Alex Racing Barracuda R2 & R3 >
Like Tree4Likes
Old 03-14-2004, 01:34 PM
  #10186
i tried switching the rear hubs around on the R2 for one qualifier just to loosen the rear end up a little bit cuz it pushed a touch in the corners and it slowed my lap times down almost half a second a lap....weird i guess the rearof this car likes being planted
R/C Anonymous is offline
Old 03-14-2004, 02:18 PM
  #10187
JusBox's Avatar
I believe the rear toe is 4 degrees stock and if you switch the rear hub carriers, you'll get 0 degree. I'm going to pick up the ti nitrade arm mounts to reduce toe as 4 is a bit much if you ask me.
JusBox is offline
Old 03-14-2004, 02:27 PM
  #10188
stock is 3...i have the xenon rear hubs and offset balls...so my original setup was 2.5 per side b4 i changed them ...after changing i turned it into 1 degree per side...just thought it was weird how such a small change made that much difference...maybe ill try adding more rear toe to get faster laps...hehe...its worth a shot...im already clicking off lap times about .5 to 1 second a lap faster then 99% of the other fast guys at the track with the Cuda...only my team Anonymous drivers keep up well except when fast guys from out of town show up then they're right up there too
Old 03-14-2004, 02:28 PM
  #10189
OVA
OVA's Avatar
Trader Rating: 84 (100%+)
Post
O degree I don't think so..I would even like to get 1 and half degree and that would be great for me...I like it a little loose in the rear with the one way......
Now How do you get o degree in the rear
OVA is offline
Old 03-14-2004, 02:30 PM
  #10190
ova do u have the offset balls for the rear?... i have no problem getting that with the perty Hudy setup gauges i use theres also an optional rear hub carrier with less built in rear toe
Old 03-14-2004, 02:49 PM
  #10191
Merciless's Avatar
Not sure What sort the carpet is ............ some sort of felt i think.Quite fluffy in comparison to some other carpet tracks i've raced on.
Set-up is also much softer than any other carpet track i've run on.
We seem to be running on a similar set-up to most UK runners use on ashphelt with rubbers ?
Will be using the one-way to start with as at present i cannot find anywhere with diffs instock ??
Merciless is offline
Old 03-14-2004, 02:57 PM
  #10192
my guess would be ozite carpeting.
when i first got my R2 last season i ran plaid and purple tires on ozite with the box setup. I currently had a XXXS before this . I figured the setup was way too soft for foam but i figured i'd try it anyway since we run on a low traction carpet( new carpet not many drivers) My lap times were a good .5 a lap faster then my foam setup XXXS which made me the fastest at the track at that time....I would try the kit setup but i am sure many others have a nice setup to try out
Old 03-14-2004, 02:59 PM
  #10193
ah yea... Mr. Speedtech has an e-mail
Old 03-14-2004, 08:07 PM
  #10194
OVA
OVA's Avatar
Hi RC A. Yes I do have off set balls in the rear..I do have 1 degree rear hub ...I should be paying more attention
OVA is offline
Old 03-14-2004, 08:14 PM
  #10195
toe out in the rear?....never saw anyone do that
Old 03-14-2004, 08:26 PM
  #10196
OVA
OVA's Avatar
I'm sorry I mean ,I like to get maybe half or less degree toe in...I just want more toe out from the box stock
OVA is offline
Old 03-14-2004, 08:29 PM
  #10197
OVA
OVA's Avatar
Anybody know where can I get o degree rear hub for R2
OVA is offline
Old 03-15-2004, 01:35 AM
  #10198
GTO2's Avatar
OVA:
if you have the offset ball studs, you should be able to correct the amount of toe at the rear. Use it in combo with the stock studs.
GTO2 is offline
Old 03-15-2004, 05:55 AM
  #10199
OVA
OVA's Avatar
GTO I useing 4 offset ball studs in the rear and I turn the mark in ,to make is narrow in the back and turn other 180 degree out the front and all I can get is half degree total different
OVA is offline
Old 03-15-2004, 07:48 AM
  #10200
SpeedTech's Avatar
Actually, if you have the stock hub (which are 2 deg.) and you flip them left and right, you'll have zero rear toe, since the arms have 2 deg. built in, putting the rear hub on the opposite side will cancel out the 2 deg.
Steve Wang
SpeedTech is offline
