Old 02-24-2004, 04:56 PM   #9766
Herminator's Avatar
Send a message via ICQ to Herminator
Default Re: R2 Settings
Originally posted by BarracudaR2
Alex Racing Design Barracuda R2 setting
I just baught an R2 but I have a problem. My car keeps on spinning when it comes to even a slight turn . How to solve this?
Their must be something wrong with your car somewhere. You need to check the bearings to see if they're free and check your diffs to see if they're smooth. You may have a load of tweek from a hard crash or bad build. Droop settings may be way off on each side.
Basicly you need to do a full rebuild and make sure everything is right and put the kit setup on the car, then work from there.
Herminator is offline   Reply With Quote
Old 02-24-2004, 05:00 PM   #9767
rc-zombies's Avatar
Originally posted by Ko Racer
here is another mod I did every little bit helps
I did that mod as well when I had my WEB... unfortunately on the Pro4 there's no space for adding a plate...
Old 02-24-2004, 05:00 PM   #9768
Regional Moderator
R/C Tech Charter Subscriber
Default Re: Re: R2 Settings
Well Said Herm hey anybody heard from DAVE BRISTOL
Ko Racer is offline   Reply With Quote
Old 02-24-2004, 05:02 PM   #9769
Regional Moderator
Ramon how you liking the pro4? I have seen you got your self a bunch of purple goodies
Old 02-24-2004, 05:11 PM   #9770
Herminator's Avatar
Dave..... the missing man that many want to hear from
Old 02-24-2004, 05:36 PM   #9771
utieh's Avatar
Default Re: Re: Re: Cuda Shocks
Alex Racing shocks are close to Yokomo ones but thats as far as I know, it would be simpler to just use the right parts for a whole shock from one company
Actually Alex shock bodies were the cheapest ones I've found, and I can order them in purple
I think the shaft diameter must be the same from Yok to Alex, o-rings too, and since they provide the o-rings retainer with the shock body set, I were wondering if I needed also some other parts inside the shock?
utieh is offline   Reply With Quote
Old 02-24-2004, 05:50 PM   #9772
JusBox's Avatar
KO is that the penguin racing support disc they make for the sd?
JusBox is offline   Reply With Quote
Old 02-24-2004, 06:56 PM   #9773
eeyan's Avatar
Send a message via AIM to eeyan Send a message via Yahoo to eeyan
I have noticed the spur gear not spinning true and weight this weighs nothing ! and most in japan are doing this also must be some good to it
I use the Tamiya Evo III spur gear support plate on my SD... works the same way, but the good part is that the screw is countersunk so it's all flushed against the plate... I'm sure that will also work on the R2/R3...
TAOB Racing Team (1999 - 2011)
eeyan is offline   Reply With Quote
Old 02-24-2004, 08:24 PM   #9774
rc-zombies's Avatar
more purple goodies on the way..the car is so...underweight..it's at 48oz fully loaded w/ ballast weights without the body... the car handles great....
want to take it for a test drive..
Old 02-25-2004, 06:26 AM   #9775
Regional Moderator
UMMMMM ......If you still have it when I come back out this summer sure and I will bring you something to try out
Old 02-25-2004, 08:18 AM   #9776
Hebiki's Avatar
Trader Rating: 26 (100%+)
Default FOUND: Steering
that new steering rack is great! along with the ball bearings.. it was very very smooth and lots of steering.
steve.. that set up you gave me did the trick.... great starting point. thank you again! just need to tweak it a little bit more so i can get some on power steering now.
pictures coming later. time to work
Hebiki Design Works
Custom R/C Vinyl Graphics & Apparel: Your gear, your way!
Web Design - Web Development - Logo Design - Graphic Design
www.facebook.com/HebikiDesignWorks
Hebiki is offline   Reply With Quote
Old 02-25-2004, 09:19 AM   #9777
SpeedTech's Avatar
If you're running a one-way, first check both one-way are spinning freely. Next check if the car spins freely and there are no binds on either side of the car as far as the transmission goes. Lastly, make sure all the suspension measurements on each side are the same and equal (camber, toe, shock length, droop, ride height..etc.)
Steve Wang
>>>www.SpeedtechHobbies.com<<<
SpeedTech is offline   Reply With Quote
Old 02-25-2004, 09:20 AM   #9778
SpeedTech's Avatar
The spur gear support plate from the EVOIII does work on the R2 and R3 (I have them on my cars) also, we'll have the Tobee Craft aluminum spur gear support plate available as well in blue, red and purple (sorry Heibiki, no pink )
Steve Wang
Old 02-25-2004, 10:02 AM   #9779
JusBox's Avatar
Steve i have a question about the excel front c-hubs i bought... unlike the stock c-hubs they don't allow the front arms to drop all the way down (with the droop screw removed). I'm not sure it's an issue but I just want to make sure.
Old 02-25-2004, 10:48 AM   #9780
Hebiki's Avatar
Steve Wang
ouch
Hebiki Design Works
WTB Alex Racing Barracuda R2 & R3 Funkymojo R/C Items: Wanted to Buy 3 02-03-2007 01:00 PM
alex racing barracuda con81 Electric On-Road 1 12-14-2005 03:36 AM
WTT: Alex Racing Barracuda R2 for PS2 AZ_Ron Other Items: For Sale/Trade or Wanted to Buy 0 02-13-2005 07:30 PM
Alex Racing Barracuda R3-New. rcracing1973 R/C Items: For Sale/Trade 9 04-11-2004 08:29 AM
Alex Racing Barracuda Bugs Bunny Singapore R/C Racers 6 01-22-2003 11:47 PM
