Old 07-01-2004, 05:26 AM   #11581
JDM_DOHC_SiR's Avatar
Trader Rating: 31 (100%+)
Originally posted by wyd
What spur gears do most of you guys run? I'm running a 95 tooth 64 pitch gear.
94-98 on the R1/2 and on the R3 94-96
-Dave
Ȼ4.5 Centro+α ◊ TRF 501ӽ ◊ TRF 502ӽs ◊ TRF 503 ◊ TRF 511 ◊ TRF 201ӽr ◊ TRF 211ӽ
B5m ◊ T5m ◊SC5m ◊ B64deez nutz
Speedway PAL ◊ SDRC ◊ Shop UFO ◊ SMC
JDM_DOHC_SiR is offline   Reply With Quote
Old 07-01-2004, 05:29 AM   #11582
My Cuda: Test Picture. Gear covers are off now.
the covers look like they are still on
-Dave
Old 07-01-2004, 05:31 AM   #11583
Originally posted by Merciless
I might be able to put those measurements on a picture if anyone dosen't understand that
That might be a good idea Rod
-Dave
Old 07-01-2004, 05:33 AM   #11584
wyd
Tech Legend
wyd's Avatar
Trader Rating: 50 (100%+)
Send a message via AIM to wyd
-Dave
Tonight I will take a picture of the car with them off!!!!!!!!
ST Racing Concepts (STRC)
Old 07-01-2004, 05:41 AM   #11585
OK
hahahah
-Dave
Old 07-01-2004, 06:52 AM   #11586
Herminator's Avatar
Send a message via ICQ to Herminator
Since I now have access to a digital camera here are a few photo's for you.
Now don't let anyone say there's no room for a large speedo!
Herminator is offline   Reply With Quote
Old 07-01-2004, 06:54 AM   #11587
Herminator's Avatar
at the other end of the scale
Old 07-01-2004, 06:56 AM   #11588
Herminator's Avatar
My usual speedo, need to actually remove the Cubed still, have to dig out the soldering iron sometime soon
Old 07-01-2004, 06:58 AM   #11589
Herminator's Avatar
my custom made car stand great for dumping your car on while you go marshal the next race
Old 07-01-2004, 07:00 AM   #11590
Herminator's Avatar
And finaly the current paint job, a slightly more fancy version of what I had on my Mazda 6 and a step closer to my final race scheme just need an airbrush now so I can stop using cans......
Old 07-01-2004, 07:01 AM   #11591
Herminator's Avatar
oops, might help if I attach it
Old 07-01-2004, 08:40 AM   #11592
seaball's Avatar
R/C Tech Charter Subscriber
Send a message via Yahoo to seaball
merciless,
nice work. i actually did almost the same thing to my r2. except i left more material above the outdrive bearing and drilled and tapped a hole so that the ball stud fastens to the bulkhead, not the upper deck. i lost the adjustability of varying the link length, but i can still adjust roll center, or camber gain, by moving the ball vertically with shims.
do you find tht the upper link is too angled with your mod? it seems to me that it would be. my ball stud is placed just below center of the top plate. i see yours is much lower, since it uses the plate as a base.
*** The Gate II - Home of Mike Wise ***
seaball is offline   Reply With Quote
Old 07-01-2004, 09:18 AM   #11593
Merciless's Avatar
Send a message via ICQ to Merciless
Originally posted by seaball
merciless,
I haven't actually got to run it yet in this format, To be honest i'm hopeing to have the Speedway hubs on there before i do run it in about a weeks time
As for the angles for the camber links i cannot be sure yet, The rear is quite level but the front is indeed angled but then with the std. hubs i was using the most angled setting !! so this is less than that !
Something i have thought about is using TC3 style ball studs on the inside too this would allow for even greater movement up and down when compared to the cuda items
TBH i have only done this to see what it looks like before fitting the PAL items.......
I don't like the HPI rear hubs having to be drilled
And the cuda front c-hubs cut down will be to weak to race with IMO
But i think with alittle fiddleing the mounting of the upper links off the top plate will work just fine
Merciless is offline   Reply With Quote
Old 07-01-2004, 10:08 AM   #11594
RcMonk's Avatar
Herminator, what kind of transponder mount is that ?
RcMonk is offline   Reply With Quote
Old 07-01-2004, 10:26 AM   #11595
Herminator's Avatar
Erm... good question
Been a while since I got it, but I think it's the Xenon version. Dave should know
WTB Alex Racing Barracuda R2 & R3 Funkymojo R/C Items: Wanted to Buy 3 02-03-2007 01:00 PM
alex racing barracuda con81 Electric On-Road 1 12-14-2005 03:36 AM
WTT: Alex Racing Barracuda R2 for PS2 AZ_Ron Other Items: For Sale/Trade or Wanted to Buy 0 02-13-2005 07:30 PM
Alex Racing Barracuda R3-New. rcracing1973 R/C Items: For Sale/Trade 9 04-11-2004 08:29 AM
Alex Racing Barracuda Bugs Bunny Singapore R/C Racers 6 01-22-2003 11:47 PM
