Alex Racing Barracuda R2 & R3 >
Like Tree4Likes
Old 06-07-2004, 04:05 PM
  #11236
JDM_DOHC_SiR's Avatar
Trader Rating: 31 (100%+)
Originally posted by R/C Anonymous
10 bucks says i know the guy thats working on your chassis
And I`ll bet you that you`ll guess it right
-Dave
JDM_DOHC_SiR is offline
Old 06-07-2004, 04:07 PM
  #11237
Hebiki's Avatar
Trader Rating: 26 (100%+)
isnt BMI working on the chassis?
DOH! did i spill it?
Hebiki is offline
Old 06-07-2004, 04:08 PM
  #11238
Originally posted by Gazza_D
Gonna spill the beans before Dave comes back?!?!?!?!?
Too Late...and besides Gaz.. the chassis is for the R3
But look in my signature to find out who will work on the chassis
-Dave
Old 06-07-2004, 04:12 PM
  #11239
Correct
Old 06-07-2004, 04:14 PM
  #11240
Trader Rating: 49 (100%+)
On the aftermarket chassis, are they going to stiffen it up other than going to a thicker graphite (similar to the 415).
weaponx is offline
Old 06-07-2004, 04:15 PM
  #11241
Gazza_D's Avatar
Ah but the plan is to upgrade and get an R3 when they are truelly sorted Dave
Gazza_D is offline
Old 06-07-2004, 04:17 PM
  #11242
Hebiki's Avatar
i didnt mean to spill your surprise dave.. but i was talking to a BMI driver here in socal.. and he was telling me about the new chassis. (ill let you spill all the goodies about it)
this will definitely be a good upgrade for barracuda drivers.
Hebiki is offline
Old 06-07-2004, 04:18 PM
  #11243
Originally posted by OVA
Hi Dave
Do you get a chance to find out about the Altas Racing sprint brushes and Yokomo brushes for stock motor Thanks
Just use the Atlas sprint ones
here is the part #`s
MH7-059 standup
MH7-061 laydown
these are good for about 3-5 runs and then they have the serations gone
-Dave
Old 06-07-2004, 04:30 PM
  #11244
Going to a R3 now Gaz.?? YOu should be able to use some of the Web Stuff that you have now the bulkheads are a tad bit different and the motor mount and steering are too but not a big deal to upgrade
and it will be a tad bit lighter than the R2 Pal version that you have now
-Dave
Old 06-07-2004, 04:33 PM
  #11245
No Big deal..
this chassis set should be 10 times stronger than the sparkle [email protected] I have killed 2 chassis in 4 runs.. High Bite Track alongwith 2x4`s are not very forgiving ---Dave
Old 06-07-2004, 04:38 PM
  #11246
well the main thing that I wanted then todo was make the Chassis stiffer...so 3mm lower chassis was a starting point..but I also wanted the car to have a bit more fwd bias so moving the servo and batterys up 3mm will help.....And I also wanted a option to have 2 different thickness upper decks so you would be able to tune for different track surfaces(3mm and 2.2mm)
-Dave
Old 06-07-2004, 04:43 PM
  #11247
Thumbs up Black Chassis
ALso a bit of news from the Japan side of the house.. ALEX has now releasedthe Black carbon chassis set for the barracuda .. this is the same normal carbon fiber thatis on the Regular R2
the chassis set retails for 16800 Yen and it includes the upper deck ,lower deck and shock towers..
But I hope to have the other 3mm R3 chassis set lower priced than that
-Dave
Old 06-07-2004, 04:49 PM
  #11248
Herminator's Avatar
2 broken chassis sounds painful
So any special little features on the BMI chassis? other than cells forwards a bit and servo forward a touch. How about some optional holes for an R2 style steering assembly?
Been racing again tonight, made some progress with the setup but my brain was in go slow mode when it came to driving Just moved the top front shocks out one hole and the rears in one hole, nothing major but I don't want big changes.
We were running anti clockwise for a change tonight (my idea ) so I don't know if it was the more left hand corners that was holding me back or just not being up for it. I still took an easy second place, about half a second a lap ahead of those behind me but the guy ahead was another half second faster, which is unusual.
I'm still needing some more high speed steering, far too easy to understeer into fast corners.
Herminator is offline
Old 06-07-2004, 04:59 PM
  #11249
Trust me Hermi..There are a few things that I have not said that I have told them to incorporate into the chassis
and as far as your on power high speed understeer..
have you tried THicker front shock oli....or reducing front droop a bit.?? also it seams like you are working backwards if you moved the front shocks out a hole..you should have layed them down a hole
-Dave
Old 06-07-2004, 05:37 PM
  #11250
Herminator's Avatar
Well in theory the further out the shocks are the softer the effect of them are, but then standing them up does the oposite, so yes, it is kind of confusing as to what it will actually do. They're already on the outer holes at the bottom.
Droop is probably the thing I need to play around with, I think I have too much all round, from when running indoors. I need to get some proper droop gauges.
There's no understeer when getting on the power out of corners and accelerating hard, in fact I had to tame the back end down a touch tonight, since it was really dusty. It's more or less when the car is neutral front to rear, that it's understeering, or just not carrying the corner speed I'd like.
