Old 02-17-2004, 11:25 AM   #9601
rc-zombies's Avatar
Herm..
the Pro4 can be made Pretty..
a color change is easily done....get all purple re-done to a color of your choice...
Old 02-17-2004, 11:29 AM   #9602
Herminator's Avatar
Send a message via ICQ to Herminator
Originally posted by rc-zombies
Herm..
I quite like purple actually
Some one would have to offer me a NIB one though as a trade for my Cuda, even then it wouldn't cover it, heck maybe two Pro 4's so I have spares
Herminator is offline   Reply With Quote
Old 02-17-2004, 11:33 AM   #9603
JusBox's Avatar
I don't really see how the pro 4 would be better than a cuda, different but not better.
JusBox is offline   Reply With Quote
Old 02-17-2004, 11:33 AM   #9604
Regional Moderator
ImGoinRCn's Avatar
Send a message via Yahoo to ImGoinRCn
So hermie is the next to get rid of his cuda??
When all else fails, aim for the quarter panel.
Several oval and off road vehicles
and a legend car nicknamed Kidney Stone.
X Factory R/C SCX-60CF
X Factory R/C X-6
ImGoinRCn is offline   Reply With Quote
Old 02-17-2004, 11:36 AM   #9605
Herminator's Avatar
Probably not getting rid of it, spent too much cash on it. But if someone made a good offer I'd certainly consider it
I love the Cuda but I could get parts for other cars a lot cheaper and setup help at the club.
Old 02-17-2004, 05:03 PM   #9606
SpeedTech's Avatar
Originally posted by Hebiki
thanks steve! will try to swing by your place sometime this week to pick one up. work has been killing me!
Hebiki,
Don't worry, they are not here just yet. But I did order a pink one for ya
Steve Wang
>>>www.SpeedtechHobbies.com<<<
SpeedTech is offline   Reply With Quote
Old 02-17-2004, 11:37 PM   #9607
Hebiki's Avatar
Trader Rating: 26 (100%+)
dannnng. no luck with the hpi pistons. i had someone else drive my car... and they said it still pushes. i thought i was getting somewhere. here's the set up....
Front and Back
5mm ride height
5.75 springs (i used 6 and 6.25 all around, there's a difference, but not much)
40 wt oil
Hpi #2 pistons
Droop: 7mm (chassis flat on a setting board, measured from the end of the arm)
-1 camber all around
no sway bars
roll center raised 3mm
shortest camber link for both F & R
Front:
0 - toe
middle hole for shocks(5 holes for the R3)
inner hole on the A-arm
Rear:
2.5 toe
2nd hole counting from the inside for shocks
3rd hole counting from the inside on the A-arm
at socal, i ran Pit 30s with Xenon Blue inserts and Sorex 36R with HPI Greens...
ran the following bodies:
Mazda - good steering, not very responsive
Bugatti - more downforce a bit more steering.
Alfa - rear end is loose mid corner and on power.
GUYS... the drivetrain is about as free and smooth as I can get it. people who have seen it are impressed by it... (without ceramics, i have a free spin of 7-10 seconds). im getting very discouraged here.. not getting the car to where i want.
please PM or email me with any suggestions..... if im doing something wrong, pls let me know...
Linger... i still have to try your ideas. thanks for reading.
Hebiki Design Works
Custom R/C Vinyl Graphics & Apparel: Your gear, your way!
Web Design - Web Development - Logo Design - Graphic Design
www.facebook.com/HebikiDesignWorks
Hebiki is offline   Reply With Quote
Old 02-17-2004, 11:41 PM   #9608
JusBox's Avatar
Hebiki, did you have the pushing problems with the R2?
Old 02-17-2004, 11:43 PM   #9609
Hebiki's Avatar
someone at the track where i race ran it.. and he said he had to turn "2 hours early" just to get the car to turn.
a friend of mine has his R2... and you just THINK of turning and the car makes a u-turn.. thats how twitchy it is. i dont want it like that.. be something inbetween his and mine.
might as well put groceries in mine and call it a shopping cart. it pushes that bad now if i could only find a way to put the R3 drivetrain with the EvoIII suspension
Hebiki Design Works
Old 02-17-2004, 11:45 PM   #9610
JusBox's Avatar
yah i was over there trolling the evo guys for some fun. what makes the evo suspension an advantage over the r3?
Old 02-18-2004, 12:23 AM   #9611
Randy Caster's Avatar
Trader Rating: 46 (100%+)
Chris - You looked faster than ever tonight, just dont let the pressure get to you, and you'll be able to hold your position better.
How did the car do in the main with the changed springs?
Old 02-18-2004, 12:26 AM   #9612
Hebiki's Avatar
Randman... thanks dude. the springs helped a little. i think i was better off with the HPI GREEN/Sorex 36 combo. felt nice when i was scrubbing your tires. i didnt really get bothered by the pressure.. i was more disappointed that my car couldnt keep up with the way i wanted to drive it..... oh well..
AWOL... just easier to get more steering with the Evo, SD's... Losi if i remember correctly. that might be the chassis? but this is the first time ive struggled to find steering. of all the cars ive had.. this one has given me the hardest time.
im not giving up on it YET because my drivetrain is sooooooo free right now.
Hebiki Design Works
Old 02-18-2004, 12:29 AM   #9613
Hebiki's Avatar
forgot to answer your question. YES i had pushing problems with the R2. never got it completely solved because i went to the R3... now ive solved about 25% of the problem.
Hebiki Design Works
Old 02-18-2004, 01:00 AM   #9614
SpeedTech's Avatar
Hebiki,
You got PM!
Old 02-18-2004, 01:49 AM   #9615
Send a message via AIM to R/C Anonymous
Hebiki,
try moving your camberlink positionsto the middle holes on the deck, a sway bar in the rear might help, ithinkmy rear toe is about 2 degrees, a one-way will make it turn more, on the A-arms i have my shocks on the outer holes on front and back, lots of small stuff to try.
Hope it helps,
R/C Anonymous
Geoff C.
R/C Anonymous is offline   Reply With Quote
WTB Alex Racing Barracuda R2 & R3 Funkymojo R/C Items: Wanted to Buy 3 02-03-2007 01:00 PM
alex racing barracuda con81 Electric On-Road 1 12-14-2005 03:36 AM
WTT: Alex Racing Barracuda R2 for PS2 AZ_Ron Other Items: For Sale/Trade or Wanted to Buy 0 02-13-2005 07:30 PM
Alex Racing Barracuda R3-New. rcracing1973 R/C Items: For Sale/Trade 9 04-11-2004 08:29 AM
Alex Racing Barracuda Bugs Bunny Singapore R/C Racers 6 01-22-2003 11:47 PM
