Alex Racing Barracuda R2 & R3 >
Old 08-31-2004, 05:18 AM
  #12451
What's the main diference on the R2 and R3 ........ any body??
johnla is offline
Old 08-31-2004, 05:24 AM
  #12452
stjerno's Avatar
Steeringrack and motormount.
Rest is minor.
stjerno is offline
Old 08-31-2004, 05:33 AM
  #12453
Speed Demon's Avatar
finally... thanks for the picture Dave... at least I have installed mine correctly just like what you did... cheers...
Speed Demon is offline
Old 08-31-2004, 06:03 AM
  #12454
Crashmaster's Avatar
Hi guys,
When you run the R2 without the gear covers, does the top deck have to bend around the steering posts?? It does on mine, and I'm not to sure if its ok like that or what.
Cheers
Crashmaster
Crashmaster is offline
Old 08-31-2004, 06:26 AM
  #12455
Originally posted by Crashmaster
Hi guys,
Cheers
Crashmaster
No...no...no... that's not suppose to happen... I think ,when you run without the diff cover, the steering post should be replaced to the shorter one.. they sell it as option...
Old 08-31-2004, 09:18 AM
  #12456
Herminator's Avatar
Yep there's a shorter post set made exactly for this reason
Or you could grind down your old posts but thats a hassle and then you can't go back to running covers if needed.
Herminator is offline
Old 08-31-2004, 09:21 AM
  #12457
Herminator's Avatar
Default Re: One shot of me at Yatabe
Originally posted by JDM_DOHC_SiR
Here is one of the only shots that came out..sorry guys the wife had the camera..and most of the shots were without a flash
-Dave
Different shell to your trademark scheme Dave?
simple but effective still shows up well in the dark
The track looks nice there, wish I could get over to Japan and race, I'll have to settle for some Florida racing instead around x-mas time possibly
Old 08-31-2004, 09:31 AM
  #12458
Cool, thx guys. Looks like another thing to add to the to buy list
Cheers
Crashmaster
Old 08-31-2004, 12:13 PM
  #12459
FUK_WRX's Avatar
Default General Question
Guys do the diff covers come with the R3?
And do the R2 arms fit the R3?
What are the part numbers for the Fr and Rr suspension arms and diff covers(if inlcuded in kit).
Thanks for your time.
-Luie
FUK_WRX is offline
Old 08-31-2004, 01:58 PM
  #12460
Herminator's Avatar
Default Re: General Question
-Luie
No, you don't get diff covers with the R3, they won't fit the newer style bulkheads without some modification.
Just run without them, unless you find you're having serious problems of messing up gear due to small stones. I've run in barely swept car parks and never had a bad problem without the covers. You'll loose a few gears every now and again but not a lot.
The suspension arms are the same, find parts numbers on speedtechrc.com
Old 08-31-2004, 02:03 PM
  #12461
JDM_DOHC_SiR's Avatar
Trader Rating: 31 (100%+)
Default Re: Re: One shot of me at Yatabe
Thanks Hermi.... The Track was kind of dark that day.... and my eyesight is not the best ... I usually use my Simple "paint" bodys for Qualifing and my "GOOD" bodys for the Mains
-Dave
JDM_DOHC_SiR is offline
Old 08-31-2004, 02:08 PM
  #12462
FUK_WRX's Avatar
Default Re: Re: General Question
Thanks very much..
FUK_WRX is offline
Old 08-31-2004, 02:30 PM
  #12463
pumpkinfish's Avatar
Not quite sure on the Pink Caps from Tech... but Xenon Makes pink transponder mount for the Barracuda..also SpeedWay PAL does too
-Dave
Dave,
Where can I order any of this? I have never seen them listed on a website. Please help...
pumpkinfish is offline
Old 08-31-2004, 03:15 PM
  #12464
Originally posted by pumpkinfish
Dave,
I belive that Speedtech can get them since he is a Dealer for Xenon and PAL.... E-mail Steve to find out... it might take 2 weeks to get the parts that you want.. but He should be able to get them..
-Dave
Old 09-01-2004, 12:34 PM
  #12465
Gazza_D's Avatar
Woh on page 2 again!!! It sure is quiet round here
Does anyone know if there were any Cudas at the US KO GP last weekend and if so where did they finish?????
A year seems such a long time ago when DB won there
Gazza_D is offline
