Alex Racing Barracuda R2 & R3
Originally posted by poop
hi all,
i was wondering which one will be a better buy:
an R3 with option parts or the R2 orange limited edition?
does the R2 orange still need hop ups or is it fully hopped?
cheers.
hi all,
cheers.
-Dave
dave,
the anti squat worked well. the car is rotating better than ever. if i could only get some rip out of it.
-chris
-chris
Originally posted by seaball
dave,
-chris
dave,
-chris
-Dave
how many mm spacer for the anti squat
Originally posted by JDM_DOHC_SiR
The R2 Web Special has pretty much all the bells and whistles that you would need..?? minus a PAL drive system or a PAL A-spec chassis... but if you can find one that would be a ggod deal
-Dave
-Dave
just curious,... anybody use the gearbox dust cover that came with the r2??? Is there a reason why we dun have to use it???
In Malta ...
Noone uses the gearbox dust cover although we race on asphalt outdoors, firstly because since it is not completely sealed the gears will get bit dirtly just the same, secondly for quicker access and maintenance of gears, thirdly you can place extra weight to balance your car elsewhere and lastly because it seems with these covers the car makes slightly more noise
However matter of personal preference I guess
ic...
thanks for the advice
hey poop i personally wouldnt go for a web r2(exen tho it looks so cool) because they were a limited release of 100 and if you can find 1 you will be paying through the teeth for it and be strugling to find alloy spares in orange,you have to get them directly from alex racing i think
The car is quieter without them too, although mine is still far from quiet
looking at the r3 all i woudl say it needs is alloy shaft holders and a spoeedway pal steering rack to be competitive but u may also want some shiny bits for it
Does anyone know of some thicker shims, the same size as the diff shims but just a bit thicker. I'll need some new ones soon and rather than have to use three or four together a thicker one would be nicer, less prone to bending.
Yokomo do a good pack of smaller shimms that are perfect for the small bevel gears, each pack has three thicknesses in it. Maybe they do a larger version?
I will hopefully have a pic or two of something shiney to show folks here tomorrow
Dave, where are those paint job pics? heck use your phone camera if you have to
-Dave
I'm working on it Hermi' Hold on
-Dave
-Dave
