Old 03-01-2004, 05:32 PM   #9931
rc-zombies's Avatar
Now this is a 'Cuda!
Old 03-01-2004, 05:32 PM   #9932
Regional Moderator
ImGoinRCn's Avatar
Send a message via Yahoo to ImGoinRCn
A Hemi cuda... I like the green!
When all else fails, aim for the quarter panel.
Several oval and off road vehicles
and a legend car nicknamed Kidney Stone.
X Factory R/C SCX-60CF
X Factory R/C X-6
ImGoinRCn is offline   Reply With Quote
Old 03-01-2004, 05:35 PM   #9933
Randy Caster's Avatar
Trader Rating: 46 (100%+)
Somethin tells me the R3 corners better...
Old 03-01-2004, 05:43 PM   #9934
rc-zombies's Avatar
This one just goes right over those corners...
Old 03-01-2004, 05:43 PM   #9935
Herminator's Avatar
Send a message via ICQ to Herminator
Originally posted by Gazza_D
Thanks for those sentiments Randy, but I think i'll leave playing in the snow to the eskimos or the guys north of the border over here, any takers Herm????
You southerners are taking the piss, it's far too early to contemplate running outdoors
We've actually missed all the snow here its been chilly but dry
I mat be going to Carlisle in a couple of weeks though, always a good way to start the outdoor season, just hope the weather improves a bit. Also need to get a new motor, last years 19spec is dead I'll miss that motor, it was nice and powerful ut had a hard seasons racing.
gaz you'll have PM by the time you read this
Herminator is offline   Reply With Quote
Old 03-01-2004, 07:04 PM   #9936
True, propably run over the drivers stand as well with a novise driver at hand
Old 03-01-2004, 10:14 PM   #9937
arn671's Avatar
Trader Rating: 15 (100%+)
Default measuring droop?
Hey Cuda owners, just wanted to find out what reference point on the arms/uprights/hubs you use measure droop on the R2? under the screw up front or on the arm itself? Thanks
arn671 is offline   Reply With Quote
Old 03-01-2004, 11:15 PM   #9938
MikeR's Avatar
Place the chassis on a flat surface and measure up to the axle that way you can compare numbers to other cars as well as your front to back axles
www.exotekracing.com ☆ASSOCIATED☆DURANGO☆HPI☆HB RACING☆KYOSHO☆LOSI/TLR☆SERPENT☆TAMIYA☆TEKNO☆XRAY☆
A picture with your post, when trouble shooting, will probably get more rctech help than without...
MikeR is offline   Reply With Quote
Old 03-02-2004, 12:18 AM   #9939
Regional Moderator
ImGoinRCn's Avatar
Default Bevel gear assembly
Okay, I guess I was a little bored replacing my bearings and replacing some parts, I got out my camera and took some pictures of how I put on my bevel gears. The pics aren't the best but it gives you an idea how to put these on without breaking them. It is pretty easy and you just have to be careful not to squeeze too hard on the gear. I know there are people buying cudas and this is one kinda tricky part to assemble. There is probably an easier way to do this but thought I'd share mine in hopes of helping others. Click the link and look for the pictures of the gear assembly.
bevel gear assembly
X Factory R/C X-6
Old 03-02-2004, 07:38 AM   #9940
Regional Moderator
R/C Tech Charter Subscriber
Default Re: Bevel gear assembly
bevel gear assembly
Heath how you like your new bearings ? and its about time you clean that cuda
Ko Racer is offline   Reply With Quote
Old 03-02-2004, 10:02 AM   #9941
Regional Moderator
ImGoinRCn's Avatar
Default Re: Re: Bevel gear assembly
lol, why clean it, it's going to get dirty again..lol, j/k, the bearings are okay, I wonder if I should have cleaned them out and relubed them before installing? At least they are better than what I had...frozen bearings
X Factory R/C X-6
Old 03-02-2004, 10:10 AM   #9942
JusBox's Avatar
I don't see the bevel gear pics.
JusBox is offline   Reply With Quote
Old 03-02-2004, 10:13 AM   #9943
Regional Moderator
ImGoinRCn's Avatar
try it again, they're there under CudaR2...anyone else not see these?
X Factory R/C X-6
Old 03-02-2004, 12:54 PM   #9944
Lotus111's Avatar
Send a message via MSN to Lotus111
Post Most needed Spare parts and hotups
Thanks for your input so far, out off your replly iv'e got the following list:
Clear:
A6510 => Alex Racing Ti-nitride coated 6.8mm uncentered ball stud
PB049x => Speedway PAL Aluminum/Graphite center shaft for Pal drive system
A6111 => Alex Racing R2 Front Knuckle and C-Hub Carrier Set
A6112 Alex Racing R2 Flanged Pipe for C-Hub (4)
Question
sway bar PN: A634x => which set is most needed? 0.8-1.0 => 1.2-1.4 => 1.6-1.8
A6713 => Alex Racing Hard Material Mid-Span A-Arms or A6711 Alex Racing R2 Mid-Span suspension Arms => which is better?
alum shaft holder => What Part No ?? isn't this an original R3 Part ??
Ti axles => What is that Aluninium axles??
PB056x SpeedWay Pal aluminum steering rack for Barracuda R3 or A6360 Alex Racing Bearing Steering Rack Set (with bearings) => which is better
A6550x Alex Racing R2 Aluminum Battery Plate => fits the R3 ?
After that i can order by Steve
Thanks again
>> no limits <<
http://mcc-konstanz.spaces.live.com
http://de.youtube.com/user/stecher111
http://www.bawue-cup.de
Lotus111 is offline   Reply With Quote
Old 03-02-2004, 01:09 PM   #9945
Hebiki's Avatar
Trader Rating: 26 (100%+)
Default Re: Most needed Spare parts and hotups
Clear:
Question
Thanks again
get the mid span arms. made my R3 more responsive.
Ti Axles.. get them if you can, saves a lot of weight. less rotating mass for your drivetrain. i have them on my R3... saved a lot of weight over the regular steel ones. EDIT..they're made of titanium, not aluminum. MUCH LIGHTER.
for steering. i have the aluminum rack (more steering throw) and i threw in the ball bearings.. now its super smooth.
most important thing are the alum. shaft holders. the alum. steering rack combined with the bearings is really super nice too. id get those first if you cant decide what to get.
Hebiki Design Works
Custom R/C Vinyl Graphics & Apparel: Your gear, your way!
Web Design - Web Development - Logo Design - Graphic Design
www.facebook.com/HebikiDesignWorks
Hebiki is offline   Reply With Quote
WTB Alex Racing Barracuda R2 & R3 Funkymojo R/C Items: Wanted to Buy 3 02-03-2007 01:00 PM
alex racing barracuda con81 Electric On-Road 1 12-14-2005 03:36 AM
WTT: Alex Racing Barracuda R2 for PS2 AZ_Ron Other Items: For Sale/Trade or Wanted to Buy 0 02-13-2005 07:30 PM
Alex Racing Barracuda R3-New. rcracing1973 R/C Items: For Sale/Trade 9 04-11-2004 08:29 AM
Alex Racing Barracuda Bugs Bunny Singapore R/C Racers 6 01-22-2003 11:47 PM
