Alex Racing Barracuda R2 & R3 >
Like Tree4Likes
Old 04-11-2004, 09:49 PM
  #10486
linger's Avatar
Default Alex shocks
The Alex shock can easily be made to fit the smaller diameter AE and Tamiya springs. Just flip the upper shock collar upside down and use a tamiya lower spring perch. I remember trying an AE spring perch, but it interfered with the arm.
Square also makes a Tamiya spring retainer, so it should fit also:
http://64.70.208.72/speedtechrc/358.html
For high bite carpet, the alex springs just aren't stiff enough.
linger is offline
Old 04-11-2004, 10:02 PM
  #10487
linger's Avatar
Default REEDY RACE PREP: Dialed SPOOL setup.
For those planning on attending the Reedy Race, I've been working on a killer spool setup. This car recently dominated the 19 turn class (3 qualifying heats) at Speedworld. I got the car to carry silly corner speed with a spool with no hint of corner entry push.
Front
1.5 x 6.25 spring (17.09 lb/in), outer hole on arm and outer hole on shock tower.
30 wt oil with HPI #2 piston.
No swaybar
SPEEDTECH Prototype Spool
mid-span arms
Rear:
1.4 x 5.5 (15.69 lb/in) spring, outer hole on arm, 4th hole (counting from the outside) on the shock tower.
1.0 mm swaybar.
30 weight oil.
rear arm mounts raised 2 mm.
mid span arms.
The light front oil really lets the car dive in hard with a spool and the raised rear blocks lets the car rotate better during "rolling off throttle" corners. On-power steering was just plain silly with a spool. I can't figure out why, but the car carried a little more cornerspeed with the front swaybar off??
-ling
linger is offline
Old 04-11-2004, 10:27 PM
  #10488
OVA
OVA's Avatar
Trader Rating: 84 (100%+)
TC3 I'm backed ASC TC3 and Tamiya shock spring are the same Dia. Yokomo and alex shock spring are a little bigger Dia. yes the yokomo spring are shorter height than TC3
OVA is offline
Old 04-11-2004, 10:38 PM
  #10489
OVA
OVA's Avatar
linger with the front sway bar off that will make the car roll more in to the corner while the rear stay flater..linger if you remove the rear sway bar ,I believe it will make the car push ..Does your car drive twitches or react fast in to the corner with the front sway off?
OVA is offline
Old 04-12-2004, 01:51 AM
  #10490
Is Speedtech's R2/R3 Spool for sale already or not yet?
dhiracing.com is offline
Old 04-12-2004, 06:46 AM
  #10491
sands's Avatar
I've got a r2 with full xenon kit for sale. Head over to the for sale section if anybody wants a very clean car.
sands is offline
Old 04-12-2004, 08:58 AM
  #10492
linger's Avatar
Hi OVA,
I almost always use a front swaybar with a 1-way. The car spends less time rolling and more time twitching. However, with a spool, the front swaybar was contributing to a off-power push.
linger is offline
Old 04-12-2004, 11:16 AM
  #10493
OVA
OVA's Avatar
I do unterstand how spool works....I do have a spool for my losi xxx-sgp..
I don't like the way spool work and It strub alot speed in the corner and you have to drive different than one way diff.
I think if you drive front diff than spool work for them
OVA is offline
Old 04-12-2004, 11:22 AM
  #10494
OVA
OVA's Avatar
Hey Linger
I never find my car drive twitchie with the one way
I alway run 1 or 0 degree rear toe in ,and I never more than 1 degree.I like the car roll into the corner with no drag
OVA is offline
Old 04-12-2004, 02:50 PM
  #10495
Merciless's Avatar
The HPI No.2 pistons you guys use, Are they part of the HP6818 set available from speedtech (on this page http://64.70.208.72/speedtechrc/101.html) or different ???
Cheers guys
Merciless is offline
Old 04-12-2004, 08:12 PM
  #10496
pumpkinfish's Avatar
Yes. Here is a picture. You will need two sets to do all four shocks. Also think about getting shock bladders for the caps.
pumpkinfish is offline
Old 04-13-2004, 12:07 AM
  #10497
Merciless's Avatar
Cheers pumpkinfish for the info.
Already running yokomo shock caps and bladders, built the shocks on the second car with them outta the box.
Old 04-13-2004, 12:13 AM
  #10498
Merciless's Avatar
I'm thinking it'd be a good idea to replace the washers on the R3 steering rack with nylon ones or a good plastic anyone got any idea's on where i might be able to get these washers ??
The idea behind it is that they won't grab the alloy speedtech rack that i use.I've greased up the standard set-up now and it's better but i think changing the washers is the answer to a perfectly smooth steering rack.
I should also say the "grabbing" is probably due to me removing some material from the nylon spacers and alloy rack mounts to reduce all the free play in the steering system as standard, mine is now almost play free!
Old 04-13-2004, 01:11 AM
  #10499
Regional Moderator
ImGoinRCn's Avatar
I'm pretty happy with my bladder caps in my cars and trucks
ImGoinRCn is offline
Old 04-13-2004, 08:36 AM
  #10500
OVA
OVA's Avatar
Hey Linger YGPM
OVA is offline
