Old 06-29-2004, 06:25 PM   #11551
JDM_DOHC_SiR's Avatar
Trader Rating: 31 (100%+)
Default Re: Re: Re: Re: if the Link doesn`t work
Originally posted by linger
Hi Dave,
I'm still using the stock hubs. I'm considering cutting them down or drilling new holes.
Any idea if the Yok or Pro4 rear hubs will fit with little or no mods?
Hi Bro.
the Pro4 ones seem to be the best bet.. I just last night tapped the hole to 3.05mm and they fit the arm just fine and the bearings and such work just fine.. .. on a little side note.. I have been messing around with the Tamiya/HPI axel in the rear and it seems you might be able to use a Tamiya dogbone in the rear ..
-Dave
Ȼ4.5 Centro+α ◊ TRF 501ӽ ◊ TRF 502ӽs ◊ TRF 503 ◊ TRF 511 ◊ TRF 201ӽr ◊ TRF 211ӽ
B5m ◊ T5m ◊SC5m ◊ B64deez nutz
Speedway PAL ◊ SDRC ◊ Shop UFO ◊ SMC
JDM_DOHC_SiR is offline   Reply With Quote
Old 06-30-2004, 01:32 AM   #11552
Attached is a pic of the front end conversion before I machined the bulkheads.
Linger.
How much did you take the bulkheads down.?? I have one set that I don`t think I took enough off
-Dave
Old 06-30-2004, 03:18 AM   #11553
Herminator's Avatar
Send a message via ICQ to Herminator
don't worry guys....
I'm still around.... kind of
and Dave-
Herminator is offline   Reply With Quote
Old 06-30-2004, 05:38 AM   #11554
Originally posted by Herminator
and Dave-
Guess what I got back today ..
PM me ...Pete with your new addy Please
-Dave
Old 06-30-2004, 06:31 AM   #11555
Herminator's Avatar
-Dave
Just PM'd you before I saw this post, will send another in a minute.
Old 06-30-2004, 08:06 AM   #11556
wyd
Tech Legend
wyd's Avatar
Trader Rating: 50 (100%+)
Send a message via AIM to wyd
I think the next time I run my Cuda in 2 weeks or so I'm going to run a front swaybar and lighter front and rear springs. I currently run Rayspeed Gray springs front and rear and the car is pretty good. When I run lighter springs like the Rayspeed REds or Whites the car rolls alot in the corners. I think the sway will take car of this and then I can run lighter springs to soften the car some to make the smoother overall.
I run asphalt with foams 99% of the time. Even when running indoors I run asphalt. I have one indoor asphalt track I run at now and soon a 2nd one to be going in the next couple of months. I will have my choice of two indoor asphalt tracks within an hour of my house. Gotta love that!!!!!
Plus I will get to try my new Parma Alpha next time I run as well. Might even order one of those new Protoform Caddilac bodies to try as well.
ST Racing Concepts (STRC)
Old 06-30-2004, 12:34 PM   #11557
Merciless's Avatar
Send a message via ICQ to Merciless
Dave
Just hit ya with a PM if ya can could take a lok plz
Merciless is offline   Reply With Quote
Old 06-30-2004, 01:25 PM   #11558
Herminator's Avatar
Anyone got a setup for the cuda, running foams on carpet with 27turn stock motors?
Looks like it will soon be time to buy a new stock motor and my first ever set of foams Should be "interesting" just wish I had some cash
Old 06-30-2004, 01:45 PM   #11559
Hebiki,
Thanks for the info. When is the non-sparkle version coming out? Are there going to be any other changes?
PSI Racer is offline   Reply With Quote
Old 06-30-2004, 02:12 PM   #11560
pumpkinfish's Avatar
Herminator,
I use plaid fronts and purple rears. Try starting with Assoc. Copper front and gold rear springs. Both 40 wt oil and use a ball diff in the front. I tried the one way but I couldn't control it. You might want to have some sway bars to try also. Linger had posted a setup what seems foever now. It is back so many pages!
I also use the Chvron G350GT body only. I tried a MZ6 and didn't like it. I may try the new Caddy this winter when it is carpet season again.
pumpkinfish is offline   Reply With Quote
Old 06-30-2004, 02:17 PM   #11561
Merciless's Avatar
Right
Front would be completed if i could only find a proper m3 Threaded ball joint for the upper king pin mounting point to the upper link.
Got a TC3 one in there for the pic but the fit is just not "right" i know these different threads are susposed to be the same size (phsically) but they aren't!!
Rear is together but not really what i had in mind.When i was drilling the HPI rear hub me it and the drill had a disagreement and it got F***ed up no vice so i suspose i should have expected it !
Anyway it'll do to see how it works if i can only get the front together properly !!
Old 06-30-2004, 03:42 PM   #11562
Originally posted by Merciless
Right
Looks really good there ..now you would just need the PAL hubs to make it that much better
-Dave
Old 06-30-2004, 03:47 PM   #11563
Herminator's Avatar
Looks good Merciless
I wish my R2 was still that shiney and clean
Thanks, Pumpkinfish, I'll have to see what foams they use at the local track, hopefully there's a simple choice. I like to use Alex Racing springs so I'll need to find out which are closest to what you suggest. Sway bars will be something I'll try later if I can't get the car working well without them, never liked adding more complications to setup, when I often struggle to be brave enough with changing the limited things I usualy do. Often have too little time and don'r like risking a whole nights racing on one thing.
Old 06-30-2004, 03:57 PM   #11564
wyd
Tech Legend
wyd's Avatar
Pumpkinfish if you would have been at WC two weeks ago you could have raced against 2 other Cuda's. Me and RCmonk were their with our Cudas and I thought you might show up with yours. Could have been really cool to have 3 Cudas at one track. Might be a record for an EastCoast Track to have that many at one place.
Old 06-30-2004, 04:10 PM   #11565
Merciless's Avatar
Dave you have another PM !!
WTB Alex Racing Barracuda R2 & R3 Funkymojo R/C Items: Wanted to Buy 3 02-03-2007 01:00 PM
alex racing barracuda con81 Electric On-Road 1 12-14-2005 03:36 AM
WTT: Alex Racing Barracuda R2 for PS2 AZ_Ron Other Items: For Sale/Trade or Wanted to Buy 0 02-13-2005 07:30 PM
Alex Racing Barracuda R3-New. rcracing1973 R/C Items: For Sale/Trade 9 04-11-2004 08:29 AM
Alex Racing Barracuda Bugs Bunny Singapore R/C Racers 6 01-22-2003 11:47 PM
