Alex Racing Barracuda R2 & R3 >
Old 04-25-2004, 09:05 AM
  #10636
JusBox's Avatar
Originally posted by raving-monkey
thanks guys, there are a couple of big shops with lots of gears in stock now
i will need them
why do you have a pro 4?
JusBox is offline
Old 04-25-2004, 09:15 AM
  #10637
Merciless's Avatar
FOAM TYRES
how r u guys getting the larger 26mm and 28mm wheels to fit your R3's ??
Please help !!
Merciless is offline
Old 04-25-2004, 09:17 AM
  #10638
raving-monkey's Avatar
yeah
just thought it would be better as it is much easier to get parts and setups etc
raving-monkey is offline
Old 04-25-2004, 09:27 AM
  #10639
JusBox's Avatar
yeah
Cool, it's a great car... i just like ragging on it cause it's not as pretty as the r2/r3.
you do know how teflon sticks to the pan, right?
JusBox is offline
Old 04-25-2004, 11:05 AM
  #10640
hmm.....mybe they use CA.....now thats where my CA has gone, the pan makers stole it
lol
Old 04-25-2004, 01:21 PM
  #10641
Merciless's Avatar
Originally posted by Merciless
FOAM TYRES
Please help !!
NE1 ??
Old 04-25-2004, 02:08 PM
  #10642
RcMonk's Avatar
I have used 26mm foams on my R2 without any problems. With 28mm foams they rub the top of the front c-hub and the rear knuckles. I ended cutting the 28m foams down to 26mm on a tire truer. You might be able to make it work by getting c-hubs and rear knuckles made by Speedway Pal(if you have seen what they look like).
NE1 ??
RcMonk is offline
Old 04-25-2004, 03:06 PM
  #10643
Merciless's Avatar
Speedway Pal ?? got XENON hubs front and rear and with 26mm tyres the wheel just touches the trackrod ends
At the moment i was thinking a 1mm or maybe 2mm spacer between the drive hex and the wheel might be the answer but i still don't think that'll get 28mm wheels on there
Old 04-25-2004, 03:47 PM
  #10644
you could put a washer in there or just use offset wheels.
Old 04-25-2004, 04:11 PM
  #10645
RcMonk's Avatar
Post
Merciless,
Yes, the Speedway Pal front & rear hubs are different from Xenon's design. With the Pal hubs I think the tie rod ends are under the wheel so your 28mm wheel may have clearance where as with the Xenon ones the tie rod ends are outside the wheel so it rubs.
From what I read Steve at Speedtech is testing the Speedway Pal hubs so he might be able to order some soon. IN case you are interested, here is what the Pal hubs look like.
http://www2.ocn.ne.jp/~sw-pal/Newpro...erarmConv.html
You can do the spacer trick but make sure you have some low profile wheel nuts since you will have less threads on the axle after adding the spacers.
RcMonk is offline
Old 04-25-2004, 04:40 PM
  #10646
Herminator's Avatar
the speedway pal hubs are the answer for wide wheels, but you'll also need the drop down mounts shown at the bottom of the page RcMonk posted, otherwise the turnbuckles will foul the top deck.
For 26mm wheels you will be able to get away with thin spacers, too thick will mean there's not enough thread for the wheel nut to secure to. HPI used to include some very thin round spacers with their wheels, these are very handy if you can find them. I use them on the rear a lot because running on wood I use 21mm wheels and tyres and Schumacher are about the only company that make 21mm wheels that are easy to get and they have thick spokes that foul the suspension arms a little.
Herminator is offline
Old 04-25-2004, 04:57 PM
  #10647
Finally I was just about to ask if they still made them any more. I hope Steve gets them soon. 'Hint' 'Hint'
NismoSkyline17 is offline
Old 04-26-2004, 02:59 AM
  #10648
Merciless's Avatar
Looks interesting but those camber arms are very short when compared to the std. alex design versions.I believe this will give very aggressive turn in but there after not so good ??
Can't believe there's not another way of getting something as simiple as Std. sized foam tyres on a modern RC tourer
Old 04-26-2004, 06:17 AM
  #10649
Gazza_D's Avatar
stjerno,
going back to the Cirrus speedo, fits really easily in the cuda, found this pic of one mounted in my car to give you an idea on how much room there is with it mounted.
Gazza_D is offline
Old 04-26-2004, 06:32 AM
  #10650
stjerno's Avatar
Hi Gazza,
Thanks for the pic.. I'm now almost and very close to settling on the Cirrus (And then I'm reading that Tekin is back in business..)
What is that batterymount your are using ?
Stjerno
stjerno is offline
