Alex Racing Barracuda R2 & R3 >
Old 08-04-2004, 02:57 PM
  #12016
Turbonium's Avatar
Trader Rating: 27 (100%+)
aren't the Alex shims .01 mm? Tamiya 10mm set has some that are .01 and .03mm. i think Yokomo has some too.
http://64.70.208.72/speedtechrc/320.html
Turbonium is offline
Old 08-04-2004, 03:02 PM
  #12017
Herminator's Avatar
trust me not to look in the easiest place
thanks
Herminator is offline
Old 08-04-2004, 05:56 PM
  #12018
JDM_DOHC_SiR's Avatar
Trader Rating: 31 (100%+)
Originally posted by Herminator
I waited a day before asking again are you colouring in the pixels by hand?
not really
JDM_DOHC_SiR is offline
Old 08-04-2004, 08:16 PM
  #12019
Deves's Avatar
Hi all, I'm wondering if anyone can tell me what a good spring rate, or type setup for a asphalt parking lot would be? I raced my car ( stock r2) last weekend at an annual parking lot challenge and had pretty good speed down the straight but need to get through the infield faster.
I qualified 11th out of 30 and finished 5th in the B main, Hmmm maybe I need more speed too. Right now I'm using the stock springs with 30wt in the shocks and long span arms. Should I look for different springs I.E. Yokomo or Rayspeed? I like the idea of being able to easily identify the springs, so maybe the Alex springs aren't the best choice for me. Should I invest in mid span arms?
Also what's a good gear combo for a 27 turn stock motor. I'm using a 72 tooth spur and 25 to 28 pinion but my choices are limited with this car. I know alot of you guys probably run mod but maybe somebody reading this has a good idea. If I can get my car working faster then I wouldn't have a problem running 19 turn or mod.
Thanks for reading,
Deves is offline
Old 08-04-2004, 09:34 PM
  #12020
COLEKO's Avatar
Im racing with the R3 but for gears im using 48 pitch 70 tooth Xenon spur with 24 to 25 pinion for a monster stock and a 21 pinion for Binary. sofar really good.
COLEKO is offline
Old 08-04-2004, 10:10 PM
  #12021
Deves's Avatar
coleko, which binary motor do you have the Quad mag or the roar legal version? if it's the quad doesn't your gear combo heat up motor considerbly?
Deves is offline
Old 08-04-2004, 10:19 PM
  #12022
COLEKO's Avatar
No heating issues with the quad Mag. But its sick fast with that gearing. Im racing this weekend and Ill temp it after my run for you... I race outdoor asphalt.
COLEKO is offline
Old 08-04-2004, 10:30 PM
  #12023
Deves's Avatar
You racing at La mirada Sunday?
Deves is offline
Old 08-04-2004, 10:41 PM
  #12024
COLEKO's Avatar
Ya ill be there
COLEKO is offline
Old 08-04-2004, 10:52 PM
  #12025
Deves's Avatar
Coleco YGPM
Deves is offline
Old 08-05-2004, 08:41 AM
  #12026
Car Breaker's Avatar
Default newbies question
I have been interest in Cuda for long
and have some question about this peice of art.
1. what is the pro and con of R2 and R3?
2 Can I convert R2 to R3 since many parts are interchangable?
3 if the answer for the previous question is positive, what parts do i need to change?
I have a R2 coming in. just want to know more about the car
thanks
Car Breaker is offline
Old 08-05-2004, 11:24 AM
  #12027
TC3
TC3's Avatar
Originally posted by seaball
dave,
the anti squat worked well. the car is rotating better than ever. if i could only get some rip out of it.
-chris
did u check ur diff if it is thight enough ?
or maybe the onway does slip ?
TC3 is offline
Old 08-05-2004, 01:20 PM
  #12028
hey guys
as any one had problems with the spool bind up on lock???
im sick of scratching my head about it??
thanks jimmy maddison
jimmy_maddison is offline
Old 08-05-2004, 02:13 PM
  #12029
Originally posted by jimmy_maddison
hey guys
Spool..??? want to expand on that Jimmy.?? then I might be a ble to help
-Dave
Old 08-05-2004, 02:21 PM
  #12030
Gazza_D's Avatar
Hi Dave,
Jimmy had a problem when running the spool on his R3. On full lock it was binding, very noisy and scrubbing speed like nothing else. Havent noticed the same problem on my R2 but I dont use anywhere near full lock.
Its almost like the outputs of the spool are 3 maybe 4mm too long!!!! as the bones sit snuggly much further in.
Any ideas
Gazza_D is offline
