Alex Racing Barracuda R2 & R3 >
Old 05-09-2004, 09:47 PM
  #10756
linger's Avatar
Originally posted by OVA
HI Linger
I didn't know there are 2 different rear block?
R2 and R3 block please explan
The R3 rear block has the hingepin hole spaced closer to the wheel axle. It makes the arm almost parallel to the dogbone. I added spacers under the rear arm mounts to give more midcorner steering, but the R3 blocks negated that change!
linger is offline
Old 05-09-2004, 09:53 PM
  #10757
OVA
OVA's Avatar
Trader Rating: 82 (100%+)
Are we talking about the same thing ? does R3 have the hingepin hole for A-arm?
OVA is offline
Old 05-09-2004, 09:54 PM
  #10758
Hebiki's Avatar
Trader Rating: 26 (100%+)
Originally posted by linger
Hebiki,
Great job!. Pretty soon, I'll be asking you for setups!
hehe.. ling.. that'll be a looooooooong long time from now.. if ever?
too bad i cant run reedy with the rest of the fish drivers... someone's gotta represent in the L - main!
Hebiki is offline
Old 05-09-2004, 10:00 PM
  #10759
OVA
OVA's Avatar
L-main it is kinda too far down
OVA is offline
Old 05-09-2004, 10:01 PM
  #10760
OVA
OVA's Avatar
Linger YGPM
OVA is offline
Old 05-10-2004, 05:12 AM
  #10761
Hi everyone
I have been using the spool now for more than a month on my R2 (speedway pal convertion) and i found it that more steering on power out of the corners is increased.The spool is made of aluminium with the one-way diff cups press fitted into the spool and weights 17g. 3g less than the one-way.the diff cups shafts are triangle formed and pressed into the spool to form a solid bonding.The track we race here in Malta is not a high traction track , infact it's very low traction but i managed to find a setup for the car.
front oil 50w
front springs yokomo blue
rear oil 30w
rear springs yokomo blue
rear toe-in 2.5
front toe-in 0
front camber 1.0
rear camber 1.5
i was going to change the front oil to 30w for more front traction.When i try it i let you know guys.
Regards
Henry
speed1 is offline
Old 05-10-2004, 09:31 AM
  #10762
linger's Avatar
Ova,
I was referring to the outer hingepin hole. For the R3 rear blocks: imagine an R2 rear upright. Take the hingepin hole and move it up a couple of mm's.
linger is offline
Old 05-10-2004, 11:16 AM
  #10763
OVA
OVA's Avatar
Hey Linger
I got it... Thanks
OVA is offline
Old 05-10-2004, 12:58 PM
  #10764
MikeR's Avatar
Trader Rating: 15 (100%+)
Originally posted by speed1
Hi everyone
Regards
Henry
Nice- is this something you machined for yourself? Sounds similar to an idea I was toying with
MikeR is offline
  #10765
MikeR's Avatar
Chris and Linger- Good job guys!
Linger- you have pm
MikeR is offline
Old 05-11-2004, 12:17 AM
  #10766
Merciless's Avatar
Great work guys !!
keep it up and keep us informed of your set-up changes and the differences you feel they have made please
Merciless is offline
Old 05-11-2004, 12:40 AM
  #10767
Hi Mike
This idea was created from me and my friend who race in mod. class.I race in super stock class.I was going to do it myself at my workshop but i hav'nt got the tools to shape the inner part for press fit the diff cups so we decided to make at an engineering shop who he also is a friend of ours.we made the ends metal because in mod class there will be a lot of stress on the spool ends and if they are alum. they will be damaged.You can make it full aluminium but you have to use the plastic covers on the shafts like the x-ray uses.
Henry
Malta
speed1 is offline
Old 05-12-2004, 04:08 AM
  #10768
Hi Guys
Here are the pics of my spool i made.
Henry
Malta
Attached Thumbnails Alex Racing Barracuda R2 & R3-100nikon-dscn0777_dscn0777.jpg
speed1 is offline
Old 05-12-2004, 04:10 AM
  #10769
Hi Guys
And here is the pic of the battery holder i fitted.(I used x-ray battery holder).
Henry
Malta
Attached Thumbnails Alex Racing Barracuda R2 & R3-100nikon-dscn0774_dscn0774.jpg
speed1 is offline
Old 05-12-2004, 04:49 AM
  #10770
stjerno's Avatar
Thumbs up
Very nice stuff you have there, the spool looks very impressive
stjerno is offline
