Alex Racing Barracuda R2 & R3
#9842
Originally posted by Hebiki
eek! luckily i have 4 extras for the wheel bearings.. they're the same size as the yokomo mini bearings....
mike.. are you running ceramics? btw. you going to rcheat?
RCheat is a definite MAYBE! Guess you kept your legs and arms attached after boarding? Hope to see ya at the track.
#9844
I am running Rc4less too, very smooth. They are higher grade than Acer if I'm not wrong.
#9845
Hi Guys,
As for ceramic bearings, I'm working on them and should be available next month.
Steve Wang
Steve Wang
#9846
Rain season
Just in case any of you guys try to blaim it on the wather.. now there's no excuse anymore for NOT going racing.
http://www.lrp-electronic.de/e/main_frameset_e.htm
Any one have any experience with the barracuda and rain ? I was thinking on the open diff's.
#9847
Regional Moderator
Re: Rain season
to much money in this hobby
#9848
Re: Rain season
of course, i wont do that again. if your gonna run in the rain, run the diff cases and throw your electronics in a balloon or something to protect them from the rain.
#9849
Re: Re: Rain season
back in dec of last year... we had a race.. and it started to rain.. my car (at the time i had an R2) was wicked fast. nothing was damaged, no electronics were fried. the only thing that got damaged was the body. the diffs were fine and weren't damaged at all. since i was running slicks.. im assuming it didnt kick up as much water as threaded tires tho.
Running in the wet is fun just have to get the tyres right, either Pit Schumizu D20's 20mm or 24mm treaded, or depending on conditions Take Off CS22's can work well It's weird but when there was a lot of standing water the CS22's worked very well, they don't do so well when it's just damp and greasey though, then you need D20's.
The only bit I don't like about wet weather racing is the clean up afterwards. You have to strip the car and clean the bearings the same day otherwise you'll have nice bits of orange rust on your car
#9852
R/C Tech Elite Member
Originally posted by Mr. MR4
Hi All,
I'm going to try out the locked diff on my R2 - Anyone has any tips on any set up changes? Springs, roll bars etc
I am currently using the stock set up with one way diff.
Karl
MALTA
Hi All,
Karl
MALTA
#9855
Regional Moderator
Originally posted by OVA
R2 Question: What size are the ball cup? and what other make brand cup that will fit R2?
