Old 08-09-2004, 05:24 AM   #12151
Dave ... which Xenon based 23T you prefer?
dhiracing.com is offline   Reply With Quote
Old 08-09-2004, 05:30 AM   #12152
JDM_DOHC_SiR's Avatar
Trader Rating: 31 (100%+)
Originally posted by Herminator
Isn't this a vectra you've painted already?
The grill is nice but I'm not sure about the triangular headlights, I prefer something atleast close to the original shape on any shell. Half the time it's the only way you can tell what car it's meant to be
Nope thats a ALEX Verrosa Body but if you look on another thread I did post the pic of the Vectra
-Dave
Ȼ4.5 Centro+α ◊ TRF 501ӽ ◊ TRF 502ӽs ◊ TRF 503 ◊ TRF 511 ◊ TRF 201ӽr ◊ TRF 211ӽ
B5m ◊ T5m ◊SC5m ◊ B64deez nutz
Speedway PAL ◊ SDRC ◊ Shop UFO ◊ SMC
JDM_DOHC_SiR is offline   Reply With Quote
Old 08-09-2004, 05:39 AM   #12153
Originally posted by dhiracing.com
Xenon makes 4 different types of new 23T stock motors ...
- High Torque - Standup Hoods
- High Revs - Standup Hoods
- High Torque - Laydown Hoods
- High Revs - Laydown Hoods
For the moment they are with bushes, however the ones with the bearings should be coming out soon ...
Dave maybe can give you more technical data
Basically Xenon has the 4 new ones
Midori or Green Dot Laydown 3mm core 3port Rotor with 9mm comm and laydown brushes..more of a torque based motor.? kind of a weird one..
AKA or red Dot Laydown 3mm core 3port Rotor with 9mm comm and laydown brushes..more of a torque/rpm based motor.?
Ao or Blue Dot Standup 3mm core 3port Rotor with 9mm comm and standup brushes..more of a torque based motor but more efficent on amp draw.?
Kin or Gold Dot Standup 3mm core 3port Rotor with 7.5mm comm and standup brushes..more of a Hi torque based motor... my personnal favorite
-Dave
Old 08-09-2004, 05:59 AM   #12154
nope but this one is
http://www.rctech.net/forum/attachme...postid=1028880
Old 08-09-2004, 07:12 AM   #12155
babytoy101's Avatar
Default sus. arm question!
which suspension arms can be use for a tight short asphalt track, long or short arms?
and can i combine like short arm in front and long arms in the rear!
babytoy101 is offline   Reply With Quote
Old 08-09-2004, 08:34 AM   #12156
Herminator's Avatar
Send a message via ICQ to Herminator
-Dave
oops, linked to the wrong one meant to link to the one you just did below
Herminator is offline   Reply With Quote
Old 08-09-2004, 11:32 AM   #12157
Crashmaster's Avatar
Can any one help me with the noise issue??
Cheers
Crashmaster
Crashmaster is offline   Reply With Quote
Old 08-09-2004, 01:17 PM   #12158
i think some one on here said to take the diff/dirt covers off
Chazz is offline   Reply With Quote
Old 08-09-2004, 01:18 PM   #12159
to make it less noisey
Old 08-09-2004, 01:57 PM   #12160
Anyone had problems with stones etc when the diff covers are removed??
Cheers
Crashmaster
Old 08-09-2004, 03:35 PM   #12161
Herminator's Avatar
Originally posted by Crashmaster
Hi again.
I was wondering if anyone could help me, but the drive train on my R2 seems a tad noisy. I know that recently someone asked a similar thing, and JDM_DOHC_SiR said to look around 60 pages back. I did have a look, but couldn't find it. Can anyone give us a hand??
Cheers
Crashmaster
The Cuda has always tended to be louder than other tourers but you can do some things to quieten it down.
Shim the diffs more to one side to make the mesh looser.
Shim the small bevel gears so they have no back and forth movement in the shaft holders.
New gears run in with a slow motor on a few volts.
Remove the diff covers, they make a noisey car sound like a tractor.
I run without the gear covers all the time and stones are not a big problem. I get the occasional tiny stone stuck in gear teeth but a quick look to see where it is then flick it out with a screw driver and everything is fine. You just end up with a few chewed up gears, but the Cuda gears are beefy enough to run fine with a few chunks out of them. I've had stones in gears even when running the covers and then it's a pain in the backside to get to the problem, you're not even sure if it's the front or rear so end up dismantling half the car
Shimming the diffs is a bit of an art I find, a big part of making things quiet. One shim too few and it may seem like there is minimal play but it will still be noisey. One shim too many and it will have no play but still spin fairly freely (not as free as it should be though) and it will again be noisey. So you need to take the bulkheads off and on a few times and use trial and error.
Maybe Dave will be nice and find the pic he had of the small bevel gears, showing the differeces that meant different shimming for each and he can tell us the thickness of shims he uses for each while he's at it
I tend to guestimate these at the moment, since taking them apart without damage is a pain, when they're in the shaft holders they stay there until they're deformed and ready for the bin
(oddly though I have a nice little collection of used bevel gears, I don't know why I keep so many "emergency backup" spares it's the same with spurs and stripped thread steering knuckles )
Old 08-09-2004, 03:58 PM   #12162
I found my pic`s I`ll post them in a few mins` I have to get them of the other Computer
-Dave
Old 08-09-2004, 06:12 PM   #12163
-Dave
Here they are
These are two different type of gears the one on the left needs more shims than the right one
-Dave
Old 08-09-2004, 06:14 PM   #12164
Here they are
-Dave
Pic of gear being shimed
Old 08-09-2004, 06:16 PM   #12165
Kyosho shim set that you`ll need comes in .1/.2/.3mm sizes
WTB Alex Racing Barracuda R2 & R3 Funkymojo R/C Items: Wanted to Buy 3 02-03-2007 01:00 PM
alex racing barracuda con81 Electric On-Road 1 12-14-2005 03:36 AM
WTT: Alex Racing Barracuda R2 for PS2 AZ_Ron Other Items: For Sale/Trade or Wanted to Buy 0 02-13-2005 07:30 PM
Alex Racing Barracuda R3-New. rcracing1973 R/C Items: For Sale/Trade 9 04-11-2004 08:29 AM
Alex Racing Barracuda Bugs Bunny Singapore R/C Racers 6 01-22-2003 11:47 PM
