave... just had an idea ask you guys wat's the different between the r2 and r3 parts if they fit to each other i just dont wanna waste my time and money buying if the part wont fit...
Herminator:
TEAM BOMBER is a drive shaft... i saw the pix of team bomber fits on the evo 4... original from yokomo sd...
You got any recommended parts for r3???
Thanks,
Bryan
Old 09-08-2004, 05:09 AM
  #12606
Not to sure about it yet....since there will be a few different versions ...that "MIGHT" come out..??.. everything is still to early in the design stage......thats all I can say about it
-Dave
Old 09-08-2004, 08:37 PM
  #12607
Speed Demon's Avatar
Default 6.8mm offset ball again??
I remember that Dave had mentioned that he use 6 pcs of the offset ball in his car... 4 pcs on the rear arm and 2 pcs on the front arm... but I wasn't too sure... I have bought the balls but a bit confused on which side to intall them in the from arm... should it be towards the rear or towards the front??? which one?? If someone got the pics , maybe I can have a look...
thanks..
Speed Demon is offline
Old 09-08-2004, 08:47 PM
  #12608
Fatboy Joe's Avatar
Default Alex Racing Spring Rate Conversion
Hi guys, I think someone has already asked this before but I can't trace it back in the old pages. I was wondering what does "1.5 x 6.0" mean interms of spring rate in Lbs.? I know this is the standard kit springs. I just need to knw the numbers in pounds. Thanks in advance
Fatboy Joe is offline
Old 09-08-2004, 09:12 PM
  #12609
RcMonk's Avatar
Default Re: Alex Racing Spring Rate Conversion
This is from my notes.
1.5x6.00 18.52lb/in
RcMonk is offline
Old 09-08-2004, 11:17 PM
  #12610
Default Re: 6.8mm offset ball again??
thanks..
ahh.... yepp... I found it.... 4 pcs in front and 2pc on the rear....
thanks to Dave....
Old 09-09-2004, 12:01 AM
  #12611
stjerno's Avatar
I'll post my little conversion table again .. guess it should be posted every second month or so
Hope it will come in handy.
File Type: pdf
stjerno is offline
Old 09-09-2004, 12:40 AM
  #12612
Thanks stjerno ... they are always handy
dhiracing.com is offline
Old 09-09-2004, 12:41 AM
  #12613
stjerno's Avatar
Your'r welcome
stjerno is offline
Old 09-09-2004, 08:45 PM
  #12614
wyd
Tech Legend
wyd's Avatar
Trader Rating: 51 (100%+)
Wow on the 2nd page. That don't happen to often. I think I'm looking to buy a new blue R3 in the sparkle chassis. I think I should of never sold my R2 Xenon that I had and I kinda miss having the Cuda. Maybe in a few weeks I will making that call to Steve at Speedtech.
wyd is offline
Old 09-09-2004, 10:56 PM
  #12615
Good to see ya coming back ... have you talked with Jason at BMI yet..?... he has a little project that he has on the back burner.. he just needs a complete car to work with
-Dave
