Alex Racing Barracuda R2 & R3 >
Like Tree4Likes
Old 07-22-2004, 04:23 PM
  #11821
JDM_DOHC_SiR's Avatar
Trader Rating: 31 (100%+)
Originally posted by seaball
dave,
my drivetrain is horendously loud. not clicking or eratic, but just loud. yeah, that's a clue that something might not be right, but withought gear covers, it stands to reason that it will scream.
also, i have a ton of axial movement on my bevel gear. the spur gear can move maybe 1.5-2mm back and forth. i pull the bevel gear all the way back/forward to the holder when i run since the driving force will cause it to end up there anyway. i also shim the dif gear about 3 shims on the long side to back it off of the pinion (bevel) gear. there's alot of backlash, but i have never slipped or chipped a gear in the transmission.
please enlighten me with something to give this car some R.I.P.
thanks,
seaball
There is a way to shim the Bevel gears.. since ALEX has made over 3 different types and sizes. by shimming the bevel gear the Barracuda becomes very Quiet ...and less friction..
If you want to go a few pages back about 60ish I posted a how to with pic's and such.. if not I"ll post it up a bit later for you.. make quite a bit of differance
-Dave
JDM_DOHC_SiR is offline
Old 07-22-2004, 04:24 PM
  #11822
Gazza_D's Avatar
Havent noticed a problem with no rip from my car, im running 2.5 degrees of toe in on the rear, parallel at the front.
The only time it wasnt at the races was a couple of weeks ago, but that was more down to scrubbing too much speed through the corners due to having way too much grip.
Soon sorted that out though
Im going to try playing with anti/pro squat this weekend to see what effect it has on the car. May put the 3 degree blocks on the front to see how it feels if I get time.
Learn track, get right gear ratio, check different bodies, oil, shock pack, springs should be enuff hours in a day to squeeze that lot in
Maybe if I reduce the cashes etc, it will give me the info I need
Best start charging cells now..........
Gazza_D is offline
Old 07-22-2004, 04:31 PM
  #11823
Man you guys should try some anti-squat in the rear
and the PAL hubs will make a huge difference
-Dave
Old 07-22-2004, 04:34 PM
  #11824
Merciless's Avatar
Dave,
Anti squat .........
The shimming of the rear wishbone to raise the front edge ??
Effect loosens the rear abit but also makes it handle bumps better ??
Just wanted to make sure i had the right idea on what were talking about here again !
Merciless is offline
Old 07-22-2004, 04:42 PM
  #11825
Originally posted by Merciless
Dave,
Yes... loosens the Rear...or should I say free's up the rear... alos I tend to run about 2-2.5* for toe in the rear and the Front I like to run max toe out on the front A-arms... Offest balls up front with maxed to outward position..very agressive turn in
-Dave
Old 07-22-2004, 04:47 PM
  #11826
Gazza_D's Avatar
Here you go Dave,
I took the bits you wrote and put this together for some of the guys over here. Hope you dont mind
Gets the point over though, dont you think
Doh....file too big to attach
Gazza_D is offline
Old 07-22-2004, 04:50 PM
  #11827
Here you go Dave,
Shrink that bad boy down
Old 07-22-2004, 04:56 PM
  #11828
Gazza_D's Avatar
Its the pictures of the gears causing the problems...... will have a go again and see what gives
Anti-squat increases steering entering the corner and provides more traction exiting the corner. Reducing anti squat to zero will decrease the steering entering the corner and will improve accelleration in bumpy conditions. It will also slightly reduce on power traction.
Or so I have been led to believe
Gazza_D is offline
Old 07-22-2004, 04:57 PM
  #11829
seaball's Avatar
dave,
i'll check back to those pages.
have you played with prosquat as well? it was hard for me to do it, because it is an odd, and often, renounced alignment, but i tried it, and it seemed to help rotate as well.
2-2.5* rear toe, is that for asphalt? i started with 3, went to 2, and now i am at 1. it has become better with each reduction.
thanks for the tips, i'm off to go searching for those pages....
by the way, i know it was just posted, but what angle of toe are the pal hubs spec'd at? and the xenon ones? 1.5 for the latter, right?
seaball is offline
Old 07-22-2004, 04:59 PM
  #11830
seaball's Avatar
gazza, perhaps i will wait for you before i begin my quest...
many thanks,
chris
seaball is offline
Old 07-22-2004, 05:04 PM
  #11831
dave,
The PAL and Xenon Hubs are both 1 deg for the Rear
as far as set ups for the R2/R3 they vary quite a bit...but mostly on Shock locations and springs
the R1 is a differnt story though
-Dave
Old 07-22-2004, 05:37 PM
  #11832
Gazza_D's Avatar
Well, I tried and tried but still cant get it down small enuff Could get it nice an small as an html document but cant upload that, so back to the drawing board
Will try again toworrow when the brain cells are functioning again
Gazza_D is offline
Old 07-22-2004, 05:39 PM
  #11833
I"ll see what I can come up with here while I'm at work
-Dave
Old 07-22-2004, 10:03 PM
  #11834
OVA
OVA's Avatar
Trader Rating: 84 (100%+)
I have R2 xenon stage 3 with speed pal drive train.
Question: Can I get oneway drive shaft for my R2 pal drivetrain?
or they're made for stock R2 only...Thanks
OVA is offline
Old 07-22-2004, 10:41 PM
  #11835
..If you are using the Xenon with the PAL driive train .. you CAN'T use the center one way ..... if you had a R3 you would be able to
-Dave
