Alex Racing Barracuda R2 & R3 >
Like Tree4Likes
Old 09-03-2004, 12:36 AM
  #12496
Default UK Nationals
Good luck at the UK Nationals to the Centre Point guy's with the R3s this weekend, the Stock and Super Stock are at Barham and the Modified at Ashby. First time out with the car at a National for Dan Watson in modified, so we will see what he can do.
anton is offline
Old 09-03-2004, 01:12 AM
  #12497
BlueisBetter's Avatar
good luck anton and good luck Nick ps cya all at jubilee arena
with them brushes nick
BlueisBetter is offline
Old 09-03-2004, 02:48 AM
  #12498
Speed Demon's Avatar
Default Re: Speed Demon
Originally posted by Gazza_D
You dont mention weather you have tried the mid span arm set, if you havent then this would be a good investment and will go quite a way to gaining that elusive corner speed through the infield sections
Keep plugging away, it will be quicker
Nope, not yeat, I am still using the long span arm but changed to the graphite type... so the fles is very minimal compared to the stock ones...
Well, I might give it a try later when my wallet is topped up again... already spend a lot to prep for the race this sunday here.. my first race with the R2... previously I race with Pro 4.
Speed Demon is offline
Old 09-03-2004, 06:20 AM
  #12499
Trader Rating: 27 (100%+)
Default PLEASE HELP!
I am in the proccess of building my R3 but i have run into a problem i bought the R2 centre one way for it but it seems that the shaft is not too long to fit! what should i do? should i cut the carbon shaft??? there must be a way to make it fit as i was assured that it'll work on an R3
thanks all
poop is offline
Old 09-03-2004, 06:36 AM
  #12500
Herminator's Avatar
Default Re: PLEASE HELP!
thanks all
who told you it would fit?
as I recall, Dave said some time ago that it wouldn't fit.
whats wrong with just using a one way diff?
Herminator is offline
Old 09-03-2004, 06:39 AM
  #12501
Default Re: Re: PLEASE HELP!
i remember that Dave said it would and is good on the R3... guess i made a mistake
i wanted the centre one way because where i race, one ways work best and centre oneway would just make it even better
oh well...
poop is offline
Old 09-03-2004, 06:46 AM
  #12502
Default FOUND IT!!
Originally posted by JDM_DOHC_SiR
Yes the center oneway works with the R3. very fast cornering speed
also the R2 hubs and knuckles will work with the R3 the stabilizers are the same... the mounting hardware is different between the R2 and R3.
-Dave
hi Herm:
found this a few pages back...had me worry there for a bit thinking that it might have been a figment of my imagination. there must be a way that it'll fit...unless Dave isn't as knowledgable as we think he is....hmmmm....nah! no way! he has all the answers for cudas!
poop is offline
Old 09-03-2004, 06:53 AM
  #12503
Herminator's Avatar
maybe Dave's been at the Saki
maybe it does need trimming though, I thought length was the issue mentioned before.
Old 09-03-2004, 07:00 AM
  #12504
yummmmm sake.....
well, once Dave can confirm this, then out comes the grinder
poop is offline
Old 09-03-2004, 08:41 AM
  #12505
chappi's Avatar
Trader Rating: 17 (95%+)
yummmmm sake.....
hey! Poop!
Where do u race?
I live in Sydney as well. I also building a R3 atm, Just finishing clean those bearing. starting to build the diff, tommrow.
wht does a centra 1-way look like?
chappi is offline
Old 09-03-2004, 12:52 PM
  #12506
stjerno's Avatar
Steve:
What happend to the spool for the Cuda ?
Can someone confirm for me that a spool works the same way as a locked diff ? And won't it just make your car wanner go straight no matter what ?
Indoor season =all night carpet action .. NOW
stjerno is offline
Old 09-03-2004, 01:23 PM
  #12507
Herminator's Avatar
Originally posted by stjerno
Steve:
Indoor season =all nicht carpet action .. NOW
spool is the same as a locked diff, just a locked diff is a way of making a spool from parts you already have.
I've never used one, don't want to put my drivetrain through the abuse but from what I understand, they make the car understeer into corners a bit so you have to be aggresive and get the rear end to swing around, then they pull very well out of corners (just like a one way), with all the steering you could need.
Old 09-03-2004, 01:32 PM
  #12508
stjerno's Avatar
So they give steering out .. how about mid corner steering ? What about cornerspeed compared to both diff and one-way
stjerno is offline
Old 09-03-2004, 01:35 PM
  #12509
Herminator's Avatar
As I say I've never used one but I think you gain speed because you arrive very fast into a corner then can slam on the brakes, then at mid corner you can give it lots of power and pull the car out of the corner hard.
It's commonly agreed that on most good sized tracks that a one way is still the fastest option though, but the tighter a track the more a spool would help.
Old 09-03-2004, 01:39 PM
  #12510
stjerno's Avatar
Ok, thanks Herm..
Guess all I need is a couple of hours at the lathe with a pices of aluminum and a complete diff set for the cuda to use as a model.
Can then use the delrin outdrives and the gear from the diff set and have a lightweight spool in a days time
Now where do I find a lathe
stjerno is offline
