Old 04-14-2004, 11:22 AM   #10516
JusBox's Avatar
Kinda off topic but I need to get some new pinion gears and was wondering what brand people like the most...
(i'm running some robinsons now but i don't like the set screws they use or the quality of the gear itself)
JusBox is offline   Reply With Quote
Old 04-14-2004, 12:10 PM   #10517
Regional Moderator
ImGoinRCn's Avatar
Send a message via Yahoo to ImGoinRCn
I changed mine out to Titanium Racing pinions and I like them a lot. They take the bigger set screw size...I got them from our hobby shop at the track.
When all else fails, aim for the quarter panel.
Several oval and off road vehicles
and a legend car nicknamed Kidney Stone.
X Factory R/C SCX-60CF
X Factory R/C X-6
ImGoinRCn is offline   Reply With Quote
Old 04-14-2004, 01:11 PM   #10518
John_S's Avatar
hi guys i was jsut woindering what the diffrent holes for the steering turnbuckles do to the handling for e.g the rear holes on the knuckles and the insde holes on the 2 servo saver parts and the rear part on the long servo link? thanks hope this makes sence
John_S is offline   Reply With Quote
Old 04-14-2004, 09:19 PM   #10519
koabich's Avatar
Send a message via Yahoo to koabich
Default R3
I am looking to purchase the R3. I am looking for several answers first...
1) How thick is the C/F chassis, upperdeck and shock towers?
2) Can I mount 28mm foam tires on the car without any modification? From the pictures I have seen, it doesn't look possible.
Joe
koabich is offline   Reply With Quote
Old 04-14-2004, 10:29 PM   #10520
GTO2's Avatar
R/C Tech Charter Subscriber
AWOL:
Not sure if you can find it in US, but here we mostly use Kawada, they are hard anodized. Very high quality and wear is minimum. Comes in 64 and 48p.
driftercentral.com
GTO2 is offline   Reply With Quote
Old 04-14-2004, 10:33 PM   #10521
Turbonium's Avatar
Trader Rating: 27 (100%+)
Send a message via Yahoo to Turbonium
as for the foams... i have a set of Jaco 28s that aaaaalomst go. minor filing, and/or maybe those Tamiya wheel spacers might do the trick. i have a set of 30s i cut the back down to fit my Evo, and they prolly wouldnt fit unless i cut off a bit more...
Wes
Team Novak
Turbonium is offline   Reply With Quote
Old 04-14-2004, 10:36 PM   #10522
GTO2's Avatar
which rear part on long servo link?
the 'rear' hole of the steering knuckles would give earlier steering/more steering, vice versa with the 'front' holes.
Servo saver inner holes = less ackerman (difference of your left and right wheels steering angle), outer holes = more.
driftercentral.com
Old 04-15-2004, 12:27 AM   #10523
SpeedTech's Avatar
Hi Guys,
Just to answer some of the questions I saw reading through the posts:
Less caster degree will give the car more turn in, and more caster degree will give the car more on-power steering (at least from my experience)
HPI C-hubs will not fit the R2 or R3
The top deck is 2.0mm and the bottom deck is 2.5mm I believe as far as thickness. Front and rear shock towers are 2mm I believe. 28mm are some what difficult to get on the car, but Linger might have a solution.
Steve Wang
>>>www.SpeedtechHobbies.com<<<
SpeedTech is offline   Reply With Quote
Old 04-15-2004, 10:50 AM   #10524
John_S's Avatar
the part where the long tie rod from the servo horm connects to the servo saver i think theres 2 holes for it
Old 04-16-2004, 08:02 AM   #10525
Merciless's Avatar
Send a message via ICQ to Merciless
Anyone ale to give me a quick reply with what the internal gear ratio is for the R2/R3 i think it 2.48 but can't find where it was posted to check
Merciless is offline   Reply With Quote
Old 04-16-2004, 08:43 AM   #10526
Send a message via AIM to R/C Anonymous
Geoff C.
R/C Anonymous is offline   Reply With Quote
Old 04-16-2004, 08:47 AM   #10527
raving-monkey's Avatar
Send a message via MSN to raving-monkey
yep, same as pro4
raving-monkey is offline   Reply With Quote
Old 04-16-2004, 08:58 AM   #10528
Merciless's Avatar
Thanks guys you know how to make a guy feel loved
The fast responce there was fantastic .......... now i can work out where to gear my car for tonight .......Oh getting excited now !!
Old 04-16-2004, 09:34 AM   #10529
OVA
OVA's Avatar
Trader Rating: 79 (100%+)
Good luck Merciless
I have not failed. I've just found 10,000 ways that won't work
OVA is offline   Reply With Quote
Old 04-16-2004, 10:15 AM   #10530
JusBox's Avatar
Originally posted by raving-monkey
yep, same as pro4
actually the pro 4 adopted the ratio from the R2... if you can't beat em, join em. notice you don't hear about tweak problems, busted gears, etc with the cudas. *jumps in a hole and hides*
WTB Alex Racing Barracuda R2 & R3 Funkymojo R/C Items: Wanted to Buy 3 02-03-2007 01:00 PM
alex racing barracuda con81 Electric On-Road 1 12-14-2005 03:36 AM
WTT: Alex Racing Barracuda R2 for PS2 AZ_Ron Other Items: For Sale/Trade or Wanted to Buy 0 02-13-2005 07:30 PM
Alex Racing Barracuda R3-New. rcracing1973 R/C Items: For Sale/Trade 9 04-11-2004 08:29 AM
Alex Racing Barracuda Bugs Bunny Singapore R/C Racers 6 01-22-2003 11:47 PM
