Alex Racing Barracuda R2 & R3 >
Like Tree4Likes
Old 09-05-2004, 07:25 PM
  #12556
Trader Rating: 27 (100%+)
Default Re: Re: how quiet can a cuda get?
Originally posted by JDM_DOHC_SiR
Quiet as a SD or Pro4.?? uumm no ..but you can get in the realm of a EVO4... on some of the older cuda bevel and ring gears..you needed to sand them...but on the new ones it`s not needed..you`ll just need to break in the drive train for a little while 30 min`s and the drive train should be a bit quieter and a bit freeier but this is after you have the drive train shimed to the point where there is a minimal ammount of slop in the gears..
-Dave
Damn! i should have asked you first! i sanded all the bevel gears
when you say minimal amount of slop...do i shim the diff and oneway gears as far away from the 16T bevel or should i only shim to the point similar to a pinion and spur mesh?
in the realm of an EVO4's good enough for me...at least people wont mistake it for a TL01
poop is offline
Old 09-05-2004, 09:54 PM
  #12557
JDM_DOHC_SiR's Avatar
Trader Rating: 31 (100%+)
Default Re: Re: Re: how quiet can a cuda get?
Shim the one way gear all the way over and shim the bevel gear so there is not any for and aft play in the gear..and then see how free they are... there is a few more things you can do to free up the drive train..but start with this 1st
-Dave
JDM_DOHC_SiR is offline
Old 09-05-2004, 10:27 PM
  #12558
chappi's Avatar
Trader Rating: 17 (95%+)
Poop,
oh, you are in the setting stage of the chassis! good on you!
When I building the ball diff, on saturday nite, I tide the screw too tided and break the Diff screw in 2 piece!!!!!
Now I am ordering it online! dam! dont know how long i am going to wait for just a tiny screw to arrive!
Too bad We cant find any spare parts for barrcude in Aus.
By the way, Poop after you have figuare it out how many shims need 2 go to which part, can you please tell me ? this will be a great help for me.
Cheers!
chappi is offline
Old 09-05-2004, 10:28 PM
  #12559
Talking Orange paint jobs
Hey guys here is what I painted up this weekend..
-Dave
Old 09-05-2004, 10:31 PM
  #12560
Thumbs up Chevron GT350
Here is the GT350 I painted also
-Dave
Old 09-05-2004, 10:33 PM
  #12561
Default Re: Chevron GT350
-Dave
one more
Old 09-05-2004, 10:39 PM
  #12562
Originally posted by Herminator
I believe the suspension arms have about 1.5-2 degree toe in built into them. Then the stock rear hubs add another 2 degree's, as the kit built per instructions has around 3.8 degrees total.
If you're getting 4 degrees when using 1 degree hubs then it sounds like you have the hubs on the wrong sides
I'm not sure about the mid span arms though, they've probably got the same built in toe as the long ones.
No herminator i have them on the right way
If i put them on the opposite side then that only gives me 1deg on each side
Nick Simpson is offline
Old 09-05-2004, 10:50 PM
  #12563
Default Re: Re: Chevron GT350
one more
Protoform Nemmisis
Old 09-05-2004, 10:51 PM
  #12564
Default Re: Re: Re: Chevron GT350
Protoform Nemmisis
Old 09-05-2004, 10:53 PM
  #12565
Default Re: Re: Re: Re: Chevron GT350
Old 09-05-2004, 10:58 PM
  #12566
The Chassis has 1.5~1.8 of toe in built into the chassis on the rear sus arm mount locations... if you have the 1 deg hub you should have anywhere from 2.5~2.8 deg toe in.. if you have the 2 deg hub you`ll be in the 3.5~3.8 Range..
if you are still haveing problems..check to see if the Black sus arm balls are bent.. this will through ..everything off a bit
-Dave
Old 09-06-2004, 12:38 AM
  #12567
Default Re: Re: Re: Re: how quiet can a cuda get?
Originally posted by chappi
Poop,
Cheers!
no worries mate. from the look of things, i will need another .2mm shim for both the one way and the ball diff. i have already put the kit shims on one side to push it away from the 16T bevel but need more.
from the look of the 16T, it doesnt have much (if any) for and aft play...i'll need to take a better look.
damn shame you broke that screw...if only you were in Brisbane, i have spares.
poop is offline
Old 09-06-2004, 12:44 AM
  #12568
-Dave
Thanks Dave.
could you give me all the tips at once pretty please???
I'm going to take the whole car apart so that i can shim the gears properly plus flush out the bearings. what else can i do to free the drive train whilst everything is apart again? i want to be able to bring the car to its first meeting and make everyones jaw drop
thanks for all your help mate
poop is offline
Old 09-06-2004, 12:46 AM
  #12569
GTO2's Avatar
A picture is worth a 1000 words... ..one clue...look at the upper 2 mounting holes at the front and rear .. I know what this item will be for I`ll let you all guess for a little while
-Dave
is this center backbone for upper deck? Should be a belt one looking at the way the motor mount. holes are
It couldn't be a belt conversion kit for R3 would it?
GTO2 is offline
Old 09-06-2004, 12:51 AM
  #12570
GTO2's Avatar
-Dave
show off
awesome dude.
GTO2 is offline
