Old 06-27-2004, 03:21 AM   #11521
JDM_DOHC_SiR's Avatar
Trader Rating: 31 (100%+)
Thumbs up if the Link doesn`t work
Try this
-Dave
Ȼ4.5 Centro+α ◊ TRF 501ӽ ◊ TRF 502ӽs ◊ TRF 503 ◊ TRF 511 ◊ TRF 201ӽr ◊ TRF 211ӽ
B5m ◊ T5m ◊SC5m ◊ B64deez nutz
Speedway PAL ◊ SDRC ◊ Shop UFO ◊ SMC
JDM_DOHC_SiR is offline   Reply With Quote
Old 06-27-2004, 04:03 AM   #11522
Merciless's Avatar
Send a message via ICQ to Merciless
DAVE
Doing the bulkhead mod should be easy for me as a mate works in a machine shop just got to talk nicely to him
Just woundering how good a fit the TC3 front hubs are before i go buy a set ?? and the HPI rears ??
Do they alter the height of the wheel in relation to the wishbones from std. R3 i.e the roll center ???
And are pro4 bearings the same size for those rear hubs or will i need new there ??
Just a few questions cause this promising and i could give it ago in the std. parts before buying them in alloy for not many $$
Merciless is offline   Reply With Quote
Old 06-27-2004, 04:33 AM   #11523
Originally posted by Merciless
DAVE
the TC3 ones will need a very small amount of work (i.e. nothing) as for the rear height of the HPI Pro4 hubs they are .5mm taller where the ball stud mounts..but I run my PAL rear hubs with a 1mm shim so it will work out just fine
the bearings on the Pro4 are the same as the Cuda in the rear so thats one more plus..
all you have to do now after you modify the bulk heads is flip the upper deck over and mount the 5.8mm ball stud facing down
-Dave
now to get out that spare set of bulkheads to work on
Old 06-27-2004, 04:39 AM   #11524
Merciless's Avatar
Sounding like a project that i might be able to get done by friday
Old 06-27-2004, 04:47 AM   #11525
You might beat me to it since the only local R/C machine shop that I know if in Japan is PAL Oh well at least after they are finished with it they can re-anodized them
-Dave
Show some pic`s when you are done
Old 06-27-2004, 05:07 AM   #11526
Merciless's Avatar
Dave
you think/Know the TC3 hindge pins are the same size as Cuda's ??
Cheers
Old 06-27-2004, 05:14 AM   #11527
Dave
Cheers
not for sure ...but it might be worth a try.
-Dave
Old 06-27-2004, 08:58 PM   #11528
Dave
Cheers
Just bought a set today..I"ll try them out after work
-Dave
Old 06-27-2004, 11:07 PM   #11529
linger's Avatar
Default Re: if the Link doesn`t work
Originally posted by JDM_DOHC_SiR
Try this
-Dave
Hmm,
Funny thing. I did the same thing prior in preparation for the Reedy Race.
I opted to use the Associated Castor blocks and the cuda or yokomo knuckes drop in driectly. The Associated castor block uses a smalled diameter hinger pin vs the Alex arm...so you have to drill out the associated castor block to fit.
linger is offline   Reply With Quote
Old 06-27-2004, 11:11 PM   #11530
Default Re: Re: if the Link doesn`t work
Originally posted by linger
Hmm,
Nice Job there
but what are you using for the Rear hubs..?
-Dave
Old 06-27-2004, 11:15 PM   #11531
OVA
OVA's Avatar
Trader Rating: 79 (100%+)
Hi Guy
That's funny I did the same thing.but I used the losi caster block instead...
I have not failed. I've just found 10,000 ways that won't work
OVA is offline   Reply With Quote
Old 06-27-2004, 11:15 PM   #11532
thats what I did when 1st tried the Pro 4 ones but I have a Tap that I used for the TC3 ones
-Dave
Old 06-27-2004, 11:21 PM   #11533
Originally posted by OVA
Hi Guy
similar
-Dave
Old 06-27-2004, 11:58 PM   #11534
OVA
OVA's Avatar
Dave what time it is there?
Old 06-28-2004, 01:59 AM   #11535
5pm at night why
-Dave
WTB Alex Racing Barracuda R2 & R3 Funkymojo R/C Items: Wanted to Buy 3 02-03-2007 01:00 PM
alex racing barracuda con81 Electric On-Road 1 12-14-2005 03:36 AM
WTT: Alex Racing Barracuda R2 for PS2 AZ_Ron Other Items: For Sale/Trade or Wanted to Buy 0 02-13-2005 07:30 PM
Alex Racing Barracuda R3-New. rcracing1973 R/C Items: For Sale/Trade 9 04-11-2004 08:29 AM
Alex Racing Barracuda Bugs Bunny Singapore R/C Racers 6 01-22-2003 11:47 PM
