Alex Racing Barracuda R2 & R3 >
Like Tree4Likes
Old 06-21-2004, 04:07 AM
  #11416
GTO2's Avatar
yo guys, any good recommendation for 19T motor for Cuda? Pro cons welcome, thanks.
GTO2 is offline
Old 06-21-2004, 04:15 AM
  #11417
chappi's Avatar
Trader Rating: 17 (95%+)
Originally posted by JDM_DOHC_SiR
THe Black chassis has been out in Japan for about 2 weeks ...almost everybody that runs the R3 at the local track has swiched to the Black one over the Sparkle chassis ....
-Dave
I am thinking of getting a R3 kit.
so is this mean I can buy a new kit that it already come with the BLACK chassis?
Or i still need to buy the one that with a Sparkle chassis, then hop up with the 2 black chassis?
Also, can someone explain to me, how do you adject the rear Toe in on R3?
and is R3 easy to get its weight balance, compare with the Yokomo SD SSG etc?
Hope some 1 can give me some suggestion. THX
chappi is offline
Old 06-21-2004, 04:39 AM
  #11418
wyd
Tech Legend
wyd's Avatar
Trader Rating: 51 (100%+)
You can adjust the rear toe in with the offset pillow balls and with the rear hubs. The offset pillow balls are really nice and super strong.
wyd is offline
Old 06-21-2004, 08:40 AM
  #11419
Herminator's Avatar
19 turn motors are pretty similar from my experience, atleast they are if geared properly, which a lot of people still can't seem to get right
Matrix do a nice 19turn, last years model, (I've not tried their newest one) very punchy and plenty top end.
Chameleon based 19turns are good too, I'm currently using a nice Demon tuned version, which is a bit more flexible with the gearing than the Matrix, but does run hotter.
The Ready Quad mag seems fast enough, not used one myself, but it can usualy just about keep up with my car
Then there#s the new Peak Vantage 19turn with the V2 endbell, I'd like to try one of these I don't think they're much more powerful, just very very easy on the comm.
Herminator is offline
Old 06-21-2004, 01:13 PM
  #11420
Gazza_D's Avatar
Most 19T motors......if geared correctly, can be made to go quickly. One thing to come out of the national this weekend was that the v2 endbell is easily damaged by crash impacts. I saw one get the brush hood crushed on its first run out of the packet
Whatever you choose to run, check with the fast guys at the track you run on what gearing they are running and try 1 tooth lower for starters. Not every one can drive the same as the super quick guys
Dave, any ideas where I can get PAL or other Aluminium front knuckles, C Hubs and rear knuckles...preferably in Orange of course. I know Ive got the Xenon ones but fancied trying something a little different
Gazza_D is offline
Old 06-21-2004, 01:48 PM
  #11421
Merciless's Avatar
Are any of you guys trying to get the corner weights correct ??
I.E 25% of the total weight on each wheel
Or are you just "leveling" it with the shocks ?? like taking out the tweak ??
I'm having a very hard time trying to get the corner weight equal alround and i've even put 1 of the cells on the same side as the motor to help
My next idea was to get the chassis under the servo cut out so i could put lead weight under the servo to help out as it's deffinately at the front on the servo side where the chassis light !!
Getting the two sides of the car even is easy but trying to get all four corners the same is proving near impossible
To be honest it ain't even close
Merciless is offline
Old 06-21-2004, 01:50 PM
  #11422
Merciless's Avatar
Oh how are the V12's runnning i got 1 of them to try out next series after we finish the stock one where on at present !!
Are they quick enough when compared to the best of the rest or are they lacking?? to give this very good life span ???
Old 06-21-2004, 02:16 PM
  #11423
Merciless's Avatar
Oh and any other news on the "new" style hubs with the lowered mounting points ??
God do i want a set of them
Anyone able to hook me up ??? Plz
Old 06-21-2004, 03:19 PM
  #11424
JDM_DOHC_SiR's Avatar
Trader Rating: 31 (100%+)
Gaz you have a PM
-Dave
JDM_DOHC_SiR is offline
Old 06-21-2004, 03:40 PM
  #11425
I think that youmight be trying to hard to get it perfect just worry about left and right balance and then tune the car for over and under steer from there but you are on the right direction with the weight on the motor side and the servo area too
take a look at some of thhe pis I will attach and you will see a few good ideas
-Dave
Old 06-21-2004, 03:42 PM
  #11426
Thumbs up Servo moved
take a look
Old 06-21-2004, 03:43 PM
  #11427
Wink Side shot
area around the motor
Old 06-21-2004, 03:45 PM
  #11428
You have a PM
Old 06-21-2004, 08:02 PM
  #11429
S-T-R-l-K-E-R's Avatar
jim - is that the black version of the R3 (your attachments)? thanks
S-T-R-l-K-E-R is offline
Old 06-21-2004, 10:19 PM
  #11430
SpeedTech's Avatar
Originally posted by chappi
o ic
thx guys...
also, another question.
Is it a new version of R3 coming? the BLACK CHASSIS edition?
when does it start selling in the market?
The Black chassis version should arrive on our next shipment from Alex Racing
Steve Wang
SpeedTech is offline
