Old 03-25-2004, 09:42 AM   #10306
Maybe my impression ... but don't you guys miss Ko Racer's posts on this thread?
dhiracing.com is offline   Reply With Quote
Old 03-25-2004, 09:47 AM   #10307
Regional Moderator
ImGoinRCn's Avatar
Send a message via Yahoo to ImGoinRCn
Who's miss ko racer?
When all else fails, aim for the quarter panel.
Several oval and off road vehicles
and a legend car nicknamed Kidney Stone.
X Factory R/C SCX-60CF
X Factory R/C X-6
ImGoinRCn is offline   Reply With Quote
Old 03-25-2004, 11:58 AM   #10308
Merciless's Avatar
Send a message via ICQ to Merciless
Visit http://www.alexracingusa.com/setup_sheets.htm for some setup sheets provided by Speedtechrc.
Regards,
Mark
Sorry if i'm being blind or stupid but i can't see a single sheet there for a carpet track let alone 1 using foam tyres
Had already been there. looked most the usual places i think
Merciless is offline   Reply With Quote
Old 03-25-2004, 12:13 PM   #10309
linger's Avatar
Merciless,
I have a couple of good setups for foam tires on both medium traction and high traction Ozite carpet. I'll post them when I get home tonight.
-Ling
linger is offline   Reply With Quote
Old 03-25-2004, 12:29 PM   #10310
Merciless's Avatar
linger
Your the man Cheers dude
Old 03-25-2004, 04:04 PM   #10311
Regional Moderator
ImGoinRCn's Avatar
linger
I have one for foams and high bite carpet...
X Factory R/C X-6
Old 03-25-2004, 04:08 PM   #10312
Merciless's Avatar
ImGoinRCn
Post it dude PLEASE
Old 03-26-2004, 02:15 AM   #10313
Regional Moderator
ImGoinRCn's Avatar
ImGoinRCn
Post it dude PLEASE
I have changed slightly but this might be a start. I don't run the square hubs anymore, the camber link position are on the lower hole on the rear hubs, not the top, xenon front hubs and the 6113(?) rear hubs that reduce the rear toe. I am running all grey springs but might do a change this weekend but this might help.
X Factory R/C X-6
Old 03-26-2004, 02:16 AM   #10314
Regional Moderator
ImGoinRCn's Avatar
well, it said it attached but didn't
X Factory R/C X-6
Old 03-26-2004, 09:08 PM   #10315
linger's Avatar
Here are two setups for Ozite Carpet:
HIGH BITE OZITE SETUP:
Front:
40 Weight Oil, HPI #2 piston
AE purple 30.3 lb/in spring (used Tamiya lower spring perch)
shock mounted 3rd hole from outer on tower, inner hole on arm
mid span arms, short camber link mounted low on both bulkheads and castor block
2 deg antidive
Front diff set tight
Jaco double pink/orange
Rear:
30 weight oil, HPI #2 piston
Tamiya Gray 20.91 lb/in spring (used Tamiya lower spring perch)
shock mounted 2nd hole from outer on tower, 2nd hole from outer on the arm
mid span arms, short camber link mounted low on both bulkheads and rear block
Jaco double pink
Body: PF Mazda 6
Reedy 8 turn TI: 19/72
Old 03-26-2004, 09:12 PM   #10316
johnny55's Avatar
Send a message via AIM to johnny55
Selling my Web special guys. Just a heads up on the for sale forum
Johnny Hernandez
Fight on!
johnny55 is offline   Reply With Quote
Old 03-26-2004, 09:12 PM   #10317
linger's Avatar
Setup #2
LOW/MED BITE OZITE SETUP:
Front:
AE Copper 23.26 lb/in spring (used Tamiya lower spring perch)
shock mounted 2nd hole from outer on tower, outer hole on arm
2 deg antidive
Jaco plaid
Rear:
40 weight oil, HPI #2 piston
AE Gold 18.35 lb/in spring (used Tamiya lower spring perch)
shock mounted 2nd hole from outer on tower, outer hole on the arm
Jaco purple
Body: PF Mazda 6
Reedy 10 turn TI: 20/72
Xenon Chassis used for both setups.
Old 03-26-2004, 10:27 PM   #10318
pumpkinfish's Avatar
Here is linger's setups on a R2 setup sheet to make it easier. Hope I did there right! Do you have any other values like camber I should add?
pumpkinfish is offline   Reply With Quote
Old 03-26-2004, 10:37 PM   #10319
linger's Avatar
pumpkinfish,
Wow! Thanks!
I forgot to add,
For both setups
0 deg front toe
1.4mm sway bar in front
1.0 mm sway bar in rear
1.5 deg camber F/R
2.5 deg rear toe
5 mm ride height (per track rules)
Old 03-26-2004, 10:54 PM   #10320
Updated them above. I assumed you meant -2.5 rear toe-in.
WTB Alex Racing Barracuda R2 & R3 Funkymojo R/C Items: Wanted to Buy 3 02-03-2007 01:00 PM
alex racing barracuda con81 Electric On-Road 1 12-14-2005 03:36 AM
WTT: Alex Racing Barracuda R2 for PS2 AZ_Ron Other Items: For Sale/Trade or Wanted to Buy 0 02-13-2005 07:30 PM
Alex Racing Barracuda R3-New. rcracing1973 R/C Items: For Sale/Trade 9 04-11-2004 08:29 AM
Alex Racing Barracuda Bugs Bunny Singapore R/C Racers 6 01-22-2003 11:47 PM
