Alex Racing Barracuda R2 & R3 >
Like Tree4Likes
Old 07-26-2004, 01:11 AM
  #11851
Trader Rating: 27 (100%+)
Thanks for the info!
Now...to be a real pain in the ***, imagine that money is not an issue, what else would you buy along with the black r3 chassis kit? I've been with my tamiya for so long that i could probably quote product numbers off the top of my head but with an R3, i know nothing...i dont know what's in the kit, i cant find a manual to do some study on, i dont know what upgrades i can get, i dont know what companies makes option parts for an R3! all i do know is that i want one and buying one first and then buying optional parts later is going to cost too much money (international bank transfer fees etc) so buying in one hit is the preferred method for me . Could you guys possibly make me a list of things to buy for the ultimate R3 experience
poop is offline
Old 07-26-2004, 02:03 AM
  #11852
Merciless's Avatar
Just let Steve at Speedtech kow you want ALL the goodies he stocks the lot
Speedway pal hubs
Speedway pal steering rack
Mid spam arms + adjustable mounting balls front and rear
Titanium drive shafts
Titanium turnbuckles
Titanium Screw set
Alloy main shaft holders
Think thats about it but i'm sure some1 will be able to think of something else
Merciless is offline
Old 07-26-2004, 05:10 AM
  #11853
Speedway pal hubs
Titanium Screw set
who makes the mid span arms and balls?
and who makes the alloy main shaft holders? (aren't they already aluminium?)
thanks mate!
poop is offline
Old 07-26-2004, 05:56 AM
  #11854
Alex Racing themselves make the mid span arms, uncentred balls and the aluminium center shaft holders. However they are optional and do not come with the standard kit. With the kit you will have standard plastic arms and shaft holders.
If you decide to make an order from Steve of Speedtech, I am sure he will help you out. He stocks all hopups for the R3
dhiracing.com is offline
Old 07-26-2004, 11:55 AM
  #11855
COLEKO's Avatar
Default Rear Body Post
Is there any other rear body posts that I can use that has a wider stance for the R3? Im having a problem mounting a Nemesis body with the rear posts. The stock ones keep ending up to close to the wing mounts.
COLEKO is offline
Old 07-26-2004, 12:15 PM
  #11856
Turbonium's Avatar
sometimes i flip'em side to side, as they are offset. or, maybe put on the other side of the tower...
Turbonium is offline
Old 07-26-2004, 01:04 PM
  #11857
COLEKO's Avatar
Ya Ive tried diffrent combos but didnt like any of the results.
COLEKO is offline
Old 07-26-2004, 01:07 PM
  #11858
John_S's Avatar
you can try em onfront of the shock mounts if they dont hit your shocks. If they do you can get some that arent offset like the tc3 posts if that will be any better?
John_S is offline
Old 07-26-2004, 02:55 PM
  #11859
Herminator's Avatar
The Mazda 6 causes the same problem, just put them on the front of the shock towers and switch them over side to side so they're as wide as normal but further forward. You're unlikely to find any that will have a wider offset, the cuda mounting points are already quite wide at the rear.
Just so all the UK guys know (most will probably already know) it seems Centre Point (x x-ray distributers) are now distributing the Barracuda R3 in the UK and it's not rebadged as the Triox....
Maybe the size of Centre Point persuaded Xenon/Alex Racing to deal direct with a UK distributer, it's certainly more handy
Hopefully we'll have all the colour options and now the black chassis option too, aswell as plenty hopup parts.
It's a shame Centre Points website isn't much use, they still have the X-Ray on there
Herminator is offline
Old 07-26-2004, 03:37 PM
  #11860
Merciless's Avatar
Center Point may well be bringing them in and for parts in a hurry we'll all be happy.
But who's prepared to put money against the kits having a retail of 299 over here ??? and all the parts be priced in the usual conversion of $ = by the time it get to the UK LHS !!!
Bet the dumb asses don't even work out thats why they'll do OK on parts but not shift the kits
Ohh the way were hit over here for over priced products really gets me going
Old 07-26-2004, 03:41 PM
  #11861
Merciless's Avatar
OHH Ahhh really begining to love my cuda now it goes better every week !!
Think my foam/carpet set-up is really begining to take shape !!
Alittle more work getting it to carry the optimum corner speed and i'll be kicking arse !!
Old 07-26-2004, 03:55 PM
  #11862
Gazza_D's Avatar
But 299 is cheap when you compare it to the RRP for an X-ray now......349.99 ouch
But at the end of the day its still rip off Britain
Gazza_D is offline
Old 07-26-2004, 04:49 PM
  #11863
Originally posted by JDM_DOHC_SiR
..If you are using the Xenon with the PAL driive train .. you CAN'T use the center one way ..... if you had a R3 you would be able to
-Dave
the center 1-way will fit an R3 right? have you tried it with any good results?
thanks Dave.
Also, are the hubs/knuckles compatible between the R2 and R3? What about stabilizer bars?
poop is offline
Old 07-26-2004, 10:47 PM
  #11864
JDM_DOHC_SiR's Avatar
Trader Rating: 31 (100%+)
thanks Dave.
Yes the center oneway works with the R3. very fast cornering speed
also the R2 hubs and knuckles will work with the R3 the stabilizers are the same... the mounting hardware is different between the R2 and R3.
-Dave
JDM_DOHC_SiR is offline
Old 07-26-2004, 10:48 PM
  #11865
Looks like the PAL hubs did the trick for ya
care to post some set ups
-Dave
