Old 05-14-2004, 12:45 AM   #10786
R/C Tech Charter Subscriber
The R3 bearing set will work on the R2. You just have an extra bearing for the motor mount but this works if you have the Xenon motor mount.
NismoSkyline17 is offline   Reply With Quote
Old 05-14-2004, 12:56 AM   #10787
MikeR's Avatar
Trader Rating: 15 (100%+)
R2 with Xenon upgrade is still awesome and is equal the R3. Team Barracuda USA will be running the R2 Xenon at Reedy in a few weeks!
www.exotekracing.com ☆ASSOCIATED☆DURANGO☆HPI☆HB RACING☆KYOSHO☆LOSI/TLR☆SERPENT☆TAMIYA☆TEKNO☆XRAY☆
A picture with your post, when trouble shooting, will probably get more rctech help than without...
MikeR is offline   Reply With Quote
Old 05-14-2004, 01:00 AM   #10788
Originally posted by Dougnuts55
Im sure this as been asked many times before but im lazy and dont like to look through 300 pages. Back to the question what is the diffrence between the R2 and R3 is the R2 still being used as is it competitive?
Doug
I love my R2. (primarily b/c I hate the TC3 style steering rack) Just add the alum. shaft holders and the Xenon chassis upgrade that Steve at Speedtech sells and it is a bullitproof TC. The R2 is just as competative as the R3 and parts are just as easy to find and prolly won't be hard to get for a very long time.
Old 05-14-2004, 10:53 AM   #10789
Hebiki's Avatar
Trader Rating: 26 (100%+)
man my R3 was supposed to be there.. oh well. oh ya ... im not part of Team Barracuda just an avid fan tho.
Hebiki Design Works
Custom R/C Vinyl Graphics & Apparel: Your gear, your way!
Web Design - Web Development - Logo Design - Graphic Design
www.facebook.com/HebikiDesignWorks
Hebiki is offline   Reply With Quote
Old 05-14-2004, 10:58 AM   #10790
Hebiki's Avatar
Default R2 vs R3
guys.. ive had both cars.. and what MikeR and the rest said is true. an R2 with a Xenon Stage 2 is about the same as an R3.
the main advantage i see with the R3 is the "floating" motor mount. the motor mount is now held by one screw on the main chassis. IMHO this makes it easier to align the entire drivetrain. the motor mount can actually pivot on that single screw making alignment easier.
compared to my R2 - Xenon stage 2... the R3 feels lighter. although i havent official weighed both car. this is helpful because then you can place weights accordingly. the R3 is also stiffer than a stock R2... but equally stiff with the Xenon Stage 2.
the scary thing is... MikeR and Linger are super fast with the R2s with the Xenon stage 2.. i cant begin to imagine how much faster the Cuda drivers can get when they use the R3.
you cant go wrong with either car.. but always get the aluminum shaft holders. those are these most important hopups for the Cuda cars.
Hebiki Design Works
Old 05-14-2004, 02:07 PM   #10791
rc-zombies's Avatar
Default Belt drive 'Cuda?
In the back ground..looks like a 'Cuda chassis with the motor in a different orientation. to me it looks like to be belt driven.
Old 05-14-2004, 02:11 PM   #10792
I think its a 415
COREY LEWIS is offline   Reply With Quote
Old 05-14-2004, 02:12 PM   #10793
rc-zombies's Avatar
Originally posted by COREY LEWIS
I think its a 415
yea..on second thought you could be right...
Old 05-14-2004, 02:40 PM   #10794
Hebiki's Avatar
its a 415 guys. the little bump on the front shock tower gives it away.
altho a belt drive cuda would be nice
Hebiki Design Works
Old 05-14-2004, 04:16 PM   #10795
JDM_DOHC_SiR's Avatar
Trader Rating: 31 (100%+)
Default Re: Belt drive 'Cuda?
Nope it`s a plane jane 415...the owner of FLAP no longer drives any cudas...he got pic`d up by Tamiya...
-Dave
Ȼ4.5 Centro+α ◊ TRF 501ӽ ◊ TRF 502ӽs ◊ TRF 503 ◊ TRF 511 ◊ TRF 201ӽr ◊ TRF 211ӽ
B5m ◊ T5m ◊SC5m ◊ B64deez nutz
Speedway PAL ◊ SDRC ◊ Shop UFO ◊ SMC
JDM_DOHC_SiR is offline   Reply With Quote
Old 05-14-2004, 04:22 PM   #10796
Doug
I still like my R2 over my R3... sure the R3 is a bit more stiff...but the strenght of the sparkle chassis is something that just plane not there thats why most of the ALEXfactory guys are still using the R2 Xenon and R2 PAL version....but ALEX Japan will be releasing the newer lot of R3`s with the standard Carbon fiber here around june time ...and that should be a step in the right direction.... but untill that time comes I`ll still use my R2....(or unless BMI gets hot on that 3mm chassis )
Both both cars are VERY WELL BALANCED.. just the R3 has a few more chassis tuning options
-Dave
Old 05-14-2004, 05:45 PM   #10797
Send a message via AIM to Dougnuts55
Default PAl
What is this pal and is it a hop up.
doug
Dougnuts55 is offline   Reply With Quote
Old 05-14-2004, 07:03 PM   #10798
OVA
OVA's Avatar
Trader Rating: 79 (100%+)
Doug yes the pal is a hop up for R2..Go to web site www.speedtechrc.net
I have not failed. I've just found 10,000 ways that won't work
OVA is offline   Reply With Quote
Old 05-14-2004, 07:22 PM   #10799
Herminator's Avatar
Send a message via ICQ to Herminator
The Xenon equiped R2 is deffinetly as capable as any other touring car, the R3 isn't much different mechanicly. Same number of bearings in the drivetrain, almost identicle geometry, rear hubs being slightly different is all I know of. It's almost a case of if you like the sparkle chassis and tc3 style steering or not.
The main advantage of the R3 is it's better in kit form than the R2, I think it's about time they did a higher spec kit version though. Any hint of a new web special Dave?
If the R3 is any lighter it would cause me some problems my chassis has enough lead on it as it is
Herminator is offline   Reply With Quote
Old 05-14-2004, 07:52 PM   #10800
No Web version.....as of yet...but I know that PAL has been quite closed lip about the R3 stuff they are working on ...moreto come on this as I find out more in the next month..
-Dave
WTB Alex Racing Barracuda R2 & R3 Funkymojo R/C Items: Wanted to Buy 3 02-03-2007 01:00 PM
alex racing barracuda con81 Electric On-Road 1 12-14-2005 03:36 AM
WTT: Alex Racing Barracuda R2 for PS2 AZ_Ron Other Items: For Sale/Trade or Wanted to Buy 0 02-13-2005 07:30 PM
Alex Racing Barracuda R3-New. rcracing1973 R/C Items: For Sale/Trade 9 04-11-2004 08:29 AM
Alex Racing Barracuda Bugs Bunny Singapore R/C Racers 6 01-22-2003 11:47 PM
