Alex Racing Barracuda R2 & R3 >
Old 06-09-2004, 10:06 AM
  #11296
wyd
Tech Legend
wyd's Avatar
Trader Rating: 51 (100%+)
I did order some offset pillow balls and more hardened midspan a arms. Speedtech didn't have any extra diff gears or bevel gears showing in their inventory right now so I will get that stuff as soon as he gets them in.
wyd is offline
Old 06-09-2004, 10:09 AM
  #11297
rc-zombies's Avatar
WYD..
PM me with your address... I've got a diff and one-way bevel gears I can send you...left over from my WEB.
I'll look for them tonight....
rc-zombies is offline
Old 06-09-2004, 10:27 AM
  #11298
wyd
Tech Legend
wyd's Avatar
Originally posted by rc-zombies
WYD..
Thanks. I sent you a PM. Once again another good guy on the R/C Tech forums.
wyd is offline
Old 06-09-2004, 10:45 AM
  #11299
OVA
OVA's Avatar
Trader Rating: 82 (100%+)
Between the MG proform and the Mazda 6 I think the MG is alittle more stable than the Mazda6 The Mazda 6 have alittle more down force than the MG
OVA is offline
Old 06-09-2004, 05:40 PM
  #11300
JDM_DOHC_SiR's Avatar
Trader Rating: 31 (100%+)
Originally posted by Herminator
So track testing is whats been keeping you busy the last couple days I'll just stay bored then....... nothing to look at......
Yep... It`s been a while ..have to pratice a bit
-Dave
BTW you`ll see something by the end of the week just kind of busy
JDM_DOHC_SiR is offline
Old 06-09-2004, 06:13 PM
  #11301
Herminator's Avatar
hehe, I bet, you must be just a little rusty
although if you've got it, you never really loose it
we had a club member return recently after two years off, within a few weeks he was back up to the top, although maybe not quite as good as he once was ,but it could be his aging equipment holding him back a bit too... He stills runs a Pro 2 and all of his cells apart from a set he bought from me, were old nicads not that they can't still be fast....
don't take too long getting to the post office, I won't be here to recieve it in a couple weeks
Herminator is offline
Old 06-10-2004, 07:34 AM
  #11302
seaball's Avatar
herminator,
i need a favor. i am running the cirrus esc as well. i have noticed something that i don't like. while the car is on the bench, i was slowly accellerating and decellerating while watching the led's. i saw that there is a distinct "jump" when the orange light goes out, leaving only the green on. this occurs to signify that 100% power is acheived.
well, if i move the trigger slow enough, i can actually get the esc to stop in it's deadband that occurs from the 99 to 100% transition. can you get your cirrus to do this? i am bothered by this, and maybe i've got a blow fet or something. what do you think?
the esc is smooth from 0-99%, but the motor arcs when going to 100% and it's audibly, and visually noticeable. like i said, if i hold at the 99.5% position the esc sits quietly in it's deadband, and the motor is still. can you reproduce these results?
please advise.
chris
seaball is offline
Old 06-10-2004, 08:28 AM
  #11303
rcsabah's Avatar
have you check your radio setting at your ESC requirement
rcsabah is offline
Old 06-10-2004, 09:25 AM
  #11304
rc-zombies's Avatar
your PM box is full
Found them!.. no charge bro...
you should have it sometime next week...
happy racin..
Old 06-10-2004, 09:47 AM
  #11305
Herminator's Avatar
I've never noticed it myself, but I'll check for you soon.
When did you get your Cirrus?
what did it include in the way of capacitors?
What radio do you use? how many steps or how much travel does it have? if you know.
Old 06-10-2004, 10:16 AM
  #11306
seaball's Avatar
the cirrus has maybe 15 runs on it, and is two months old.
wired in is a 4.7 uF x 10v cap (novak cap)
schottky diode (novak board style)
i am running a futaba 3pm radio on 75 band (not hrs). brand new actually. as far as travel goes, it's set for 100% throttle epa, and the esc is calibrated accordingly. the zero is good, the high level and braking are as well. it's just getting there that exposes the discontinuities.
i have played with frequency settings in the cirrus profile, but to no avail. i will play more, but i am skeptical that anything will change. i have not had great luck with the mtroniks stuff thus far, (two cubes and a cirrus) but i love their specs.
seaball is offline
Old 06-10-2004, 10:38 AM
  #11307
Herminator's Avatar
OK, I've checked mine out and there's definetly no jump, or stall. I can get the orange led to flicker on and off but there's no actual power issues at the motor. The orange LED goes out a bit before 99% power, probably more like 95%.
When I got my Cirrus back the other day it came with an extra cap, the same as used on motors, 0.1 uF. There was an added note to say it has to be soldered across the negative motor and negative battery terminals on the ESC. M.Troniks have always stressed that the smaller of the power caps supplied must always be used.
Some radio's have too much throttle range for the speedo, a club mate with a cheapo radio had erratic power glitches when at full throttle, since the radio sent out a signal out of the speedo's range so the speedo didn't know what to do. Doesn't sound like your problem though, I use a Futaba 3PK, so there shouldn't be much difference.
Old 06-10-2004, 11:25 AM
  #11308
wyd
Tech Legend
wyd's Avatar
your PM box is full
happy racin..
I emptied my PM. Funny thing it is not really that full to begin with. Oh well thanks for the hook up. If you need anything let mw know and I will try to help you out.
Brian
wyd is offline
Old 06-10-2004, 01:21 PM
  #11309
seaball's Avatar
Thumbs up thank you
for the quick help. i'll look some more, but it doesn't look good. you are man herm. perfect!
seaball is offline
Old 06-10-2004, 10:03 PM
  #11310
psmart2's Avatar
Does anyone have a good setup for modified/rubber tire/indoor asphalt medium tight track? Will be using R2 with Xenon Stage 2& Square front and rear hubs. Motor will be 10T limit.
psmart2 is offline
