Alex Racing Barracuda R2 & R3 >
Old 08-23-2004, 05:55 AM
  #12331
Herminator's Avatar
LOL, I thought you were on about some strange new material when you said rubber vice alloy
Almost invisaged a rubbery main shaft, would create weird power delivery
Hmm, sounds like pretty much a new car
All I can see them using is the suspension, bulkheads and delrin diffs with pulleys instead of gears, cvd's too of course.
Any idea if it will be single or double belt?
Will it be Tamiya 415 and Schumacher style with the motor hanging out one side or X-ray mid motor with saddle packs?
It obviously won't be cheap, new alloy motor mount, new top deck and main chassis, layshafts and pulleys. Would be awfully painful to buy a whole cuda to use for parts, maybe they'll release it as a whole kit.
Soon it will be like Tamiya, having two car concepts at the same time.
But the big question is....
.... how long before Dave buys one, or several?
Herminator is offline
Old 08-23-2004, 08:00 AM
  #12332
Speed Demon's Avatar
what???? Barracuda going belt???? ummm... can't wait!!!!
Speed Demon is offline
Old 08-23-2004, 08:41 AM
  #12333
well ive not herard about this............
mmmmmmmmmmmmm
jimmy
jimmy_maddison is offline
Old 08-23-2004, 08:43 AM
  #12334
stjerno's Avatar
Everybody hold your horses
Dave said Xenon was working on something .. Xenon is NOT Alex
But it would make the Cuda a one of a kind, kind of car
mmmmmmmmmmmmm
jimmy
stjerno is offline
Old 08-23-2004, 01:01 PM
  #12335
yes and all im saying is ive not heard of this and im also drive for xenon....
jimmy
Old 08-23-2004, 01:52 PM
  #12336
JDM_DOHC_SiR's Avatar
Trader Rating: 31 (100%+)
the reason that You have not heard about this is because "nobody" is suppose to know about it ..
-Dave
JDM_DOHC_SiR is offline
Old 08-23-2004, 04:59 PM
  #12337
WINK WINK (I think that's what Dave is trying to say)
NismoSkyline17 is offline
Old 08-23-2004, 06:07 PM
  #12338
OVA
OVA's Avatar
Trader Rating: 82 (100%+)
I can't wait. see the new car
OVA is offline
Old 08-23-2004, 07:09 PM
  #12339
Yep
Old 08-23-2004, 08:22 PM
  #12340
Default Free drive train..
how do you guys "free" the barracuda drive train?? I have the R2 but it's is not as free as my Pro4 drive train..
How much horizontal play we should have on the drive shaft??
thanks...
Old 08-23-2004, 08:45 PM
  #12341
Default Re: Free drive train..
thanks...
The Pro4 needs less out of the Box to have a awesome trive train... but the Cuda can be made to be just as good if not better... one thing on the cuda that is important it the shimming of the Bevel gears and Prep work on the ring/bevel gears
I posted quite a bit of info on how to do this a few pages back ... On average you should get 7-10 seconds on a normal preped Cuda.... One that is preped and had all of the little tricks done to it can be anywhere in the 10-18 seconds
anything more than this and you would have had to spin the Sh!t out of the wheels
-Dave
Old 08-24-2004, 01:37 AM
  #12342
Lotus111's Avatar
Default Re: Re: 6.8mm offset ball
Originally posted by JDM_DOHC_SiR
I my self use 6 of set 6.8mm balls 4 in the front and 2 in the rear
in the front I have them set for maximum sus arm toe out.. make the cuda much more predictable
-Dave
Dave,
what is the exact difference in the Handling from "normal" Toe-Out to the one with the Suspension. Is it in the end not the same?
Lotus111 is offline
  #12343
Soon as I find out more I`ll post it..
-Dave
Old 08-24-2004, 02:05 PM
  #12344
TC3
TC3's Avatar
Default Re: Re: Re: 6.8mm offset ball
Originally posted by Lotus111
Dave,
i don#t like the offset balls because they cause mor friction than the normal black ones.
question:
should i use the outer camber link holes on the top deck when useing the midspawn arms? (without pal hubs)
i will try the midspawn arms soon
TC3 is offline
Old 08-24-2004, 02:35 PM
  #12345
Dave,
I like to use the toe out on the front sus arms because the car has much better turn in feel
-Dave
