Alex Racing Barracuda R2 & R3
Hudd
i use a mid size kimbro servo saver and it very good
Thanks Merciless,
Where did you get it from? Steve at Speedtech?
NA "Amc" in paignton UK 01803 666556
Sorry usually use steve for most things nowadays as my unhappy bank manager is noticing
But for small things the postage is alittle on the steep side
Tamiya servo saver set part 50204
Should be able to get it from most hobby dealers.
The Wallbanger
The Wallbanger
R3 drop
A quick question for all R3 owners ..
In the manual both dampers are build 59,5mm long, but I can't get my ridehight any higher that 6mm with that damper lenght..
Does any of you build the dampers without the internal spacers ?
I don't need a ridehigh of more than 6mm but I would like to be able to controll my drop with drop screws and not the length of the damper
(And the by the end of the seasone I won't be the wallbanger no more)
Update says not to use internal spacers on the R3
i have set my damper length to 62mm all round for faom use and find it to be about right i also put a single o-ring on the shaft of each shocker to prevent the theads damaging the seals if the shaft ever got that far up
hi, my R3 kit does not come with set screws ( for droop ) are those supposed to be there or i should get them separately ?
thanks
thanks
What internal spacers ? could you be more specific ? thanks for the help
thanks
thanks
thanks for the reply but is that a question mark or period at the end of your sentence ?
no drop screws included ? or .
Originally posted by stjerno
No drop screews included
My questionmark proberly would have looked like but I'll remember to make my statements a little more clear
thanks well how do you adjust the droops then ?
Re: R3 drop
Steve Wang
