Alex Racing Barracuda R2 & R3 >
Old 06-02-2004, 08:13 PM
  #11176
pumpkinfish's Avatar
Has anyone ever tried the center one way? If so what does it do and is it something I should have in my box? I have seen it on Speedtech but never hear anyone discuss it. Hopefully the picture works:
pumpkinfish is offline
Old 06-02-2004, 08:27 PM
  #11177
wyd
Tech Legend
wyd's Avatar
Trader Rating: 51 (100%+)
Have not tried it yet but I have two of them with cars I have bought. Look pretty cool. I'm sure they work great.
wyd is offline
Old 06-02-2004, 09:52 PM
  #11178
OVA
OVA's Avatar
Trader Rating: 82 (100%+)
HI WYD
I was thinking about buying a center oneway for my R2
Can you sell one of your spare center oneway to me? please email me [email protected]yahoo.com Thanks
OVA is offline
Old 06-02-2004, 10:01 PM
  #11179
OVA
OVA's Avatar
pumpkinfish the center oneway shaft work the same way like super one way front diff ,except the center oneway only works an half of the corner speed than the super oneway front diff.
OVA is offline
Old 06-02-2004, 11:47 PM
  #11180
utieh's Avatar
Default Re: HELP!
Originally posted by utieh
I've just made a Lexan O-ring retainer which works fine...
My new problem is that the shocks are all bleeding from the aluminium shock retainer and the shock body, seems that I cannot close the shock good enough...Is there something I missed?
Here is the way I've putted the O-rings inside the O-ring retainer:
- Lexan thingy
O O-ring
- 3mm plastic shim
O O-ring
Gilles-
anyone?
utieh is offline
Old 06-03-2004, 09:40 AM
  #11181
utieh's Avatar
Talking HELP
still can't find a solution, the oil bleeds so much, each time I move the shaft some is going out from the retainer
utieh is offline
Old 06-03-2004, 09:55 AM
  #11182
Herminator's Avatar
It'e been a long time since I've rebuilt my shocks but you should have a small top hate shapped piece that fits snugly in the alloy end piece. Then there's a couple of o-rings (clear rubber) then a black plastic piece with one flat edge to it. This is held in by a C shaped sprung wire, which has a straight section that fits onto the flat section of the plastic piece and should clip under a small rim in the alloy end piece. Then there's a rubber ring that fits around the threaded section and compresses when you tighten the two alloy pieces together.
You should be able to see what I mean from the manual.
Herminator is offline
Old 06-03-2004, 10:29 AM
  #11183
utieh's Avatar
Thank you so much
Actually I don't own a Cuda (perhaps it would be my next car), I bought some shock bodies for my mini RS4, they didn't include any manual.
If I don't misunderstand you the"small top hate shapped piece" contains the o-ring and the shims and is contained by the alloy o-ring retainer,...
I will try to find an english part list for it...perhaps you have a link for that
I can't find the Triox website where I should be able to download it
Thanks again...I didn't imagine those shocks were so complex to build (I mean so many parts)..
gilles
utieh is offline
Old 06-03-2004, 10:40 AM
  #11184
Merciless's Avatar
Hope this helps ??
Merciless is offline
Old 06-03-2004, 10:56 AM
  #11185
utieh's Avatar
thank you very much.
it solved my problem, actually I used the O-ring which goes between the body and the holder inside the "spring-ride-height-alloy-ring thingy"(forgot that word ) like on my SD....
Thanks again Herminator and Merciless
Gilles
utieh is offline
Old 06-03-2004, 11:46 AM
  #11186
JDM_DOHC_SiR's Avatar
Trader Rating: 31 (100%+)
I'd show you my new paint job but I don't know what it is
I get back to Japan in a few days
Hold on big guy I'll post a pic for you
-Dave
JDM_DOHC_SiR is offline
Old 06-03-2004, 12:20 PM
  #11187
Herminator's Avatar
-Dave
no rush
Old 06-03-2004, 01:54 PM
  #11188
OVA, so when would I use one? I have a front one way in my car now for parking lot racing and I use a ball diff for carpet. So when should I think about using the center one way? I don't want to buy one and have no use for it.
Old 06-03-2004, 04:11 PM
  #11189
OVA
OVA's Avatar
If you're running front ball diff anywhere or place you race ,the car somtime is slower going around the corner and by putting the one center shaft ,it help the car breeze around corner alittle faster. and easy to control the steering .
OVA is offline
Old 06-03-2004, 04:14 PM
  #11190
rc-zombies's Avatar
I could never get the car to handle properly using the center one-way when I had my WEB... or even on the TC3...
rc-zombies is offline
