Alex Racing Barracuda R2 & R3 >
Old 09-06-2004, 01:03 AM
  #12571
stjerno's Avatar
Default Re: Orange paint jobs
Originally posted by JDM_DOHC_SiR
Hey guys here is what I painted up this weekend..
-Dave
Thats it ....
Hold em' for me
Dave - I'll PM U
stjerno is offline
Old 09-06-2004, 01:23 AM
  #12572
JDM_DOHC_SiR's Avatar
Trader Rating: 31 (100%+)
Default Re: Re: Orange paint jobs
Originally posted by stjerno
Thats it ....
Hold em' for me
Dave - I'll PM U
You have a PM
JDM_DOHC_SiR is offline
Old 09-06-2004, 03:00 AM
  #12573
Herminator's Avatar
Default Re: Let the Guessing begin
A picture is worth a 1000 words... ..one clue...look at the upper 2 mounting holes at the front and rear .. I know what this item will be for I`ll let you all guess for a little while
-Dave
Hmm, certainly looks like there may be no need for a top deck on the belt conversion
Even with an alloy back bone I'd be worried about tweak though, imagine one hard hit that would twist the chassis a bit and the alloy would stay bent
I'm wondering which side it would go on, and which side the motor would be.
The motor could go on the left side of the chassis but the flat bottom of the brace would be close to getting in the way of the motor can unless it stops there but we just can't see that in the pic. It could go on the right side of the chassis but then you've got battery placement issues.
The brace couldn't go on the left unless the servo is moved, and then there's the cells to think about if you have the motor on the right of the mount.
argh... so many ways that will and won't work...
OK, either one of these may be the layout....
brace on the right with motor on the right too, hanging out like a 415 but on the other side. Servo turned 90 degrees to keep it at a sensible width while being on the right too, along with the other electronics. Cells all on the left of the chassis, with the belt running down the middle, in line with the flat bottom of the brace.
or pretty much the same as above but with everything on the opposite side but then the brace would get in the way of the servo Unless the servo is put almost central at the front of the chassis but then would there be room for the cells behind it.
My brain hurts I just remembered the motor would be spinning the wrong way if it's on the right hand side, stupid belt drive cars
So it should be motor left, cells on right, or possibly a 4-2 split or maybe 3-3 saddles, I some how favour 4-2 though if there is a split. But the servo location may not be so obvious...
I think my brain just regurgitated over this page
Either way there's still the possibility of a top deck, possibly a one sided brace of some sort, the other side will atleast need spacers.
Herminator is offline
Old 09-06-2004, 03:05 AM
  #12574
Herminator's Avatar
-Dave
These are very nice
The over blue/yellow shells need something extra.... sunlight would help I'm not sure about the yellow with that blue, neither stand out enough, but that could just be the light.
I think you should try the orange ones with the marble orange replaced by metalic blue with with silver showing through and bit more orange in the front fade section so it stands out against the blue
Old 09-06-2004, 02:44 PM
  #12575
Gazza_D's Avatar
Put the Orange shells on that Web special of yours Dave and get out racing
Stun the opposition into submission
Second place for Cudas at the national this weekend in both 27T stock and 19T super stock classes!!!!. Sure was close to victory too
Next time.....
Gazza_D is offline
Old 09-06-2004, 03:12 PM
  #12576
Registered User
how does the r3 run i havent seen one in action
T Allen is offline
  #12577
raving-monkey's Avatar
are there any sites where there is a detailed building tips for the cuda's(also pics would be great)..just ready for when mine arrives
raving-monkey is offline
Old 09-06-2004, 03:53 PM
  #12578
Originally posted by Herminator
hang on, what the heck am I thinking
having the 1 degree hubs on the wrong sides would give you less toe in
Hmm if you have 4 degrees then I'm puzzled. Are you sure it's 4 degrees per side?
Ive put the stock rear hubs on the oppsite side now to what they should be and have got 1 deg toe in each side
I really need some of the opstional ball studs but every one is out of stock
Im going to try and have a chassis done that has 0 deg on the wishbones so it will give better ajustmant
Nick Simpson is offline
Old 09-06-2004, 04:14 PM
  #12579
I have a few different ones that I have been painting up for the Sportsman final here in November .. the Orange ones are the best to see at Yatabe.. but I"ll be sporting some different paint this time
Old 09-06-2004, 11:55 PM
  #12580
stjerno's Avatar
No we're not
www.a-rc.dk
stjerno is offline
Old 09-07-2004, 12:29 AM
  #12581
Club K&K
This website has the building tips for R3.
Vector is offline
Old 09-07-2004, 07:53 AM
  #12582
thanks, but...erm..its all in some dodgey language (japanese or something)
Old 09-07-2004, 08:28 AM
  #12583
I've seen and heard a r2 very nicely built but it was a bit whiny at the start but quietened when it was run more
Chazz
Chazz is offline
Old 09-07-2004, 09:09 AM
  #12584
Herminator's Avatar
take a look at www.alexracingusa.com
Old 09-07-2004, 09:47 AM
  #12585
thanks, i looked there but it doesn't seem very detailed..or any pics.
i guess it will do tho
