Old 08-28-2004, 02:50 PM   #12391
rcsabah's Avatar
agreed.. my only problem is the one way bearing.
is the 4 pieces bearing durable???
rcsabah is offline   Reply With Quote
Old 08-28-2004, 06:09 PM   #12392
OVA
OVA's Avatar
Trader Rating: 79 (100%+)
Default Re: Re: One way diff... Try this!?
Originally posted by Herminator
Why would you want to?
It just adds rotating weight, the Cuda gears are strong enough without it.
I agree
I have not failed. I've just found 10,000 ways that won't work
OVA is offline   Reply With Quote
Old 08-28-2004, 06:31 PM   #12393
JDM_DOHC_SiR's Avatar
Trader Rating: 31 (100%+)
Yes the 4 bearing one way is very durable I have yet to destroy one
-Dave
Ȼ4.5 Centro+α ◊ TRF 501ӽ ◊ TRF 502ӽs ◊ TRF 503 ◊ TRF 511 ◊ TRF 201ӽr ◊ TRF 211ӽ
B5m ◊ T5m ◊SC5m ◊ B64deez nutz
Speedway PAL ◊ SDRC ◊ Shop UFO ◊ SMC
JDM_DOHC_SiR is offline   Reply With Quote
Old 08-29-2004, 12:06 PM   #12394
hi guys
i need to know the difference between the r2 shock towers and the r3 towers???
thasnk jimmy
ps i have a mod to try??
Team AME/Orca
jimmy_maddison is offline   Reply With Quote
Old 08-29-2004, 12:26 PM   #12395
John_S's Avatar
hye peter iw as surprised to not see you at stoney cuz you are not counted for the smtca champs now. And we have another centre point driver in scotland got the r3 now .
Are you doin the scotish carpet nats pete?
John_S is offline   Reply With Quote
Old 08-29-2004, 12:34 PM   #12396
TC3
TC3's Avatar
Default Re: Re: Re: Re: Re: Re: Re: 6.8mm offset ball
Originally posted by JDM_DOHC_SiR
With a Buffing wheel and Metal Polish compound... they look like shiny Brass now
i tryed to polish them wit ha dremel ans metal polish compund, but they wont get real shiny. how long did it take until they were realy smooth?
did u polish the black alloy ones too?
TC3 is offline   Reply With Quote
Old 08-29-2004, 12:39 PM   #12397
TC3
TC3's Avatar
Default Re: Re: Re: Re: Re: 6.8mm offset ball
Yes use the upper deck outer holes.. you will also notice that the car will not feel as lazy in the corners
-Dave
i tried the mid spawn arms today.
they give more mid corner steering.
the car doesn't lose as much speed in thigt corners.
with the long spawn arms i allways had to slow down too much in 180 turns.
i like the mid spawn arms
Old 08-29-2004, 12:44 PM   #12398
TC3
TC3's Avatar
i second that !
the barracuda oneway gear is really strong !!
Old 08-29-2004, 12:52 PM   #12399
TC3
TC3's Avatar
Originally posted by jimmy_maddison
hey sorry ive not been around i have been real busy at work...
well set up tips.......
i have done lots of festing with the car and the main difference that made the car good or real bad was shock build this car responds real good to set up changes!
my starting set up is
yoko orange springs all round
50wt oil with hpi number 3 pistons
3 deg toe in (rear)
0 front
camber 1 deg all round
short front camber link on toip deck and mid at rear
low holes all round in rear and fron hubs
0.5mm roll center lifted this gave more direct feel to the car and it didnt roll as much..
shock postions were outer most hole at front and 2nd from outer at rear and this is with a oneway...
bodyshell i use an ing magnus..
thanks jimmy
thx for sharing
that is really diffrent from my setup.
i never use 50wt oil with hpi #3 pistons.
outdoors with rubbers i run sth like 40wt oil with hpi #2 pistons.
springs usualy around 1,4 x5,50 or 1,5 x 6,00
with mazda body of course..
i sometimes use swaybars up to 1,6mm in front to reduce roll.
i should do some testing with higher rollcenter in front, but changing swaybars is done quicker
Old 08-29-2004, 03:19 PM   #12400
hi guys
thasnk jimmy
The difference in the rear tower is just the hole spacing were the bulkheads mount to ..everything else is the same
now for the front tower ... . .the R3 tower has one less mounting hole going out.. and the spacing is different for the mounting to the bulkheads.. about 2mm closer together than the R2 towers..
What are you tring to do.... Use the R2 tower on the Front...
Been there... there is a comapany that is making 3mm front towers with more shock palcement holes right now... but I'm sure that you will come up with something too
-Dave
Old 08-29-2004, 03:21 PM   #12401
Default Re: Re: Re: Re: Re: Re: Re: Re: 6.8mm offset ball
Nope I just polished the Offset one's
It took me about 10 mins to buff them out.. and I did not touch the Black ones
-Dave
Old 08-29-2004, 03:22 PM   #12402
Default Re: Re: Re: Re: Re: Re: 6.8mm offset ball
Once you start to use them you"ll never go back unles you have a very flowing track
-Dave
Old 08-29-2004, 03:28 PM   #12403
Herminator's Avatar
Send a message via ICQ to Herminator
I should still have four out of six rounds so have the points to count for the championship but it wasn't really worth the trip up after some of the scores I have.
It's a 6 hour drive now so I would have had to stay overnight and spend a fortune on fuel too (over 80p a litre bloomin rip off)
Saving any racing funds for one last outdoor race this summer, the Cumbria GP in 2 weeks time
Only 1.5 hours drive to Carlisle and I know my car should go well, it's not been touched since my last race which was the Carlisle SMTCA round
I may even splash out on my second set of new CS22's this season, if things are going well and they're needed
At Carlisle new CS22's seem to give a good edge if you can afford them and don't over work them, as half the track is usualy shaded from the big tree behind the rostrum. They soon loose the ability to stay good enough for a whole 5 minutes though.
Herminator is offline   Reply With Quote
Old 08-29-2004, 03:29 PM   #12404
pm dave
Team AME/Orca
Old 08-29-2004, 03:31 PM   #12405
Herminator's Avatar
-Dave
Looks like I'll have to arrange a little order of parts in the next month, a new diff and some mid span arms B'days are handy sometimes
WTB Alex Racing Barracuda R2 & R3 Funkymojo R/C Items: Wanted to Buy 3 02-03-2007 01:00 PM
alex racing barracuda con81 Electric On-Road 1 12-14-2005 03:36 AM
WTT: Alex Racing Barracuda R2 for PS2 AZ_Ron Other Items: For Sale/Trade or Wanted to Buy 0 02-13-2005 07:30 PM
Alex Racing Barracuda R3-New. rcracing1973 R/C Items: For Sale/Trade 9 04-11-2004 08:29 AM
Alex Racing Barracuda Bugs Bunny Singapore R/C Racers 6 01-22-2003 11:47 PM
