Alex Racing Barracuda R2 & R3 >
Old 08-07-2004, 07:13 PM
  #12106
JDM_DOHC_SiR's Avatar
Trader Rating: 31 (100%+)
Arrow A little Red and Pink
Something more along the Japanese style
-Dave
JDM_DOHC_SiR is offline
Old 08-07-2004, 07:15 PM
  #12107
Default Re: A little Red and Pink
-Dave
Old 08-07-2004, 07:17 PM
  #12108
Default Re: Re: A little Red and Pink
Old 08-07-2004, 09:15 PM
  #12109
GTO2's Avatar
Cool 11 times...
Very original & professionally done! What can I say,
Good job Dave. Might hookup with ya if I need one
GTO2 is offline
Old 08-08-2004, 12:53 AM
  #12110
Originally posted by GTO2
Cool 11 times...
Thanks... hit me up if you need something painted
-Dave
Old 08-08-2004, 04:37 AM
  #12111
Default FOR SALE LAST TIME
Hey Guys
Im selling a Alex racing barracuda the PINK version R2
Its about 8 months old and it is in good condition
The HOT UPS parts include
*Ti-screws every single one
*Ti-turnbuckes( with wrench)
*brand new ball diff and Delrin outdrives
*Ti nitride pivot balls ( the off set ones)
*Adjustable Aluminum Hex Hub adapters front and rear(blue)
* Long-Span, oversized suspension A-arms
*team losi e clips though out]
*hard shafts on the suspension arms
*brand new front shock tower
The SPARE PARTS are
*new diff gear
*new bevel gear
*Alex racing e clip set
*new front axle
*2 new universal join sets
*new body post set
*new c hubs
*1 new rear upright
* heaps of spare parts also included e.g spurs and pinions, shock oils and much much more
Since i have added these new hot up parts the car has never been in a race but before that it has . The car is very solid and build to last
Make me an offer my calling me on 0431 483 979 or just add a PM
mr barracuda is offline
Old 08-08-2004, 10:31 AM
  #12112
Lotus111's Avatar
Angry Rear Toe in
Hi all
Need some advice on my little problem i have with my Rear Toe In
I have on my left side 3 and on my right sight 2 Toe In => so far not to bad but:
Im using already the uncentered ball studs: on the left ajusted to have the Min. Toe In and on the right to have the Max Toe In
I have put new suspension Arms, new rear hub carrier in to see if any of these are bend or damaged, but still the same difference in the left and right side
Any ideas ?
thanks
Lotus111 is offline
Old 08-08-2004, 10:36 AM
  #12113
John_S's Avatar
have you adjsuted both the balls on the same arm or just 1 , and are you measuring it from the wheels because possibly the wheels are buckled
John_S is offline
Old 08-08-2004, 10:47 AM
  #12114
Lotus111's Avatar
Hi
I have adjusted both ball studs, and im messure the toe In with the Integy setup tool with should be one of the most exact ones.
Any other suggestion
Lotus111 is offline
Old 08-08-2004, 10:59 AM
  #12115
Crashmaster's Avatar
Hi guys.
Just had my first rin with a R2 today (or atleast the euro version (TrioX). All I can say is WOW!!! From a TC3, this thing just feels so planted, even with the standard setup Can't wait to get racing with this thing!!!
Cheers
Crashmaster
Crashmaster is offline
Old 08-08-2004, 11:07 AM
  #12116
Herminator's Avatar
Hermi Don`t change your car to the PAL Hubs if it`s working good Also by Changing over to the PAL hubs with Merciless` Mod Bulkheads I was able to drop over 25 grams off the car ...over the Xenon Hubs Talk about shavingsome weight off the Cuda
-Dave
Well the Cuda went pretty well today, first round I was fasted in my heat and beat last years FTQ by 2 seconds, getting my first proper 18 lapper There was one guy in the heat before me though who was flying all day and went 10 seconds faster aparently he loves spending lots of time getting the perfect setup, he certainly had it today, good cells and motor too
The car didn't quite feel so good in the second and third run, the sun was out more and this seemed to make the rear tyres slide a bit mid corner, which scrubbed a lot of speed.
Last qualifier the sun went behind some clouds and I moved the rear shocks out one hole on the shock tower, since they were pretty leant over. The car was back to going round the fast sweeper well but still slid out on the hair pin a bit. I managed to go about a second and a half faster and climb two spaces on the grid. Ending up 4th, less than two tenths behind 3rd who was 2 seconds behind 2nd. The pole guy was 8 seconds ahead though and squeezed in a 19 lapper in his last run Thats modified kind of lap times
The final wasn't great, the first lap and at the first hairpin I tapped the back of a friend who was 3rd I took the corner just a bit too well and had more speed and a tighter line as we exited, it was his bit of road but I couldn't really brake with the one way, I did let off but I guess my drive train was too free after this weeks work I came out 5th and my frined was near the back after then loosing out a bit on the next corner too. He did well to come through the field but I was running pretty much the same lap times as the guys ahead of me so couldn't catch up, then on the last lap I made a small mistake and my mate got past me I was right on his tail as we crossed the line but I suppose it's fair he beat me.
The setup I have seems to be good in the fast stuff but I loose time to others in the slow corners, I suppose it's a compromise but on the often twisty tracks up in Scotland I loose out more than I gain. At Carlisle I had a nice advantage in the end of straight sweeper and chicane which can be taken flat out, since I was using the one way.
The Alfa got it's first use today Dave, plenty of people admiring it, one comment was "it's a cracker" It's handy that the Alfas seems to be the best shell I've found for Carlisle, helps get into the corners
Herminator is offline
Old 08-08-2004, 11:14 AM
  #12117
Herminator's Avatar
Originally posted by Lotus111
Hi
Are you sure you don't have an incorrect hub on one side?
Old 08-08-2004, 11:16 AM
  #12118
Herminator's Avatar
some pics of the day
my car after it's first qualifier...
Old 08-08-2004, 11:17 AM
  #12119
Herminator's Avatar
the start of the modified A final, 1st to 4th cars shown.
Old 08-08-2004, 11:18 AM
  #12120
Herminator's Avatar
the last one, I think this was 3rd and 4th at the time, the car behind was also running 19Spec, the guy who got the 19 lapper
